> 2010 MS3 - Car Audio & Electronics
 Old 09-06-2017, 10:53 AM   #1
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Default Swapping a 2013 HU into a 2012
If I can find a 2013 head unit, how difficult would it be to swap in a 2012? I don't use the actual radio; however, the interface and button layout sorta bothers me. I've looked into the Eonon ones that people have used, but I've read so many reviews that are a little less than positive, with the biggest turnoff being they're quieter, and make buzz sounds at higher volumes.
Now, when I do upgrade to this unit I will be adding an amp along with speakers. I would just get a double din unit, but I really enjoy the OEM look of the 13's setup.
I'm assuming that the stereo would literally just slide in if I replaced that whole section since nothing else is different (from what I've seen).
But my main question would be wiring/ functionality. I haven't seen any threads where somebody has done this, so I have no idea if the steering wheel buttons would become obsolete, or if I'd be able to use the GPS on the actual head unit (I really don't mind where the 12's is up front, but it can be a bit frustrating at times).
I know of the little adapters they make so you can use double din setups, aside from how ugly they look with the huge bottom lip, I'd prefer to just get the OEM one so it's flush since I'll be adding an amp later down the road when I sound damp.
Any input is appreciated.
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
 Old 09-12-2017, 01:58 PM   #2
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
I was wondering the same thing. I do know the stock radio is an ugly pos !
Why use a dial to change the song, much less plop it in the center like a volume button?
Can't tell you how many times a friend has changed a song trying to turn the "volume" down
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 09-29-2017, 08:32 AM   #3
slubell614's Avatar
Posts: 6   (View Stats)
slubell614 is an unknown quantity at this point
I wondered the same thing if headunit could be swapped into a 2011... I hope someone can answer!!
slubell614 is offline   Reply With Quote
Gauge cluster swapping oakley990099 Gen2 MS3 General Discussion 3 03-31-2015 10:55 PM
Swapping out rods!! ledfootrob 2010 MS3 - Engine, Transmission & Driveline 6 11-26-2013 04:08 AM
swapping out smoking stocker 2gr84u MazdaSpeed 3/6 - Turbo Induction 4 03-27-2012 07:06 PM
Swapping ECU's xcoldricex MazdaSpeed 3/6 - ECU Computer Tuning 4 01-15-2011 03:36 PM
Swapping to Evo 9 stock turbo cageyvet Mazdaspeed3/6 General Discussion 11 10-05-2008 08:18 PM
Page generated in 0.24571 seconds with 22 queries
