> 2010 MS3 - Torque Specs & information
Like Tree5Likes
 Old 02-16-2013, 10:16 PM   #41
qweedqwag's Avatar
Posts: 233   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
Book in my car says 78 foot lbs.
qweedqwag is offline   Reply With Quote
 Old 03-05-2013, 07:16 PM   #42
Illusion's Avatar
Posts: 123   (View Stats)
Illusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant future
Groaned at 34 Times in 12 Posts
i beleive the tq specs are 85
78-85 you should be fine
Illusion is offline   Reply With Quote
 Old 03-07-2013, 09:22 PM   #43
qweedqwag's Avatar
Read you manual Brownie.
 Old 05-29-2013, 09:21 AM   #44
90210's Avatar
Posts: 271   (View Stats)
90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world
Originally Posted by Goose View Post
Speaking as an engineer, the torque spec (+/- 20lb/ft) in the manual is pretty useless. The good thing about such specs is that there's plenty of "slop" designed-in. I wouldn't exceed the spec'd range, though (such as 90 lb/ft) since you risk over-stretching the stud and possibly causing deflection of the brake disk.
For what it's worth, I checked my lugs and found that they were torqued to 80 lb/ft. I have no idea if the factory or the port or the dealer set them, but they're within the specified range. 80 is a nice round number, so I'm sticking with it.
Hope this helps...
How often do you guys check it ?
First time I did rotation within a week front was loose. With help of this forum figured it out
Did the front brakes with help of friend from here . We did 85 lb.
4 weeks now front loose again !!!!
90210 is offline   Reply With Quote
The Following User Says Thank You to 90210 For This Useful Post:
lilred (05-29-2013)
 Old 05-29-2013, 02:39 PM   #45
supertubesocks's Avatar
Posts: 404   (View Stats)
supertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the world
I've never used a torque wrench on lug nuts. That's for women.
Sent from my SPH-L900 using Tapatalk 2
supertubesocks is offline   Reply With Quote
The Following User Says NO Thank You to supertubesocks For This Un-useful Post:
SeeMeGovan (06-18-2013)
 Old 05-29-2013, 02:48 PM   #46
90210's Avatar
Look at my cars color. Y wud u asume I am a man
The Following 2 Users Say Thank You to 90210 For This Useful Post:
lilred (05-29-2013), SLOWHATCH (08-10-2013)
 Old 05-29-2013, 03:08 PM   #47
DTKII's Avatar
Posts: 247   (View Stats)
DTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the world
Fail, men have to use torque wrenches do they don't over tighten things.
Stay away from RD Motorsportz
DTKII is offline   Reply With Quote
The Following User Says Thank You to DTKII For This Useful Post:
 Old 05-29-2013, 11:40 PM   #48
I disagree, when it comes to lug nuts at least. It's best practice to use a torque wrench but for a street car proper lug wrench tightening is good enough.
 Old 05-30-2013, 04:17 AM   #49
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I have occasionally had a few become loose after 5k miles, which I noticed when rotating tires.
I have since upped my torque from 80 ft-lbs to 100 ft-lbs and so far it hasn't been an issue again.
rfinkle2 (09-12-2013)
 Old 06-18-2013, 12:33 AM   #50
intotheice's Avatar
Posts: 85   (View Stats)
intotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really niceintotheice is just really nice
65-87 ft-lbf recommended by the manual
intotheice is offline   Reply With Quote
 Old 06-18-2013, 12:42 AM   #51
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
My front left wheel almost fell off the other day driving about 40mph. I heard wub-wubs so I turned down the dubstep and I still heard wub-wubs so I pulled over. 3 of the 5 lugs were just finger tight. I carry a 150 ft-lb torque wrench and a 26" 1/2"-drive breaker bar in my car for dealing with lug nuts. Coulda been a bad day.
And I now use 85 instead of 80. I check all 4 wheels every 2 weeks or so since it only takes a few minutes. I have gorilla small diameter lugs if it matters.
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
The Following 2 Users Say Thank You to SeeMeGovan For This Useful Post:
kgb (01-31-2019), rfinkle2 (09-12-2013)
 Old 06-24-2013, 05:41 PM   #52
Zoomer1987's Avatar
Posts: 25   (View Stats)
Zoomer1987 has a spectacular aura aboutZoomer1987 has a spectacular aura about
We torque pretty much all mazdas to 87 at my work with a 25 mile retorque, works great, never had a wheel fall off or stripped studs
Zoomer1987 is offline   Reply With Quote
 Old 06-29-2013, 12:14 PM   #53
intotheice's Avatar
Time for brake warp
 Old 07-31-2013, 05:42 PM   #54
iammike's Avatar
Posts: 1,415   (View Stats)
75 for me, last I checked all 4 wheels were still on the car.
