![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
(Thread Starter) | Neutral : -1 score
__________________ 2010 Velocity Red MS3 1979 280ZX |
![]() Join Date: Jan 2009 Location: NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 815
Groans: 46
| Not Ranked : 0 score Wrxified: I usually just got a 1/4 turn after its tight, no need to go tighter as you mentioned its an aluminum pan. Can I ask how much oil you added when you did your change? My 1st Gen used to take between 5.7 and 5.8 quarts. TIA! |
| The Following User Says Thank You to redblur For This Useful Post: | Wrxified (10-17-2009) |
| Lurkers
Posts: n/a
| there is a tq spec guide in here somewhere that will tell you everything you need to know |
(Thread Starter) | Not Ranked : 0 score Thanks. I think that's about what I used almost 6 quarts counting the oil filter. I was surprised that it took so much when I read the manual.
| The Following User Says Thank You to Wrxified For This Useful Post: | redblur (10-17-2009) |
Groans: 46
| Not Ranked : 0 score Thanks Wrxified! |
![]() Join Date: Oct 2008 Location: Frederick, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 913
30-41 N·m {3.1-4.1 kgf·m, 23-30 ft.lbf}
__________________ CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic. | |
| The Following 5 Users Say Thank You to PaPaSpeed For This Useful Post: | indianaryan (07-01-2010), makjur (04-27-2014), pinetar (05-05-2010), turbo test (10-15-2013), Wrxified (10-17-2009) |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score make sure u use the crush washer
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | MATT DAMOND (10-21-2009) |
![]() Join Date: Oct 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score are u guys using synthetic oil when changing it at home? |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Yes. Always run synthetic on a forced induction engine. |
(Thread Starter) | Not Ranked : 0 score Yep. I run Royal Purple 5w-30.
![]() Join Date: Jan 2010
| Not Ranked : 0 score . |
| The Following User Says NO Thank You to Mister T For This Un-useful Post: |
![]() Join Date: Jan 2010 Location: Miramar
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score yep full synthetic first oil change just perfomed at 1100 miles |
![]() Join Date: Jan 2009 Location: Lehigh Acres, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 824
| Not Ranked : 0 score tighten is a hard as you can. be sure to strip it. lol jk btw what's the oil filter type on the new speed3's?
__________________ [SIGPIC][/SIGPIC] |
![]() Join Date: Nov 2009 Location: Lacey, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,314
Groans: 48
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score It uses a cartridge oil filter.. i hope thats the answer you're looking for MB.. thats what they told me yesterday when i got it changed at the dealership.. Mobil 1 Syn..
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT |
| The Following User Says Thank You to Dre For This Useful Post: | miguelbates (01-20-2010) |
| Not Ranked : 0 score thank you! yes. i was just wondering if they still used that format of oil filter. thanks for the info.
__________________ [SIGPIC][/SIGPIC] Last edited by miguelbates; 01-20-2010 at 11:23 AM. |
| The Following User Says Thank You to miguelbates For This Useful Post: | Dre (01-21-2010) |
Groans: 48
| Not Ranked : 0 score NP bruh!
| Not Ranked : 0 score dre is your pic from overdrift?
Groans: 48
| Not Ranked : 0 score LOLOL.. you fail at movies.. its from the first Fast and the Furious.. Thats teh part where they're racing in the desert against the white kid with ADD in the Jetta.. "Too soon junior"... Then Michelle Rodriguez punches that one asian dood out.. God.. shes so hot.. i bet shes an absolute animal in the sack.. I even adore the semi-retarded looking eye she has..
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT Last edited by Dre; 01-22-2010 at 07:47 AM. |
![]() | | #19 | ![]() |
| Not Ranked : 0 score ROFLLLL dude have you even seen Overdrift? youtube it and you'll see why that pic reminds me of it. fucking hilarious! lol @ too soon junior.
![]() | | #20 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 798
Groans: 33
| Not Ranked : 0 score Dre, did you have to take the Mobil 1 to the dealer when they changed the oil? I got free oil changes with the purchase of my new car, however, the salesman said they put semi synthetic in it. So the question is do I need to bring my own oil or is the dealer oil ok?
