![]() Join Date: Aug 2013 Location: Mentor, Ohio
(Thread Starter) | Neutral : +2 score So I took the time to pull a bunch of engine torque specs from all-data. Enjoy, and let me know if you need any more and I can try and dig them up! HEAD Loosening order: (I personally recommend a few loosening steps) Tightening order: Step 1: 3-11 Nm (27-97 in-lbf) Step 2: 13-17 Nm (116-150 in-lbf) Step 3: 43-47 Nm (32-34 ft-lbf) Step 4: 88°-92° Step 5: 88°-92° (for stock bolts only!) CAM CAPS Loosening order: Tightening order: Step 1: 5-9 Nm (45-79 in-lbf) Step 2: 14-17 Nm (11-12 ft-lbf) VALVE COVER Loosening order: Tightening order: 8-10 Nm (71-84 lb-in) OIL PAN Tightening order: 17-23 Nm (13-16 ft-lbf) CRANK BOLT Tightening: Step 1: 96-104 Nm (71-76 ft-lbf) Step 2: 87°-93° TIMING COVER Tightening order: Bolts 1-18: 8-11 Nm (71-97 lb-in) Bolts 19-22: 40-55 Nm (30-40 lb-ft) WATER PUMP Tightening: Bolts 1: 17-23 Nm (13-16 lb-ft) Bolts 2: 8-11 Nm (71-97 lb-in) REAR MAIN SEAL Tightening order: 8-11 Nm (71-97 lb-in) EXHAUST MANIFOLD Tightening order: 43-64 Nm (32-47 lb-ft) OIL PUMP Tightening order: Step 1: 8-12 Nm (71-106 in-lbf) Step 2: 17-23 Nm (13-16 ft-lbf) CAM SPROCKETS Tightening: 69-75 Nm (51-55 ft-lbf) (both sides) THROTTLE BODY Tightening order: 8-11 Nm (71-97 lb-in) FLYWHEEL Tightening order: 108-116 Nm (80-85 ft-lbf) PRESSURE PLATE Tightening order: Tighten in a MINIMUM of 2 steps ending with 25-33 Nm (19-24 ft-lbf) FUEL RAIL COVER 8-10 Nm (71-88 in-lbf) THERMOSTAT 8-10 Nm (71-88 in-lbf) TIMING COMPNENTS Bolts 1: 8-11 Nm (71-97 in-lbf) Bolts 2: 20-30 Nm (15-22 ft-lbf) HIGH PRESSURE FUEL PUMP (the E8 bolts) 9-11 Nm (80-97 in-lbf) 17-23 Nm (13-16 ft-lbf) PCV PLATE 8-11 Nm (71-97 in-lbf) POWER STEERING DUMBY PULLEY 19-25 Nm (15-18 ft-lbf) IDLER PULLEY 20-30 Nm (15-22 ft-lbf) INTAKE MANIFOLD Bolts 1: 17-23 Nm (13-16 ft-lbf) Bolts 2: 4-6 Nm (35-52 in-lbf) FUEL RAIL 1. 17-23 Nm, 13-16 ft/lbs 2. 22-25 Nm, 17-18 ft/lbs 3. 24-35 Nm, 18-25 ft/lbs 4. 8-11 Nm, 71-97 in/lbs 5. 17-23 Nm, 13-16 ft/lbs 6. 16-24 Nm, 12-17 ft/lbs FRONT HUB 1. 236-275 Nm, 175-202 ft/lbs 2. 82-101 Nm, 61-74 ft/lbs 3. 64-74 Nm, 48-54 ft/lbs 4. 43-60 Nm, 32-44 ft/lbs 5. 4-6 Nm, 36-53 in/lbs 6. 38-50 Nm, 29-36 ft/lbs 7. 44-58 Nm, 33-42 ft/lb STARTER 1. 38-51 Nm, 29-37 ft/lbs 2. 38-51 Nm, 29-37 ft/lbs 3. 10-11 Nm, 89-97 in/lbs ALTERNATOR 1. 38-51 Nm, 29-37 ft/lbs 2. 38-51 Nm, 29-37 ft/lbs 3. 8-10 Nm, 71-88 ft/lbs 4. 8-10 Nm, 71-88 ft/lbs 5. 10-14 Nm, 89-123 in/lbs KNOCK SENSOR 1. 16-24 Nm, 12-17 ft/lbs COIL PACKS 1. 6-9.5 Nm, 54-84 in/lbs BLIND PLUG 1. 18-22 Nm, 14-16 ft/lbs CRANK SENSOR 1. 5.5-7.5 Nm, 49-66 in/lbs CAM SENSOR 1. 5.5-7.5 Nm, 49-66 in/lbs I will be updating as I get suggestions or find more!
