Like Tree7Likes
  • 2 Post By SofaKingAwesome
  • 1 Post By Shwa
  • 1 Post By SofaKingAwesome
  • 1 Post By rfinkle2
  • 1 Post By NCspecV81
  • 1 Post By Djohns
 Old 12-11-2015, 06:53 AM   #1
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Default Battery Terminal Fuse Melted
FYI: I have the @CorkSport battery box
Driving to work this morning I turned my heater on to be hit with the smell of burning plastic. I looked under to hood to see smoke/fumes coming from between the harness for the ECU and my positive battery terminal fuse. Upon closer look it seems that the fuse has turned brownish black and the wire below it is was starting to melt the connector handle that plugs into the ECU. I've been looking everywhere to fine a replacement for this part:
Please help. =[
V/R
2012 Mazdaspeed3 Black Mica
 Old 12-11-2015, 06:55 AM   #2
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
This is a known issue, I'll post up the link at my desktop shortly, if someone hasn't already by the time I get there.
Cujo and monkey.bones.007 like this.
Cujo (12-11-2015)
 Old 12-11-2015, 07:07 AM   #3
Shwa's Avatar
Posts: 322   (View Stats)
Don't have a link unfortunately, but I went thru the dealer when mine was fried. Described it and they had it stocked
Cujo likes this.
The Following User Says Thank You to Shwa For This Useful Post:
Cujo (12-11-2015)
 Old 12-11-2015, 07:46 AM   #4
COCKSTRONG
Groans: 890
WTF!!! My car almost caught on fire!!
Cujo likes this.
The Following 3 Users Say Thank You to SofaKingAwesome For This Useful Post:
CorkSport (12-11-2015), Cujo (12-11-2015), WAMBUSHHHH! (12-29-2015)
 Old 12-12-2015, 07:58 AM   #5
Cujo's Avatar
I went to disconnect the battery this morning and found this... fml. And way to fix this w/o getting a whole new harness?
 Old 12-29-2015, 08:07 AM   #6
Cujo's Avatar
Update:
Ordered new terminal ($25)
Trimmed back the burned end and some of the plastic
Used Coke to clean off the corrosion (to my surprise the wire was fine excluding the charred part)
At first I tried to crimp on a 8 gauge connector being everyone and their mother said it was the size of the wire used. Turns out the 8 gauge cap was too small and I had to go with a 6 gauge one which fit perfectly.
Hooked everything back up and the car starts perfectly. I'm monitoring everything to make sure it doesn't happen again but trying to fit the stock battery in the original @CorkSport; battery box is a tight fit and a PITA to keep taking the battery in and out of.
TL;DR the wire was fine, use 6 gauge not 8 gauge connector, car still runs.
The Following User Says Thank You to Cujo For This Useful Post:
SofaKingAwesome (12-29-2015)
 Old 12-29-2015, 08:39 AM   #7
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
So I'm probably lacking in the reading department but what is the cause of this "common" problem? Just wondering if there is something we should do to prevent it from happening.
 Old 12-29-2015, 08:46 AM   #8
Yatta's Avatar
Posts: 1,862   (View Stats)
I’ve read through this and the previous thread, it has happened to folks that have (re)moved their batteries; both using and not using ECU/battery relocation kits; I have yet to see a definitive, but it looks like improper reconnection of the two wires (the nut/ring connector) might lead to arcing/excessive heat... some dielectric grease and proper torque on the nuts might go a long way to preventing this. Much like the Gen2 spoiler, check your nuts.
 Old 12-29-2015, 08:47 AM   #9
Djohns's Avatar
Posts: 3,944   (View Stats)
Well this isn't reassuring seeing as how I just got their battery box.... I'd prefer if nothing melted
2010 black mica speed3
Soon:built motor
 Old 12-29-2015, 08:48 AM   #10
Yatta's Avatar
I don’t think it has anything to do with the box per se, it has a lot to do with what is needed to install the box (or an intake).
