> 2010 MS3 - Car Audio & Electronics
 Old 11-25-2010, 02:04 PM   #1
taylo105's Avatar
Posts: 1   (View Stats)
taylo105 is an unknown quantity at this point
Default Sub install on NON Bose system
I just purchased a 2010 MazdaSpeed 3 without the Bose system. I got a killer deal on it since it was a 2010 and they needed to clear out their 2010 inventory.
I have searched through the forums for adding a Sub, but all of the information I have found has referanced Bose Stereos. Can I add a sub to the stock stereo? Keeping the original headunit and speakers. I just wanted to add my Sub system from my old car.
taylo105 is offline   Reply With Quote
 Old 11-25-2010, 02:24 PM   #2
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Yes you can. I have on my Genpoo without the bose system.. here's my thread on what i used.. PAC OEM. Plugs directly into the headunit's wiring harness and gives you RCA outputs along with an amp turn on wire.
For anyone wondering..
No cutting wires, or splicing into your rear speaker inputs for a signal. Works perfect and sounds amazing.
 Old 11-25-2010, 08:56 PM   #3
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
You can use a LOC as well. But yeah, you def can toss that sub in. The non-Bose really needs it too. I've got a powered 10" JL Audio in mine.
BLK_MS3 is offline   Reply With Quote
 Old 12-24-2010, 06:31 PM   #4
WRX_Fan_0717's Avatar
Posts: 292   (View Stats)
WRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the worldWRX_Fan_0717 is the leader of the world
^What's an LOC? Too many acronyms.
The factory Bose (spare tire one) will not work with the regular stereo right?
WRX_Fan_0717 is offline   Reply With Quote
 Old 12-24-2010, 10:27 PM   #5
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
Line output converter. Basically gives you RCA's so you can add an amp to the stock head unit.
 Old 01-09-2011, 08:21 AM   #6
327whp's Avatar
Posts: 231   (View Stats)
327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute
Groaned at 7 Times in 5 Posts
I have put a custom system in the rear for shows using the stock deck still but all my speakers were replaced. The subs in these pics have also been replaced with the new Fosgate Power T1 12s. Sounds great for a stock headunit.
327whp is offline   Reply With Quote
 Old 01-18-2011, 10:04 PM   #7
chris23023's Avatar
Posts: 43   (View Stats)
chris23023 has a spectacular aura aboutchris23023 has a spectacular aura about
I am looking at doing some work to mine but want to keep the stock HU, It's good to know the stock HU isn't that limiting
Not to get to far off topic but, what are you using for an amp(s)? I know it's HiFonics, but more detail pls
2007 BMW 335i E92 with COBB Stage 2+ (DP's/FMIC/DCI/E30)
2010 Black Mica Mazdaspeed 3 SOLD
CP-E Intake/ COBB AP(Self Tuned 93-Eth tune in the works)/ Corksport TP/ Autotech Internals/ CP-E RMM/ Custom nylon shifter bushings/ Custom Short shifter plate/ DDM 5K HID/ 30% window tint
chris23023 is offline   Reply With Quote
 Old 01-20-2011, 03:18 PM   #8
327whp's Avatar
The amp is Hifonics new 5 channel. The new Zxi60.4 + 1k. I needed the mono power and this gives me 1000 RMS for the mono side. Can't find another amp that even comes close in price to power ratio.
Originally Posted by donotbugme View Post
If you went that far you need to go all the way and change your headunit. I cannot believe the difference from the lc6i loc to replacing the hu with this:
Pioneer AVIC-X920BT.
Since I am using the car for both show and autocross I had to spread the money around and get the most for my money. For shows I get extra points for keeping everything looking stock up front but I do plan on getting a HU and it will be the Pioneer 120BT new this year. I also wanted to hear just what the system would sound like using the stock deck first but it will be coming out. Thanks
Last edited by 327whp; 01-20-2011 at 03:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-18-2011, 10:38 PM   #9
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
DONOTBUGME is offline   Reply With Quote
 Old 01-20-2011, 03:25 PM   #10
327whp's Avatar
I will actually post up a pick with the new Fosgate Power T1's now that they are actually in and running. Things sound killer in the back of this car and I was able to eliminate all rattling by dynomatting the entire back end. Now if only I can stop my front window and mirror from vibrating
 Old 01-23-2011, 03:01 PM   #11
DONOTBUGME's Avatar
Groans: 266
Your display for the subs and amp looks great. I want to do a custom box in the hatch maybe with a false bottom and having the sub go into where the spare tire sits or something. But like you I am also torn between performace/visual/sound upgrades.
 Old 01-24-2011, 02:40 PM   #12
327whp's Avatar
Thanks. There is actually more to that bax then you can see and the floor also. I have LED's built into the floor under the plexiglass so it all lights up, plus on the back of the box when I have the seats down is a custom MAZDA 3 in 3D built directly into the box which also has LED's which makes it look insane I think. Very cool and I like. Very hard to tell but here is a pick.
The Following User Says Thank You to 327whp For This Useful Post:
DONOTBUGME (01-24-2011)
 Old 01-24-2011, 04:00 PM   #13
DONOTBUGME's Avatar
Groans: 266
if you dont mind me asking, how much would something like that run?
 Old 01-25-2011, 03:20 PM   #14
327whp's Avatar
Well I know the owner of the stereo shop so he matches all my prices but just to do the 3D Mazda 3 on the box would cost someone about $100. I'm not sure what you want prices on and my price is a package deal. $1000-$1500 for stereo components, wiring and materials plus your labor costs. The LED kits actually add up pretty quick. I have them all over, under dash, seats, in all vents etc. Looks bad ass though at night and well worth it.
 Old 01-25-2011, 09:29 PM   #15
DONOTBUGME's Avatar
Groans: 266
Thats not a bad price for the stereo equipment
 Old 02-10-2011, 01:33 PM   #16
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
LOC, Amp, Sub Install
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f434/sub-install-non-bose-system-65680/
The Non This thread Refback 05-27-2013 11:16 PM
New system to replace Bose BreakTheStatic MazdaSpeed 3/6 - Car Audio & Electronics 18 03-23-2011 12:28 AM
aftermarket hu with bose system cbspeed3 MazdaSpeed 3/6 - Car Audio & Electronics 7 05-15-2010 05:37 PM
Better Bose system! _Toxic_ 2010 MS3 - Car Audio & Electronics 2 03-23-2010 11:24 AM
regarding the bose system in 1st gen speed3 tiness69 MazdaSpeed 3/6 - Car Audio & Electronics 1 03-20-2010 12:06 PM
Bose system questions... splat1 MazdaSpeed 3/6 - Car Audio & Electronics 1 06-17-2008 12:42 PM
Page generated in 0.37995 seconds with 28 queries
