> 2010 MS3 - Torque Specs & information
Like Tree4Likes
  • 2 Post By HOCKEYNUBE
  • 1 Post By Mylifeiseasy
  • 1 Post By 5hiftyy
 Old 10-18-2015, 07:25 PM   #1
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
Neutral  +2 score
Default All-Data engine TQ specs
So I took the time to pull a bunch of engine torque specs from all-data. Enjoy, and let me know if you need any more and I can try and dig them up!
HEAD
Loosening order:
(I personally recommend a few loosening steps)
Tightening order:
Step 1: 3-11 Nm (27-97 in-lbf)
Step 2: 13-17 Nm (116-150 in-lbf)
Step 3: 43-47 Nm (32-34 ft-lbf)
Step 4: 88°-92°
Step 5: 88°-92°
(for stock bolts only!)
CAM CAPS
Loosening order:
Tightening order:
Step 1: 5-9 Nm (45-79 in-lbf)
Step 2: 14-17 Nm (11-12 ft-lbf)
VALVE COVER
Loosening order:
Tightening order:
8-10 Nm (71-84 lb-in)
OIL PAN
Tightening order:
17-23 Nm (13-16 ft-lbf)
CRANK BOLT
Tightening:
Step 1: 96-104 Nm (71-76 ft-lbf)
Step 2: 87°-93°
TIMING COVER
Tightening order:
Bolts 1-18: 8-11 Nm (71-97 lb-in)
Bolts 19-22: 40-55 Nm (30-40 lb-ft)
WATER PUMP
Tightening:
Bolts 1: 17-23 Nm (13-16 lb-ft)
Bolts 2: 8-11 Nm (71-97 lb-in)
REAR MAIN SEAL
Tightening order:
EXHAUST MANIFOLD
Tightening order:
43-64 Nm (32-47 lb-ft)
OIL PUMP
Tightening order:
Step 1: 8-12 Nm (71-106 in-lbf)
Step 2: 17-23 Nm (13-16 ft-lbf)
CAM SPROCKETS
Tightening:
69-75 Nm (51-55 ft-lbf) (both sides)
THROTTLE BODY
Tightening order:
FLYWHEEL
Tightening order:
108-116 Nm (80-85 ft-lbf)
PRESSURE PLATE
Tightening order:
Tighten in a MINIMUM of 2 steps ending with 25-33 Nm (19-24 ft-lbf)
FUEL RAIL COVER
8-10 Nm (71-88 in-lbf)
THERMOSTAT
TIMING COMPNENTS
Bolts 1: 8-11 Nm (71-97 in-lbf)
Bolts 2: 20-30 Nm (15-22 ft-lbf)
HIGH PRESSURE FUEL PUMP
(the E8 bolts) 9-11 Nm (80-97 in-lbf)
PCV PLATE
POWER STEERING DUMBY PULLEY
19-25 Nm (15-18 ft-lbf)
IDLER PULLEY
INTAKE MANIFOLD
Bolts 1: 17-23 Nm (13-16 ft-lbf)
Bolts 2: 4-6 Nm (35-52 in-lbf)
FUEL RAIL
1. 17-23 Nm, 13-16 ft/lbs
2. 22-25 Nm, 17-18 ft/lbs
3. 24-35 Nm, 18-25 ft/lbs
4. 8-11 Nm, 71-97 in/lbs
5. 17-23 Nm, 13-16 ft/lbs
6. 16-24 Nm, 12-17 ft/lbs
FRONT HUB
1. 236-275 Nm, 175-202 ft/lbs
2. 82-101 Nm, 61-74 ft/lbs
3. 64-74 Nm, 48-54 ft/lbs
4. 43-60 Nm, 32-44 ft/lbs
5. 4-6 Nm, 36-53 in/lbs
6. 38-50 Nm, 29-36 ft/lbs
7. 44-58 Nm, 33-42 ft/lb
STARTER
1. 38-51 Nm, 29-37 ft/lbs
2. 38-51 Nm, 29-37 ft/lbs
3. 10-11 Nm, 89-97 in/lbs
ALTERNATOR
3. 8-10 Nm, 71-88 ft/lbs
4. 8-10 Nm, 71-88 ft/lbs
5. 10-14 Nm, 89-123 in/lbs
KNOCK SENSOR
1. 16-24 Nm, 12-17 ft/lbs
COIL PACKS
1. 6-9.5 Nm, 54-84 in/lbs
BLIND PLUG
1. 18-22 Nm, 14-16 ft/lbs
CRANK SENSOR
1. 5.5-7.5 Nm, 49-66 in/lbs
CAM SENSOR
I will be updating as I get suggestions or find more!
Mylifeiseasy and ms3gt08 like this.
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following 15 Users Say Thank You to HOCKEYNUBE For This Useful Post:
Dubcnea (04-16-2019), g00s3y (10-18-2015), Hush (11-05-2015), jdmage_mx5 (10-18-2015), Mattyhawk1 (01-09-2016), monkey.bones.007 (10-18-2015), MRR (04-09-2019), MS3Shadow (10-18-2015), sho (10-19-2015), Snyeed (10-19-2015), speed23 (10-18-2015), SpeedRebirth (11-05-2015), TJM216 (11-06-2015), tparker14 (10-18-2015), WAMBUSHHHH! (10-19-2015)
torque specs for engine on ms6 dkfung88 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-24-2014 05:18 PM
Report: Alfa Romeo 4C specs and performance data leak via dealer brochure Haltech Automotive News 0 08-27-2013 08:30 AM
Engine Stand Bolt Specs Airman3454 Gen2 MS3 General Discussion 6 07-07-2013 05:47 PM
Engine specs viper1b2 MazdaSpeed 3 - Engine, Transmission & Driveline 6 05-09-2011 06:14 PM
MS3,MZ3, MZ5 Engine Mount Torq Specs Grumpyjap MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-05-2011 02:47 PM
Page generated in 0.46399 seconds with 29 queries