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
hsraffety (07-31-2013), rfinkle2 (09-12-2013)
 Old 07-31-2013, 07:03 PM   #55
hsraffety's Avatar
Posts: 106   (View Stats)
hsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud of
Well that's just great, iammike
2012 Crystal White Pearl Mazdaspeed3 - Cobb AccessPort // Cobb Short Ram Intake // Cobb Turbo Inlet Pipe // Autotech HPFP // Race Pipe // CP-E Stage 2 xFlex RMM // Hawk HPS Rotors and Pads
hsraffety is offline   Reply With Quote
 Old 07-31-2013, 07:45 PM   #56
iammike's Avatar
I know, right?
Mike
 Old 08-10-2013, 03:27 PM   #57
The Nut's Avatar
Posts: 1,571   (View Stats)
I have aftermarket wheels & lugs, been using 90 since I got them. No problems.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 09-12-2013, 07:07 AM   #58
markie277's Avatar
Posts: 4   (View Stats)
markie277 will become famous soon enough
at my dealer we torque to 90 on alloys and 100 on steels
markie277 is offline   Reply With Quote
The Following User Says NO Thank You to markie277 For This Un-useful Post:
KusteLokal (09-12-2013)
 Old 09-12-2013, 07:15 AM   #59
Cool story bro.
rfinkle2 (09-17-2013)
 Old 09-17-2013, 12:30 AM   #60
Livingframe's Avatar
Posts: 41   (View Stats)
Livingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the world
New to running offset plates. wanted to try a wider track to launch on factory tires. currently exiting 60' at 2.007-2.05. plan on trying the 5mm spacers I have on wed. I originally torqued in a cross pattern in 2 steps: 60, then 85. after reading some here I backed off to 75 on the stock studs. car has 5900mi on it. there is a small amount of anti seize on the threads. thoughts. anyone know what lugs I will need if I run an arp stud or can I stay with stock. thanks guys. Michael
Livingframe is offline   Reply With Quote
 Old 09-17-2013, 02:55 AM   #61
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Only a fucking moron would put anti seize on wheel studs.
Sent via blown passenger side speakers.
Pickles Tune in progress
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
SeeMeGovan (09-17-2013), WetzMS3 (07-25-2014)
 Old 09-17-2013, 03:20 AM   #62
The Nut's Avatar
Yeah. Everybody knows you should use red Loctite.
 Old 09-17-2013, 03:37 AM   #63
SeeMeGovan's Avatar
Don't do that. Get a $12 breaker bar from harbor freight.
Crappatalking on my big-ass phone.
NATOR-WA 'GOVAN'
 Old 09-17-2013, 06:12 AM   #64
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I must be a fucking moron then.
Antiseize on lug nuts is a much debated topic. I'm all for it, never given me a problem. I've had OEM studs break under normal use (on my speed an on other cars), especially if the wheels are coming off often. Until actual empirical evidence says its dangerous I'll continue to use it (anecdotes need not apply).
Blue Pu.
 Old 09-17-2013, 09:33 AM   #65
^ you can answer the question if you're obliged and you might be surprised to know I've been smart a few couple times in my life too. I read a sticky thread on the subject so any addtional thoughts would be helpful. thanks
SDG:Racing/Intertune Tv - Videographer/Driver
2013 MS3: 1.954 12.943@108.94 full weight, factory tire on 93 octane. modded intake and updated mid pipe only changes since 12.988.
Best 60' - 1.91 on factory 2050 tire, Best MPH - 110.35 @ ENM '14
AT LEAST +10WHP OVER STOCK SETTING FROM SPARK PLUG MOD EXPLAINED: https://vimeo.com/85412223 reserve your set!
 Old 09-17-2013, 09:40 AM   #66
someguy's Avatar
Posts: 914   (View Stats)
Anti-seize will change the torque spec...don't use it on lugs
 Old 09-17-2013, 10:00 AM   #67
himurax13's Avatar
Groans: 255
It appears that way. Its your life and your car.
Zero Fucks Given either way.
 Old 09-17-2013, 10:20 AM   #68
anavrinIV's Avatar
Groans: 63
so will corrosion, thread deformation and dirt. Those are hard to avoid.
When my wheels fall off from usin antiseize on the studs I'll let you guys know and admit defeat. I'm not trying to convince anyone of anything, just offering the other side of the coin on this argument. I also run 5mm spacers which some people believe is dangerous, but at the same time I have extended ARP studs for lots of threading on the lug nuts. Lots of variables.
