> 2010 MS3 - Torque Specs & information
Like Tree4Likes
  • 2 Post By HOCKEYNUBE
  • 1 Post By Mylifeiseasy
  • 1 Post By 5hiftyy
 Old 10-18-2015, 07:25 PM   #1
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
Neutral  +2 score
Default All-Data engine TQ specs
So I took the time to pull a bunch of engine torque specs from all-data. Enjoy, and let me know if you need any more and I can try and dig them up!
HEAD
Loosening order:
(I personally recommend a few loosening steps)
Tightening order:
Step 1: 3-11 Nm (27-97 in-lbf)
Step 2: 13-17 Nm (116-150 in-lbf)
Step 3: 43-47 Nm (32-34 ft-lbf)
Step 4: 88°-92°
Step 5: 88°-92°
(for stock bolts only!)
CAM CAPS
Loosening order:
Tightening order:
Step 1: 5-9 Nm (45-79 in-lbf)
Step 2: 14-17 Nm (11-12 ft-lbf)
VALVE COVER
Loosening order:
Tightening order:
8-10 Nm (71-84 lb-in)
OIL PAN
Tightening order:
17-23 Nm (13-16 ft-lbf)
CRANK BOLT
Tightening:
Step 1: 96-104 Nm (71-76 ft-lbf)
Step 2: 87°-93°
TIMING COVER
Tightening order:
Bolts 1-18: 8-11 Nm (71-97 lb-in)
Bolts 19-22: 40-55 Nm (30-40 lb-ft)
WATER PUMP
Tightening:
Bolts 1: 17-23 Nm (13-16 lb-ft)
Bolts 2: 8-11 Nm (71-97 lb-in)
REAR MAIN SEAL
Tightening order:
EXHAUST MANIFOLD
Tightening order:
43-64 Nm (32-47 lb-ft)
OIL PUMP
Tightening order:
Step 1: 8-12 Nm (71-106 in-lbf)
Step 2: 17-23 Nm (13-16 ft-lbf)
CAM SPROCKETS
Tightening:
69-75 Nm (51-55 ft-lbf) (both sides)
THROTTLE BODY
Tightening order:
FLYWHEEL
Tightening order:
108-116 Nm (80-85 ft-lbf)
PRESSURE PLATE
Tightening order:
Tighten in a MINIMUM of 2 steps ending with 25-33 Nm (19-24 ft-lbf)
FUEL RAIL COVER
8-10 Nm (71-88 in-lbf)
THERMOSTAT
TIMING COMPNENTS
Bolts 1: 8-11 Nm (71-97 in-lbf)
Bolts 2: 20-30 Nm (15-22 ft-lbf)
HIGH PRESSURE FUEL PUMP
(the E8 bolts) 9-11 Nm (80-97 in-lbf)
PCV PLATE
POWER STEERING DUMBY PULLEY
19-25 Nm (15-18 ft-lbf)
IDLER PULLEY
INTAKE MANIFOLD
Bolts 1: 17-23 Nm (13-16 ft-lbf)
Bolts 2: 4-6 Nm (35-52 in-lbf)
FUEL RAIL
1. 17-23 Nm, 13-16 ft/lbs
2. 22-25 Nm, 17-18 ft/lbs
3. 24-35 Nm, 18-25 ft/lbs
4. 8-11 Nm, 71-97 in/lbs
5. 17-23 Nm, 13-16 ft/lbs
6. 16-24 Nm, 12-17 ft/lbs
FRONT HUB
1. 236-275 Nm, 175-202 ft/lbs
2. 82-101 Nm, 61-74 ft/lbs
3. 64-74 Nm, 48-54 ft/lbs
4. 43-60 Nm, 32-44 ft/lbs
5. 4-6 Nm, 36-53 in/lbs
6. 38-50 Nm, 29-36 ft/lbs
7. 44-58 Nm, 33-42 ft/lb
STARTER
1. 38-51 Nm, 29-37 ft/lbs
2. 38-51 Nm, 29-37 ft/lbs
3. 10-11 Nm, 89-97 in/lbs
ALTERNATOR
3. 8-10 Nm, 71-88 ft/lbs
4. 8-10 Nm, 71-88 ft/lbs
5. 10-14 Nm, 89-123 in/lbs
KNOCK SENSOR
1. 16-24 Nm, 12-17 ft/lbs
COIL PACKS
1. 6-9.5 Nm, 54-84 in/lbs
BLIND PLUG
1. 18-22 Nm, 14-16 ft/lbs
CRANK SENSOR
1. 5.5-7.5 Nm, 49-66 in/lbs
CAM SENSOR
I will be updating as I get suggestions or find more!
Mylifeiseasy and ms3gt08 like this.
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following 15 Users Say Thank You to HOCKEYNUBE For This Useful Post:
Dubcnea (04-16-2019), g00s3y (10-18-2015), Hush (11-05-2015), jdmage_mx5 (10-18-2015), Mattyhawk1 (01-09-2016), monkey.bones.007 (10-18-2015), MRR (04-09-2019), MS3Shadow (10-18-2015), sho (10-19-2015), Snyeed (10-19-2015), speed23 (10-18-2015), SpeedRebirth (11-05-2015), TJM216 (11-06-2015), tparker14 (10-18-2015), WAMBUSHHHH! (10-19-2015)
 Old 11-05-2015, 08:43 PM   #2
HOCKEYNUBE's Avatar
updated a little bit more info
@Raider; can I possibly get a sticky?
