> 2010 MS3 - Torque Specs & information
Like Tree23Likes
 Old 07-31-2011, 10:55 AM   #1
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
Default installing downpipe
ill be recieving tomorrow to tuesday the downpipe and wanted to know if i can do it with the ramps or should i got to a shop and have a lift what u suggest
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
The Following User Says Thank You to dr_banano For This Useful Post:
seby1992 (10-02-2013)
 Old 07-31-2011, 10:58 AM   #2
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
It's doable on ramps. That's how mine was done
The Following 3 Users Say Thank You to manelscout4life For This Useful Post:
rfinkle2 (08-01-2011), skeurton (07-31-2011), TexasSpeed3 (10-06-2011)
 Old 07-31-2011, 04:41 PM   #3
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
It's gonna take you a lot longer on ramps/stands, but it's doable. Be very patient. Give yourself 6-8 hours if this is your first DP install. Read as much HowTo guides as possible, and remember to be careful with the O2 sensors as they are very expensive to replace.
The Following 5 Users Say Thank You to adlpb For This Useful Post:
Broxer (09-01-2011), Monotonous ONE (08-01-2011), rfinkle2 (08-01-2011), skeurton (07-31-2011), TexasSpeed3 (10-06-2011)
 Old 07-31-2011, 05:05 PM   #4
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I did mine on jackstands last week. Not too bad. See if you can get a second set of hands, that would have made it cake for me. Get a ratcheting 14mm for the DP to turbo bolts when you reinstall it. Make sure you have several extensions and at least a swivel for your socket. Wear gloves.
Oh, and get a can or two of PB Blaster and start soaking that shit now.
403whp/451ft/lb Dry Shot
Last edited by Bucker; 07-31-2011 at 05:05 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to Bucker For This Useful Post:
 Old 07-31-2011, 05:11 PM   #5
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
The PB blaster is really key here. Mine took about 3.5 hours with bullshitting and it was dark. Make sure you dont overtighten where it butts up to the exhaust. Have some patience lining it up with the turbo from underneath the car, a second set of hands here really wouldnt suck.
I PB blasted mine the night before, morning of, and 1 hour prior to installation. I also did it when the motor was warm, makes the o2 sensors come out a bit easier. The pb blaster will smoke a tad when the engine gets hot, dont be alarmed.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
The Following 2 Users Say Thank You to thatsmrgimp2u For This Useful Post:
BPASPEED (10-07-2011), skeurton (07-31-2011)
 Old 07-31-2011, 05:50 PM   #6
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
I installed a DP yesterday. First time for me and it took a good 7 hours...
- I did it with the car up on jack stands and it wasn't bad at all. Just make sure you do all the work you need to do topside before raising it.
- To reiterate what was already said, read as many how-to guides as you can find. I printed out 4 different ones. They were all relatively the same, except for a few steps here and there. So it allowed me to put together my own plan of attack.
- I ended up removing all the heat shields in the engine bay, which was honestly the most time consuming part for me. But by doing so, I was able to remove the 5 turbo nuts from the top.
- I had 10K miles on my car and the top O2 sensor and 5 turbo nuts came off like butter.
- The second O2 sensor was the only problem I ran into. It would not come out. I PB'd the shit out of it, took a blowtorch to it, but it just wouldn't budge. Thankfully, I bought new sensors for backup, just in case I fucked them up.
- When putting it all back together, check and re-check everything. I managed to miss tightening one of the TMIC hose clamps, but caught it during my re-check. I also always torque everything twice.
- Tools that saved my ass: 18" breaker bar + wobble extensions.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 2 Users Say Thank You to skeurton For This Useful Post:
BPASPEED (10-07-2011), uncorked11 (12-05-2011)
 Old 07-31-2011, 06:07 PM   #7
irishking03's Avatar
Posts: 2,136   (View Stats)
Probably easier to do on the lift..
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
The Following User Says Thank You to irishking03 For This Useful Post:
 Old 07-31-2011, 06:10 PM   #8
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
@skeurton. Where did you buy the post cat sensor? Decent price? I'm doing my dp install sometime this week.