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
Easter Bunny (09-17-2013), rfinkle2 (09-17-2013)
 Old 09-17-2013, 11:00 AM   #69
himurax13's Avatar
Groans: 255
They are dangerous with the oem studs/lugs. I was running the JBR 5mm spacers with the oem studs/lugs at 100 lbs of torque and I still ended up ejecting 4 lugnuts from my front passenger wheel in a month. Needless to say, I am not running spacers anymore.
Why would you add anti seize to a load bearing thread? To allow it to unthread easier? To add a variable to contribute to fail?
rfinkle2 (09-17-2013), [R]usty (09-17-2013)
 Old 09-17-2013, 11:16 AM   #70
[R]usty's Avatar
Posts: 2,204   (View Stats)
90-100 ft lbs on every car I've ever owned or worked on, never had any problems.
2010 Mazdaspeed3 w/tech
himurax13 (09-17-2013), rfinkle2 (09-17-2013)
 Old 09-17-2013, 11:34 AM   #71
anavrinIV's Avatar
Groans: 63
They are dangerous with the oem lugs.
I realize that, that's why I changed them. When I put my wheels on with the spacers there was not nearly enough thread engagement so I ordered new studs ASAP.
Anti-seize is, as the name implies, is used to keep metals from seizing. I understand that is is a lubricant to a degree but that is not its main purpose. And having taken my wheels off a few times since putting the AS on there I feel no change in threading the lug nuts on....on the OEM studs they are all different and feel more resistant. I feel more confident in the torque spec on the AS lugs than I do on the OEMs
Blue Pu.
 Old 07-25-2014, 09:50 AM   #72
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
I know this is an old thread but there is a ton of bad information.
Anti seize changes the torque on the surfaces it's in contact with. You will never get the proper torque numbers, it reduces the space between the stud and fastener. If you care about the proper torque don't use it, if you care about ease of fastener removal than use it but you can't have both. Sometimes the manufacturer will use and recommend, they've accounted how it changes the torque.
The main reason you torque your wheels besides keeping them on the car, is prevent your wheels and brakes from distorting or warping. Over torque a lug it will cause your rotors to warp.
They make torque sticks for impacts that restrict how much torque the impact is putting on the fastener. We used them at honda but I still double checked them with my torque wrench.
If the manual or manufacturer calls for a certain torque and you still have oem parts, that's what it needs to be.
tmillner is offline   Reply With Quote
The Following User Says Thank You to tmillner For This Useful Post:
CWP_MS3 (11-25-2014)
The Following User Says NO Thank You to tmillner For This Un-useful Post:
Easter Bunny (07-26-2014)
 Old 11-23-2016, 07:59 AM   #73
lethalhazard's Avatar
Posts: 39   (View Stats)
lethalhazard has a spectacular aura aboutlethalhazard has a spectacular aura about
a
lethalhazard is offline   Reply With Quote
 Old 11-23-2016, 08:10 AM   #74
Originally Posted by lethalhazard View Post
2006 Mazdaspeed 6 "Owners Manual"
Ch. 7 In Case of an Emergency
Look under "Flat Tire"
Ch. 7-9
-Nut Tightening Torque-
Nm (kgfm, ft lbf)
88-118 (9-12, 65-87)
bruh.
 Old 11-23-2016, 08:17 AM   #75
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
i hope the dude from 2013 didn't wait until now to install the wheels...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
The Following 2 Users Say Thank You to Jeff23spl For This Useful Post:
KiwiFlavor (11-23-2016), WetzMS3 (11-23-2016)
 Old 11-23-2016, 08:20 AM   #76
2 years is an long time to wait for answer, so you can install your wheels.
 Old 11-23-2016, 08:26 AM   #77
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Ch. 7-9
Nm (kgfm, ft lbf)
Nice first post breh
2012 NASA Spaceship Gray MS3
 Old 11-23-2016, 08:47 AM   #78
How many uggga dugggga's is 85 ft/lbs?
 Old 11-23-2016, 08:51 AM   #79
KiwiFlavor's Avatar
Tree fiddy
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f435/lug-nut-torque-specs-54736/
Axel nut ProbeTalk com Forums This thread Refback 08-04-2014 05:25 PM
Thee NYPOC Lounge - Page 191 - ProbeTalk.com Forums This thread Refback 04-18-2011 10:16 AM
Torque specs DV8 MazdaSpeed 3/6 - Wheels & Tires 7 04-14-2010 12:29 AM
Torque specs for bolts on OEM midpipe? 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 1 03-09-2010 11:43 AM
Page generated in 0.58839 seconds with 44 queries