__________________ 2010 Mazdaspeed 3 Tech - Sort of Fast some stuff 2008 Triumph Daytona 675 - Actually Fast GB Racing Slider Kit - DDM 35w 6000k HID - TechSpec Snakeskins |
![]() | | #21 | ![]() |
Groans: 48
| Not Ranked : 0 score they had the mobil 1 synthetic there.. but id be surprised if they gave you the synthetic for free.. and make sure you tell them synthetic.. the guy almost put regular oil in there.. then had the nerve to tell me to bring it back after 3k miles after he put synthetic in.. at least 5k miles for me between oil changes on this bad boy..
![]() | | #22 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score pretty sure they switched back to a normal spin on filter. someone with a gen2 ms3 verify this?
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #23 | ![]() |
Groans: 33
One other question, when did you guys do your first oil change? The dealer said to bring it in at 5000 miles, but I am not sure I feel comfortable with that. I have never let a brand new engine go much past 1000 miles without a change.
__________________ 2010 Mazdaspeed 3 Tech - Sort of Fast some stuff 2008 Triumph Daytona 675 - Actually Fast GB Racing Slider Kit - DDM 35w 6000k HID - TechSpec Snakeskins | |
![]() | | #24 | ![]() |
Groans: 48
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Dre - opt_ms3 is saying it's a spin on. You said the dealer told you it was a cartridge. They gave you the wrong info unless the cars sold in FL are different than what we're getting everywhere else. I've changed the oil 3x on my gen 2. It's a spin on oil filter like opt_ms3 stated.
![]() | | #26 | ![]() |
Groans: 48
| Not Ranked : 0 score wow.. id been had.. sorry opt..
![]() | | #27 | ![]() |
![]() Join Date: Nov 2009 Location: Newark, DE
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score Just changed the oil for the 2nd time today - in about 25 degrees (alright I was in the garage, but the door was open) - it uses the ph9566 in fram. Not sure about other filter makes, but def spin-on. I'm surprised by how "light" the engine feels again, much smoother. Thought I'd just been getting used to the car's power, but it definitely felt sluggish before the change (after 5k) compared to after. Maybe that fuel dilution problem? Used 5W-30 full synth mobil1 at 1500, then tried 0W-30 full synth mobil1 today. Anyone have any thoughts on the 0W-30? |
![]() | | #28 | ![]() |
The 0w means you have a thinner oil at start up temps so it's great oil for cars like yours and mine in the northern states during the winter months. Other than that it's still a 30 weight oil at normal engine temps.
__________________ 2010 Velocity Red MS3 1979 280ZX Last edited by Wrxified; 01-30-2010 at 06:37 AM. | |
| The Following User Says Thank You to Wrxified For This Useful Post: | cymrujmc (01-30-2010) |
![]() | | #29 | ![]() |
![]() Join Date: May 2010
I changed mine at 500 miles to castrol syntec 5W30. The oil that comes from the factory has all kinds of assembly lube and such in it so swapping it out before 5000 is a good idea | |
![]() | | #30 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score My dealer told me to do the first change at 1500 miles. I've only got about 200 right now, though. Just for future referrence, how difficult is this filter to access? I imagine it's not visible unless you're under the car or the answer to "spin-on vs. cartridge style" would not have even come up. Thanks. |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
![]() Join Date: May 2010 Location: GoldsBoro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 280
Groans: 106
Groaned at 53 Times in 41 Posts
![]() | | #33 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
![]() | | #34 | ![]() |
![]() | Not Ranked : 0 score |
| The Following User Says NO Thank You to wormfighter For This Un-useful Post: | wolly6973 (01-12-2011) |
![]() | | #35 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
Sent from my iPhone using lame ass Tapatalk
__________________ ![]() [SIGPIC][/SIGPIC] | |
![]() | | #36 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Hey guys, new to mazda's..... does anyone use Motul 8100 x-lite??? or any other motul brand, that's what I use to use in my two previous cars and it's actually a true synthetic..... |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
| Magnetiic Oil drain plug | Jarods7920 | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 08-20-2009 06:44 AM |
| Magnetic Drain Plug | KayWhy | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 04-11-2009 12:45 AM |
| Magnetic Drain Bolt. Yes or No? | desertrat | Mazdaspeed3/6 General Discussion | 14 | 10-09-2008 06:19 PM |
| Source of Battery Drain, Tire Valve Cap, Replacing A Brake Light: Mike Allen's Weekly Online Auto Clinic | Haltech | Automotive News | 0 | 09-19-2008 02:30 PM |
