> 2010 MS3 - Torque Specs & information
 Old 02-15-2011, 11:49 PM   #1
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Default Starting Car with Push Button
Ok, so I have my flame suit on for this one but I have been wondering about this and have not found anything relating to this question I have. Every other car I have owned has been a key start type. So turn the key to the acc and power, let fuel pump prime and then start the car. Seems to me that is the best way to go about it.
However, with the keyless start button, you can just push in the clutch and push the button and fire it right up.
So is it better to go through the cycles before starting the car to prime the FP, or can I just go straight to starting the car?
BTW, was not sure where to post this, so I apoligize if its in wrong section.
 Old 02-16-2011, 01:42 AM   #2
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
Just start the car...
Your brain is getting in the way
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline   Reply With Quote
The Following 2 Users Say Thank You to ebnash For This Useful Post:
jax ms3gt (02-16-2011), pipe (02-16-2011)
 Old 02-16-2011, 03:06 AM   #3
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
Just push the button. Pretty much every new car has push button now and they did research. If it was an issue you would have heard about it.
Also- I've never done the "prime" thing on any car I've ever driven even with a key and I've never had an issue
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
The Following User Says Thank You to Aetherfury For This Useful Post:
redblur (02-18-2011)
 Old 02-16-2011, 03:15 AM   #4
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Aethur...you never prime the fuel pump???
DUDE YOUR GONNA FUCKING BLOW YUR STI BROAH
The Following 5 Users Say Thank You to Monotonous ONE For This Useful Post:
Aetherfury (02-16-2011), ledfootrob (10-12-2012), pipe (02-16-2011), PunjabiPlaya (02-16-2011), snailD (02-16-2011)
 Old 02-16-2011, 09:16 AM   #5
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
hahahah, not sure why but i just busted out laughing really hard in my office.
 Old 02-16-2011, 09:46 AM   #6
Aetherfury's Avatar
I know why, Monotonous has had a string of good shit lately. He had one comment on my STi thread I literally almost crapped myself at work. My co-workers thought/still think I was/am insane.
dizzydtrain (02-16-2011)
 Old 02-16-2011, 05:00 AM   #7
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Neutral  :  -1 score
you only really need to prime the fuel pump after youve done things like replace the pump or disconnected lines and drained the fuel.
If you need to do this, hold the clutch and gas pedal al the way down while youre starting the car. This will let the motor turn over (priming the pump) but it wont let it start.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
The Following User Says Thank You to Blackspeed For This Useful Post:
Teal (02-16-2011)
 Old 02-16-2011, 09:52 AM   #8
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Unless you are starting the car for the first time after installing a new fuel pump, you can just start the car.
 Old 02-16-2011, 09:55 AM   #9
ahskeetz's Avatar
Posts: 431   (View Stats)
ahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the world
Groaned at 7 Times in 5 Posts
I thought this thread was gonna lead to how to manually start a car by rolling it down the hill and dumping the clutch in 1st gear with the PUSH button.
2010 Black Mica MS3 |CP-E Nano.TIP.TMIC.RMM|1G DSM BPV|UR DP.TP|H&R springs|eBay camber arms|ITV-22|Ford XT-M5-QS|Sure Shortcut|PG shift weight|JBR Bushings|Maisonvi Chode Knob|MD OCC|Cobb AP tuned by me
2013 Kawasaki Ninja 300|15T sprocket|Yoshimura R77 full system| Area-P Tune
ahskeetz is offline   Reply With Quote
The Following User Says Thank You to ahskeetz For This Useful Post:
snailD (02-16-2011)
 Old 02-16-2011, 12:17 PM   #10
SLOWHATCH's Avatar
Groans: 274
Lol, I figured someone would have thought this was going to be a tutorial on "how to start" your car. Surprised it came so late lol.
Thanks everyone for your responses and minimal flamming. You guys are alright.
 Old 02-16-2011, 12:23 PM   #11
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
I always do it, just a habit. Just like i let the car idle 30sec before i shut it off.
 Old 02-16-2011, 01:51 PM   #12
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Prime the fuel pump is like for a carburetor injected car. Like Old School Shit.
Plus it literally takes 0.25 seconds for the pressure to come up according to the logs I take with the standalone.
 Old 02-16-2011, 03:32 PM   #13
kmac's Avatar
Posts: 1,792   (View Stats)
You should always prime your car by turning the key to acc for a few seconds, get out ( with the key in the acc position still ) , open your gas door , remove the cap , insert penis and give 3 good hard pumps , re-enter the car and start if it gives u trouble repeat steps 1 - 6 . That's what I do and it hasn't failed me yet.
 Old 02-16-2011, 03:37 PM   #14
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
I was gonna come in here to tell him to make sure the slider is on choke before starting, but w/e. lol.
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following User Says Thank You to PunjabiPlaya For This Useful Post:
Blackspeed (02-22-2011)
Ipod install Through the AUX button zpele MazdaSpeed 6 - How-To's 1 01-11-2011 08:44 PM
No Reply Button? fjames Website Help/Feedback 15 02-13-2010 07:15 PM
CD Pause Button gfather MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 09-26-2009 11:13 PM
top button phillyb Website Help/Feedback 3 01-04-2009 12:28 AM
Page generated in 0.33512 seconds with 31 queries