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
 Old 07-31-2011, 06:26 PM   #9
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
I did it with JBarone and it was a first for both of us. It took about 3.5 hours.
The two tips I have are:
1)take lots of time with the 02 sensor, douse that shit in pb blaster and just keep working it back and fourth super slow... I made us spend about 20 minutes going back and fourth to make sure that I didn't have to buy a new one... However I had to apply tons of force for the first jolt... we actually broke the first o2 socket!... Which leads me to the second and most important tip
2) Get as much off as you can easily, then, turn the car on and let that shit idle for a good 5-10 minutes so everything gets super hot, then proceed with all the hard to loosen shit... This made everything SO MUCH easier for us.
... we did it on jack stands.
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
bertrand_CX_7 (08-04-2011), BPASPEED (10-07-2011), rfinkle2 (08-01-2011), skeurton (07-31-2011)
 Old 07-31-2011, 06:28 PM   #10
skeurton's Avatar
Originally Posted by warlord View Post
Where did you buy the post cat sensor? Decent price? I'm doing my dp on Wednesday.
I got an OEM one from onlinemazdaparts.com for $138. Part number is L34B-18-861B. But you can get a Bosch or NGK post-cat sensor for cheaper. It was just easier to order both sensors at the same time. If you need a primary O2 sensor, unfortunately OEM is the only way to go and it costs $300. Since I was able to re-use the primary sensor, I'll probably sell the one I bought.
Here are the part numbers for NGK and Bosch:
NGK - 24442 (rockauto.com has these for $91 - LINK)
Bosch - 13581 (Amazon has these for $76)
Amazon.com: Bosch 13581 Oxygen Sensor, OE Type Fitment: AutomotiveAmazon.com: Bosch 13581 Oxygen Sensor, OE Type Fitment: Automotive
2011 MAZDASPEED 3
BPASPEED (10-07-2011), turbo test (07-31-2011)
 Old 07-31-2011, 06:37 PM   #11
warlord's Avatar
Great info! Since my car is three months old I'm hoping the sensors come out easy. If not I now know where to get them. Thanks.
2014 IS350 (sold)
 Old 07-31-2011, 06:41 PM   #12
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
subbed for good info.
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 07-31-2011, 06:43 PM   #13
Groans: 134
LOL, you would think so huh, but age seems to have nothing to do with it... hell (granted it was on an aftermarket down pipe), but we hand twisted jwilkins88 o2 sensors off last week!
And my car didn't have that many miles, but it was a bitch to get them out
and bewsted without many miles had his rear cross threaded from the factory!
 Old 07-31-2011, 06:56 PM   #14
warlord's Avatar
Well I'm prepared, I've got two cans of PB, a torch, big ass breaker bar, swivel extensions, a heavy walled 02 socket from NAPA, your suggestion and the mind set that this bitch won't win. I will. LOL I'll probably do like you said: Bust loose what ever I can from the top and bottom. Whatever doesn't budge I'll warm up the car and then work on them till they do get loose.
How did you guys keep the o2 wires from laying on the new downpipe? The oem heatshield has those clips that keep the wires from laying up against the hot dp.
2014 IS350 (sold)
The Following 3 Users Say Thank You to warlord For This Useful Post:
rfinkle2 (08-01-2011), SLOWHATCH (08-02-2011), TexasSpeed3 (10-06-2011)
 Old 07-31-2011, 08:02 PM   #15
Bucker's Avatar
Groans: 451
OH! Also, I used an adjustable wrench to remove the second o2, my o2 socket flexed from too much torque so I said fuck it and used something better. That did the trick.
 Old 07-31-2011, 08:47 PM   #16
warlord's Avatar
Is this enough selection for the o2 sensor?
bertrand_CX_7 likes this.
2014 IS350 (sold)
The Following 4 Users Say Thank You to warlord For This Useful Post:
bertrand_CX_7 (08-27-2011), BPASPEED (10-07-2011), skeurton (07-31-2011), SLOWHATCH (08-02-2011)
 Old 07-31-2011, 08:49 PM   #17
skeurton's Avatar
sledge hammer for stress relief if you can't get it out???