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller Last edited by HOCKEYNUBE; 11-05-2015 at 08:42 PM. |
| The Following 15 Users Say Thank You to HOCKEYNUBE For This Useful Post: | Dubcnea (04-16-2019), g00s3y (10-18-2015), Hush (11-05-2015), jdmage_mx5 (10-18-2015), Mattyhawk1 (01-09-2016), monkey.bones.007 (10-18-2015), MRR (04-09-2019), MS3Shadow (10-18-2015), sho (10-19-2015), Snyeed (10-19-2015), speed23 (10-18-2015), SpeedRebirth (11-05-2015), TJM216 (11-06-2015), tparker14 (10-18-2015), WAMBUSHHHH! (10-19-2015) |
(Thread Starter) | Not Ranked : 0 score updated a little bit more info @Raider; can I possibly get a sticky?
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller |
| The Following User Says Thank You to HOCKEYNUBE For This Useful Post: | BLKSTIG (11-18-2015) |
![]() Join Date: Jun 2015 Location: Oakdale, Minnesota
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score I know I'm reviving a long dead thread, but could you specify if you use any type of threadlock on any of these? If at all? |
Groans: 60
| Not Ranked : 0 score The only bolts that need threadlocker are the flywheel bolts, but it's already on them when you buy new oem bolts.
![]() Join Date: Jun 2014 Location: Savannah , GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score 3 And 4 on alternator bolts aren't converted to ft/lbs right Sent from my SM-G935P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC |
![]() Join Date: Sep 2018 Location: Raleigh, NC
Rep Power: 20 ![]() ![]() ![]() Thanks: 54
Groaned at 24 Times in 7 Posts
| Not Ranked : 0 score This is God sent. I'm about to start a teardown and rebuild and this is exactly what I need. Anyway you have engine clearance specs as well? I am going to be running supertech rods and supertech pistons and running a bnr stage 3 with a boost goal of 25 PSI, so I'll spec out how much ring-gap I need to avoid butting. I'm more worried about PTW clearances. It will be bored to 88MM and 4032 alloy pistons and I'm trying to avoid piston-slap. |
| Not Ranked : 0 score supertech should supply you with "recommended" PTW clearance and ring gap specs.
| Not Ranked : 0 score Clearances will depend on piston design, the expansion ratio of the material, and how you intend to operate the vehicle. I emailed Manley with my details and they told me what clearances I should run.
| Not Ranked : 0 score I'm also thinking of running 88mm pistons. You're not having any problems with heat soaking the cylinder walls due to there being a bigger bore? |
| Not Ranked : 0 score Its been a while since I've checked my cylinder wall temperature sensor, but thinner cylinder walls should transfer heat faster to the coolant. Additionally, a larger bore increases the surface area in which to distibute the heat.
| Not Ranked : 0 score I'm more concerned about knock being caused be the additional heat within the cylinder head. The walls act as a heat sink so when you bore the engine, you are effectively decreasing that heat sinks ability to absorb cylinder heat. I can upgrade the coolant system with ducting and silicone hoses so not to overwork the coolant. Idk man, I'm just bouncing shit off now lol. |
| Not Ranked : 0 score With less material to be a heatsink, it is likely the cylinder walls heat up faster, but the same goes for the coolant's ability to pull the heat away. This might not equate, but if you're too hot in the winter, wear a thinner coat.
| Not Ranked : 0 score I just realized your in Charlotte nc. I'm in Raleigh nc. Small world lol. The speed community is growing here, hell the car scene in general is becoming a thing here. |
![]() Join Date: Apr 2013 Location: wi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Can someone update the pics or repost them.?
__________________ 2008.5 gtx fmic dm pd Manley |
![]() Join Date: Sep 2019
Rep Power: 0 ![]() Thanks: 0
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| The OP hasn't been on the forum since February 2018. You can try PMing him to see if he'll update the photos. Nobody else has them though.
![]() Join Date: Mar 2019 Location: Mississauga, Ontario, Canada
| Not Ranked : 0 score Here's a Google Drive link to a folder for this thread, in case the photos go down again. |
| torque specs for engine on ms6 | dkfung88 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 01-24-2014 05:18 PM |
| Report: Alfa Romeo 4C specs and performance data leak via dealer brochure | Haltech | Automotive News | 0 | 08-27-2013 08:30 AM |
| Engine Stand Bolt Specs | Airman3454 | Gen2 MS3 General Discussion | 6 | 07-07-2013 05:47 PM |
| Engine specs | viper1b2 | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 05-09-2011 06:14 PM |
| MS3,MZ3, MZ5 Engine Mount Torq Specs | Grumpyjap | MazdaSpeed 3 - Engine, Transmission & Driveline | 0 | 04-05-2011 02:47 PM |
