![]() Join Date: Jun 2015 Location: Belgium
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Last week when the engine was cold I stopped at the red light after a 1 mile drive. When I pulled up (normal speed, cold engine..) there was a lot of blue clear smoke coming out of the exhaust. But at the next red light, nothing happened. I checked the back of the car and it was full of little black oil spatters. So I cleaned the car and went out for some testing, I let it idle for +10 minutes, nothing happened. I went on WOT, engine braking and again on WOT etc etc. No smoke to see, let it idle again, for short time, long time, gave a little gas. No blue smoke to see. Ive been riding for +200 miles now, no blue smoke or oil spatters on the back.. Any thoughts ? Sorry for my writing faults... Last edited by DC2; 11-05-2015 at 02:01 PM. |
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. | |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
| Not Ranked : 0 score Sounds like condensation making its way out of the exhaust...
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs |
Groans: 50
| Not Ranked : 0 score I've never seen blue condensation or condensation make little black oil spots on the back of a car. I gave the OP the benefit of the doubt that he could tell the difference between "blue smoke" and condensation.
![]() Join Date: Feb 2013 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 49 Times in 12 Posts
| Not Ranked : 0 score I'm more surprised your engine was cold after driving a mile. My coolant temps are fully warmed up after driving that far (no oil temp gauge).
__________________ 2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016! BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn |
Groans: 50
| Not Ranked : 0 score You're in alabama. He's in belgium.
| Not Ranked : 0 score Haha, very true. But even during the winter when ambient temps hover around freezing, I'm still usually warmed up after a mile. But then again, for all I know Belgium gets way below freezing at this time of year.
Groans: 50
| Not Ranked : 0 score Yeah man. I don't know i could be way off base. Just trying to help him out since no one else was chiming in.
(Thread Starter) | Not Ranked : 0 score I really know the difference between condensation and oil burning blue. I was thinking maybe some PCV valve who got blocked ?? Here in Belgium its now like 60 °f. Way to hot for the time of the year.. About 1000miles ago I've changed the oil from semi synthetic to 5w30 shell full synthetic. (=rotella oil). Oil level is ok, did not drop.. So strange
__________________ 2007 Mazda 3 MPS Cobb accesport v3 Freektuned Corksport SRI - TIP - HPFP internals - Racepipe FMIC Downpipe Shortshifter H&R -4cm springs |
Groans: 50
On a side note. When did you install the racepipe? Have you tried the stage 2 ots map with your setup? I believe the first cat should be replaced with a high flow cat but a lot of guys have gone stage 2 with a racepipe (and the other supporting mods obviously) and had decent results. Just curious. Do what your comfortable with.
The race pipe is on it for a long time, previous owner installed it already.. I bought the AP and flashed it to the normal stage 1 map. Then I bought the SRI, TIP and HPFP and flashed it to stage 1+, then I had to do MAF calibration because AFR dropped from 11.6 to mid 10's.. I did some emailing with the guys from cobb, because on their website they say you can run stage 2 with only a racepipe (https://static.cobbtuning.com/cobbtu..._12%20v231.pdf) and on the forums you reed many different things, one say yes you can, others say no you cant, so I asked it ! The guy from cobb told me I can run stage 2 unless there was underboosting. I did not see underboosting (had 18.7psi or something) but it did not feel smooth. So I switched back to stage 1+ after max 150 miles. This is now 2 months ago I think ? I still got the mails from cobb.. ps; 2 days ago I bought a tune from Freektune, because it looks like cobb is not what they look like I gues.. Thanks for the help and thinking with me robb !!
__________________ 2007 Mazda 3 MPS Cobb accesport v3 Freektuned Corksport SRI - TIP - HPFP internals - Racepipe FMIC Downpipe Shortshifter H&R -4cm springs | |
Groans: 50
At the moment, she runs pretty good. Very happy with it. Looking forward to complete the freektune.. If I had some engine damage, or broken turbo I would smoke all the time.
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Any smoke at startup? Could be valve seals. |
(Thread Starter) | Not Ranked : 0 score Update; when I installed my downpipe, the car was now smoking ALWAYS after cold start and idling. So maybe because the oil was thick and cold, the turbo pushed it out through the seals.. I installed a smaller oil feed banjo bolt and the problem was solved..
| The Following User Says Thank You to DC2 For This Useful Post: | robbspeed (03-04-2016) |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Your turbo seals are beginning to fail. The banjo bolt as well as switching to a 10w-40 oil will help prevent the oil from passing the seals for a while, but it likely only a matter of time before they fail completely.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
When the time has come, and my turbo fails completely. I think that moment is the perfect excuse to install a upgraded turbo
![]() | | #19 | ![]() |
Groans: 111
| Not Ranked : 0 score 15w30... If your car had a mouth and fists it your bite you from the neck and punch you in the eyes on cold starts, especially when that 15w oil is in there over winter nights.
| The Following User Says Thank You to mituc For This Useful Post: | MD1032 (03-04-2016) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry, its 5w30 not 15w30
![]() | | #21 | ![]() |
Groans: 111
| Not Ranked : 0 score Well, that's a lot better but not ideal... The thinner the oil, the higher the penetration and flow capabilities. So with these weak seals on the factory turbo a w30 grade oil will simply to past the seals when it's hot enough and there;s not enough back pressure in the exhaust to push back the turbo seals (at idle there's one of these situations). I've never looked at the banjo bolt as a viable solution because I always assumed that the oil flow was calculated properly for lubrication and cooling. But moving to 5w40 early in my car's life (27k km) got me a stock turbo in pristine condition at 103k km when I replaced id with the GTX. Well, now you have the occasion, justification and need (look at it how you want ) to throw at least a BNR S3 or a GTX2867/71 in there
| Heavy Blue Smoke | blackmazda07 | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 04-26-2015 06:03 PM |
| blue smoke | Xlude | 2010 MS3 - Engine, Transmission & Driveline | 6 | 12-17-2013 10:25 AM |
| Blue smoke under acceleration | Dsmer4ever | Mazdaspeed3/6 General Discussion | 7 | 04-17-2011 04:22 PM |
| Blue Smoke | johnnyspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 03-04-2010 08:31 PM |
| Blue Exhaust Smoke | JCMS07 | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 12-02-2008 11:56 PM |