2011 MAZDASPEED 3
 Old 07-31-2011, 08:58 PM   #18
warlord's Avatar
"The persuader".
2014 IS350 (sold)
rfinkle2 (08-01-2011), SLOWHATCH (08-02-2011), TexasSpeed3 (10-06-2011), zpele (08-26-2011)
 Old 07-31-2011, 09:04 PM   #19
Bucker's Avatar
Groans: 451
LOL I was going to say... I wouldn't use the hammer on the sensor. Oh, another point... I pried the stocker off because I couldn't get it over the bottom left turbo stud... I know I could have removed the stud but that seemed like too much effort when I have a 30" screwdriver I have been itching to use.
 Old 07-31-2011, 09:44 PM   #20
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
I have my pipe in the garage waiting to go in this week ill let you know how it goes too thanks for the PB tips im gonna start it now Lol
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
 Old 08-01-2011, 06:26 AM   #21
dr_banano's Avatar
[QUOTE=How did you guys keep the o2 wires from laying on the new downpipe? The oem heatshield has those clips that keep the wires from laying up against the hot dp.[/QUOTE]
yeah what about it???
Dr_banano
 Old 08-01-2011, 06:30 AM   #22
skeurton's Avatar
I was able to run it behind the foil heat shield that's against the firewall...
File Type: jpg 205899_2261991393640_1364122874_2604833_5199428_n.jpg (52.3 KB, 1470 views)
2011 MAZDASPEED 3
The Following 3 Users Say Thank You to skeurton For This Useful Post:
RedMS3 (04-27-2014), rfinkle2 (08-01-2011), warlord (08-02-2011)
 Old 08-01-2011, 10:20 AM   #23
dr_banano's Avatar
whats that grey stuff on the bolt?
Dr_banano
 Old 08-01-2011, 10:22 AM   #24
krazycoble's Avatar
Posts: 662   (View Stats)
krazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the world
Probably anti-seize
Stratified Tuned 2011 MS3 | 410 HP - 402 TQ | Dynojet 10-21-12
krazycoble is offline   Reply With Quote
 Old 08-01-2011, 11:02 AM   #25
skeurton's Avatar
Originally Posted by krazycoble View Post
Probably anti-seize
Anti-seize is right. I went a little overboard with it. You should have seen the big cloud of smoke coming from the engine bay as it burned off when I first started the car.
Sent from my DROIDX using Tapatalk
2011 MAZDASPEED 3
The Following User Says Thank You to skeurton For This Useful Post:
 Old 08-01-2011, 11:12 AM   #26
dr_banano's Avatar
[QUOTE=skeurton;965230]Anti-seize is right. I went a little overboard with it. You should have seen the big cloud of smoke coming from the engine bay as it burned off when I first started the car.
Sent from my DROIDX using Tapatalk[/
should i aply that too??on the bolts??
Dr_banano
 Old 08-01-2011, 11:25 AM   #27
skeurton's Avatar
Yeah, in case you need to take them off again. Anti-seize will... well... help prevent the nuts from seizing up onto the studs over the long run.
2011 MAZDASPEED 3
 Old 08-01-2011, 11:26 AM   #28
skeurton's Avatar
Oh, and use anti-seize on the O2 sensors as well.
2011 MAZDASPEED 3
 Old 08-01-2011, 03:41 PM   #29
krazycoble's Avatar
I installed my downpipe 2 weekends ago and my car did the same thing lol. Yes, use some if you plan on taking it off one day.