 Old 12-29-2015, 08:54 AM   #11
Djohns's Avatar
Can you elaborate on that one a little? I bought the box because I plan to run a 3.5" intake
Soon:built motor
 Old 12-29-2015, 11:58 AM   #12
Yatta's Avatar
so the positive terminal has two posts on it with nuts, I think the big issue here is that they are somehow getting loose; the wiring is already on the smallish side for what could go through it, a poor connection is just going to draw more through less (which equals heat).... I have yet to see where anyone has explained what caused the problem... and some with exactly the same configuration have had no issue at all.... the ECU case isn’t shorting the terminal (its plastic on that side) and it always seems to start on positive post.
I am working/planning on doing an ultra capacitor/small mower AGM battery conversion on mine, so will be watching this but I don’t believe its the box causing it; much like replacement of HPFP doesn’t cause hardline failure (unless damage is done to the hardline ).
At least you caught it before this
How I fixed mine. Like @rfinkle2; said. I used a 150amp circuit breaker and some terminals that aren't a fire waiting to happen.
that is beautiful. I especially like that meth tank, looks familiar.
Last edited by Yatta; 12-29-2015 at 12:01 PM. Reason: MSF Database - Automerged Doublepost
NCspecV81 (12-29-2015)
 Old 12-29-2015, 09:05 AM   #13
You can replace that fuse with a 12v circuit breaker (like those used in high end / high power audio builds)
blackms3_71 likes this.
Mauro_Penguin (12-29-2015), NCspecV81 (12-29-2015)
 Old 12-29-2015, 09:52 AM   #14
NCspecV81's Avatar
Posts: 2,867   (View Stats)
2013 CWP and Stock
RazoE (01-01-2016)
 Old 12-29-2015, 09:56 AM   #15
Djohns's Avatar
That engine bay is absolutely beautiful. Well done.
Soon:built motor
 Old 12-29-2015, 03:12 PM   #16
Djohns's Avatar
Now that I see what you guys are talking about, I have that too. Still on stock battery box as of now. I should probably figure this out before I'm playing with fire.
Soon:built motor
 Old 12-29-2015, 04:17 PM   #17
Yatta's Avatar
@NCspecV81; how did you wire the breaker? the ‘stock’ config has two leads, each has a fuse link (that clearly isn’t doing its job some times) is there a bar or separate outputs? just curious as I would have to believe Mazda split them for a reason.. (good or bad).
 Old 12-29-2015, 06:17 PM   #18
NCspecV81's Avatar
I used an unfused distro of 2-4AWG in and 1-0AWG out. They technically aren't "split". The starter wire as a fusible-link while the fuse box does not and is joined downstream after the fusible-link. I chose to fuse them both for safety purposes. I didn't want anymore fires in my engine bay. Especially around pure meth.
2013 CWP and Stock
Djohns (12-29-2015), Yatta (12-29-2015)
 Old 12-29-2015, 09:25 PM   #19
Yatta's Avatar
This might be the best way anyhow, if something shorts well enough to pop a fusable link it should all be shut off... the two links out might be what is allowing a fire to start... again subjective/opinion but one hard link/cut might be best... I am considering a 16V/83F ultra capacitor fed by a 18 a/h lithium battery... I really don’t want that shorting out.... it will cut about 30 lbs from my front end and give me longer/better winter performance.. I hope.
 Old 12-29-2015, 05:00 PM   #20
Djohns's Avatar
I wonder if me being modded I can get this fixed under warranty. Probably not since it's a 2010. Only 40k miles though. Or if it's even a problem because it's been like that since I bought the car about 2 years ago. @NCspecV81; I'm also interested to hear how you did it because I'd like to avoid problems before they begin
Soon:built motor
 Old 12-29-2015, 07:19 PM   #21
Djohns's Avatar
I think I may end up going this route. It seems like a really good idea
Soon:built motor
 Old 12-29-2015, 10:01 PM   #22
NCspecV81's Avatar
If you go the route I did I went with a 150 amp breaker and works just fine.
2013 CWP and Stock
Djohns (12-29-2015)
 Old 12-29-2015, 10:24 PM   #23
Djohns's Avatar
I would love to know more about your setup. Did you by any chance make a thread of how you did it or anything like that?