The Following User Says Thank You to HOCKEYNUBE For This Useful Post:
BLKSTIG (11-18-2015)
 Old 06-24-2017, 02:49 PM   #3
Aeternus Nexus's Avatar
Posts: 7   (View Stats)
Aeternus Nexus will become famous soon enough
I know I'm reviving a long dead thread, but could you specify if you use any type of threadlock on any of these? If at all?
Aeternus Nexus is offline   Reply With Quote
 Old 06-25-2017, 08:07 PM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The only bolts that need threadlocker are the flywheel bolts, but it's already on them when you buy new oem bolts.
 Old 06-25-2017, 08:09 PM   #5
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
3 And 4 on alternator bolts aren't converted to ft/lbs right
Sent from my SM-G935P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 09-26-2018, 04:10 PM   #6
Sasuke-kun's Avatar
Posts: 25   (View Stats)
Sasuke-kun is a jewel in the roughSasuke-kun is a jewel in the roughSasuke-kun is a jewel in the rough
Groaned at 24 Times in 7 Posts
This is God sent. I'm about to start a teardown and rebuild and this is exactly what I need. Anyway you have engine clearance specs as well? I am going to be running supertech rods and supertech pistons and running a bnr stage 3 with a boost goal of 25 PSI, so I'll spec out how much ring-gap I need to avoid butting. I'm more worried about PTW clearances. It will be bored to 88MM and 4032 alloy pistons and I'm trying to avoid piston-slap.
Sasuke-kun is offline   Reply With Quote
 Old 09-26-2018, 09:28 PM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
supertech should supply you with "recommended" PTW clearance and ring gap specs.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-27-2018, 08:25 AM   #8
Sasuke-kun's Avatar
Why the quotes?? I'm trying to get more than 75k of the motor. Tighter clearances are the first step.
 Old 09-27-2018, 08:40 AM   #9
Fstrnyou's Avatar
Clearances will depend on piston design, the expansion ratio of the material, and how you intend to operate the vehicle. I emailed Manley with my details and they told me what clearances I should run.
Other rides:
History:
 Old 09-27-2018, 08:53 AM   #10
Sasuke-kun's Avatar
I'm also thinking of running 88mm pistons. You're not having any problems with heat soaking the cylinder walls due to there being a bigger bore?
 Old 09-27-2018, 10:09 AM   #11
Fstrnyou's Avatar
Its been a while since I've checked my cylinder wall temperature sensor, but thinner cylinder walls should transfer heat faster to the coolant. Additionally, a larger bore increases the surface area in which to distibute the heat.
Other rides:
History:
 Old 09-27-2018, 10:24 AM   #12
Sasuke-kun's Avatar
I'm more concerned about knock being caused be the additional heat within the cylinder head. The walls act as a heat sink so when you bore the engine, you are effectively decreasing that heat sinks ability to absorb cylinder heat. I can upgrade the coolant system with ducting and silicone hoses so not to overwork the coolant. Idk man, I'm just bouncing shit off now lol.
 Old 09-27-2018, 11:37 AM   #13
Fstrnyou's Avatar
With less material to be a heatsink, it is likely the cylinder walls heat up faster, but the same goes for the coolant's ability to pull the heat away.
This might not equate, but if you're too hot in the winter, wear a thinner coat.
Other rides:
History:
 Old 10-15-2018, 12:16 PM   #14
Sasuke-kun's Avatar
I just realized your in Charlotte nc. I'm in Raleigh nc. Small world lol. The speed community is growing here, hell the car scene in general is becoming a thing here.
 Old 12-24-2019, 10:54 AM   #15
Mylifeiseasy's Avatar
Posts: 74   (View Stats)
Mylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud of
Groaned at 6 Times in 3 Posts
Can someone update the pics or repost them.?
VeneCZ likes this.
2008.5 gtx fmic dm pd Manley
Mylifeiseasy is offline   Reply With Quote
 Old 01-16-2020, 02:47 PM   #16
VeneCZ's Avatar
Posts: 1   (View Stats)
VeneCZ is an unknown quantity at this point
^ Would really appreciate this as well.
Thank you
VeneCZ is offline   Reply With Quote
 Old 01-16-2020, 03:35 PM   #17
Police - Grammarhead
Vansquish's Avatar
Thank you
The OP hasn't been on the forum since February 2018. You can try PMing him to see if he'll update the photos. Nobody else has them though.
 Old 02-02-2020, 09:40 PM   #18
5hiftyy's Avatar
Posts: 2   (View Stats)
5hiftyy has a little shameless behaviour in the past
Thank you
Here's a Google Drive link to a folder for this thread, in case the photos go down again.
VeneCZ likes this.
5hiftyy is offline   Reply With Quote
torque specs for engine on ms6 dkfung88 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-24-2014 05:18 PM
Report: Alfa Romeo 4C specs and performance data leak via dealer brochure Haltech Automotive News 0 08-27-2013 08:30 AM
Engine Stand Bolt Specs Airman3454 Gen2 MS3 General Discussion 6 07-07-2013 05:47 PM
Engine specs viper1b2 MazdaSpeed 3 - Engine, Transmission & Driveline 6 05-09-2011 06:14 PM
MS3,MZ3, MZ5 Engine Mount Torq Specs Grumpyjap MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-05-2011 02:47 PM
Page generated in 0.44572 seconds with 29 queries