The Following User Says Thank You to krazycoble For This Useful Post:
skeurton (08-11-2011)
 Old 08-01-2011, 05:01 PM   #30
wankular's Avatar
Posts: 4,343   (View Stats)
In anticipation of my dp install (when it cools off in a couple months) I pulled my 02 sensor and anti-seized it. The hardest part was threading it back in, the stupid wires kept twisting. I'm going to do the bottom one next time I'm under the car.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
rfinkle2 (08-02-2011)
 Old 08-01-2011, 08:35 PM   #31
dr_banano's Avatar
well just began today the intake is comingo on wendsday today i changed the plugs and sprayed wd40 on the bolts and the o2 senors planning on taking apart everything tomorow night so when i get the downpipe just begin isntallation going part by part taking my time better so i dont get frustated illl keep up with the install tomorrow
Dr_banano
 Old 08-01-2011, 09:29 PM   #32
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Use PB Blaster, WD40 is about as useful as water on those bolts...they are HARD SEIZED on there
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post:
skeurton (08-01-2011), TexasSpeed3 (10-06-2011)
 Old 08-02-2011, 08:13 AM   #33
Bucker's Avatar
Groans: 451
LOL WD40? Have you not read anything in here about how to remove it? You need something like PB Blaster to remove this shit.
 Old 08-02-2011, 09:25 AM   #34
dr_banano's Avatar
yeah i did but here i we dont get pb so i just have wd40 and the car is 4000 miles so i dont think they will be that hard ill be getting them today night after i give them a bit of heat
Dr_banano
 Old 08-02-2011, 09:28 AM   #35
adlpb's Avatar
Groans: 669
As posted before, how many miles you have doesn't really affect how tough it will be to remove the 02 sensors. I really suggest you order a couple cans of PB blaster online and wait to use them. WD-40 will not do anything. If you happen to cross thread the 02 sensors you're looking at at least $200 in parts and not being able to use your car until they arrive.
 Old 08-02-2011, 11:48 AM   #36
dr_banano's Avatar
weill the best i could find is this i think this is beter then wd40 and got the anti seize yeeey
Dr_banano
 Old 08-02-2011, 12:22 PM   #37
lax22pearl's Avatar
Posts: 186   (View Stats)
lax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond repute
figured this is a good question to post here but I got my dp installed by an exhaust shop and now both codes saying my sensors are bad are coming up. well have been there since I got my dp installed. well my question is that is there a way to test if they are actually bad or just need a defouler since I went catless
08 CWP MS3 GT -- CP-E Nano SRI-PG TIP-Turbosmart BPV-Ebay 3" catless DP-Cobb AP-TurboXS FMIC-KMD FP Internals-Medieval RMM-TWM STS-Redline Goods Shift/E-Brake boot and armrest cover-BC Coilovers-Advan SA3R 18x9.5 +22-Federal595 215/35/18
lax22pearl is offline   Reply With Quote
 Old 08-02-2011, 12:26 PM   #38
adlpb's Avatar
Groans: 669
Most catless DP's will give you CEL's on a gen2. You have to live with it or get used to clearing the codes with your AP. Even CS advertises on their website that their catted DP will throw a CEL. UR revised theirs to fix the CEL issue, but some say it still happens.
 Old 08-02-2011, 12:27 PM   #39
wankular's Avatar
I think you do need a defouler on the bottom 02 sensor of an ebay dp. It was discussed on one of the ebay dp threads.
2009 MS3 sport MGM
 Old 08-02-2011, 12:43 PM   #40
mglavina's Avatar
Posts: 33   (View Stats)
mglavina is a jewel in the roughmglavina is a jewel in the roughmglavina is a jewel in the rough
ebay downpipe thread? Anyone have a link for that?
My ebay DP should be arriving soon and I wanted to see the issues I may run into with installation, sensors, fitments, CEL's, ect...
2006 Black Mica Mazdaspeed 6 GT
Autotech HPFP internals, M2 3" Catless Downpipe (+ bnoon bolt), 3" Cp-e Catback Exhaust, Corksport exhaust hangers, Forge BPV, Cobb SF SRI, Cobb TIP, Cobb AP: Stage 2 + SF + TIH 93, Denso ITV-22's, BC Coilovers BR Type, Mishimoto OCC
To install: CX Racing 29x9x3 intercooler + custom FMIC, TurbineTech rear diff mount, defrost vent pod gauge + other goodies
mglavina is offline   Reply With Quote
need hlp after installing SU BPV camdensms6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-02-2009 02:54 PM
help on installing MBC tburton101 MazdaSpeed 3 - How-To's 1 08-27-2009 02:35 PM
Page generated in 0.63400 seconds with 36 queries
