 Old 05-11-2015, 09:17 PM   #1
Delgado60's Avatar
Posts: 13   (View Stats)
Delgado60 will become famous soon enoughDelgado60 will become famous soon enough
Exclamation Another ac issue
hey guys i've read over a few of the AC issue threads and still cant seam to find an answer. My ac is blowing warm air and when i have it on full blast i went tho see if the compressor clutch was even engaging and nothing. I dont have a FMIC so im prayingi dont have a leak. Any suggestions or ideas? I allready tries to replace the AC relay under the hood with a duralast one from autozone and it did nothing. I'm running out of ideas, any help is appreciated!
celestial blue FTW!!!!
Delgado60 is offline   Reply With Quote
 Old 08-05-2015, 11:43 AM   #2
AgentWh0's Avatar
Posts: 5   (View Stats)
AgentWh0 is an unknown quantity at this point
Have you tested the system for pressure in the A/C lines? Maybe you do have a leak and there is no more 134a in the A/C lines.
2010 Mica Black Mazdaspeed3
BNR S3
JBR Tru-3.5 Wide Path Aluminum intake
Cobb 3-Port Boost Control Solenoid
Ultimate Racing Catted Downpipe
Ultimate Racing TestPipe
Street Unit Top Mount Inter-cooler
JBR Cold and Hot side Boost Tubes
1 step colder plugs gapped .28 - NGK
Corksport MZR BPV
JamesBaronRacing Oil Catch Can
Cobb Access Port
Cobb rear motor mount
JamesBaronRacing Transmission and passenger motor mounts
JamesBaronRacing RearSwayBar
Running Custom Self tune @ 18PSI
AgentWh0 is offline   Reply With Quote
BCM + SRS Issue Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 2 07-23-2013 10:54 AM
AC issue MS3KO MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 07-31-2011 11:16 PM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 09:12 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
AWD issue caseygt2 MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-14-2010 02:38 PM
Page generated in 0.24560 seconds with 21 queries