Soon:built motor
 Old 12-29-2015, 10:57 PM   #24
NCspecV81's Avatar
Not really. It's pretty simple. A double 4awg in and single 0awg out (Ground distribution block so it's not fused) to 150amp stinger circuit breaker that feeds 0awg to knukonceptz positive battery terminal.
2013 CWP and Stock
Djohns (12-30-2015)
 Old 12-30-2015, 04:50 PM   #25
Djohns's Avatar
What distribution block did you use? I'm looking into this option now and seeing if I'll be able to make it work with the CS battery box.
Soon:built motor
 Old 12-30-2015, 05:52 PM   #26
NCspecV81's Avatar
I used a T-spec ground distribution block. I liked it b/c it was small, compact and to the point. You could go fancier if you wanted.
http://www.sonicelectronix.com/item_...12DB-1124.html
2013 CWP and Stock
Djohns (12-30-2015), monkey.bones.007 (12-30-2015)
 Old 12-30-2015, 06:35 PM   #27
Djohns's Avatar
Thanks man. You've been a huge help!
monkey.bones.007 likes this.
Soon:built motor
 Old 12-31-2015, 04:18 PM   #28
blackms3_71's Avatar
Posts: 2,250   (View Stats)
@NCspecV81; where did u get ur valve cover, cover? Coving the spark plug wires
 Old 12-31-2015, 04:39 PM   #29
Djohns's Avatar
Amazon has the exact same one for $27 with free shipping and its in stock
Soon:built motor
 Old 12-31-2015, 06:12 PM   #30
Thanks. I didnt look around.
 Old 12-31-2015, 08:52 PM   #31
Djohns's Avatar
No problem
Soon:built motor
 Old 03-30-2018, 08:29 AM   #32
MJA-09MS3's Avatar
Posts: 5   (View Stats)
MJA-09MS3 has a little shameless behaviour in the past
Im having the same issues. what do i need to do to fix this
MJA-09MS3 is offline   Reply With Quote
The Following User Says NO Thank You to MJA-09MS3 For This Un-useful Post:
Vansquish (03-30-2018)
 Old 03-30-2018, 09:19 AM   #33
Djohns's Avatar
Two options. #1 read this thread and fix it yourself without being spoon fed, or #2 let it happen, since it’s possible that will be the best thing to happen to your speed.
Soon:built motor
 Old 03-30-2018, 11:05 AM   #34
Police - Grammarhead
Vansquish's Avatar
C'mon man. I spoon fed you a thread with the same issue in it, as well as a SOLUTION. If you can't be bothered to fucking read it. There's no way to help you.
The Following 4 Users Say Thank You to Vansquish For This Useful Post:
Db09ms3 (03-30-2018), Djohns (03-30-2018), JSmith (03-31-2018), Thor Hammer (03-30-2018)
 Old 03-30-2018, 09:07 AM   #35
shamie's Avatar
Posts: 952   (View Stats)
Did you read all of this thread?
Disconnect that (fusible link) from the battery and check to see if there is continuity through it. If there is no continuity the FL is blown and you will need to cut it off and replace it with another fuse or circuit breaker.
The Following User Says Thank You to shamie For This Useful Post:
 Old 09-19-2019, 12:13 AM   #36
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
My battery terminal has the same issue. White wire burning up but the fuse link isn't blown. Stock setup, so strange wish I knew how to prevent such issue. Will try fixing it with the above method.
2012 Black Mica Speed 3
300whp-341wtq tuned by John @ Tork Motorsports (2/4/14)
Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC
Mazdaspeed3KHP is offline   Reply With Quote
help....melted cable off of battery RACER_X Gen2 MS3 General Discussion 45 08-01-2015 08:56 AM
Has your Dashboard Melted? SpencerC Mazdaspeed3/6 General Discussion 25 11-23-2014 06:39 AM
Melted Bushing HiFiSpeed Gen2 MS3 General Discussion 1 10-27-2014 12:43 PM
Need a part help! (MS3 Positive Battery Terminal Bolt) batman MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-15-2011 09:09 AM
Page generated in 0.54915 seconds with 33 queries
