Like Tree78Likes
 Old 10-03-2015, 05:49 PM   #1
vesestilldrumming's Avatar
Posts: 50   (View Stats)
vesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of light
Groaned at 6 Times in 2 Posts
Default Boost creep after installing Corksport Turbo
Hey guys I bought and installed the CS turbo a week ago. I'm having serious boost creep issues with this thing and me and my tuner cannot get it under control. New EBCS, bigger boost lines off of ebcs, wastegate flapper isn't getting stuck inside the downpipe etc. I hooked up the boost port from the turbo to the top of the wastegate to see if it was working properly and it definitely is. Hold strong at 17 psi with that set up. I opened the wastegate arm a little bit more to allow a little bit of preload off the turbo. Turbo is boost creeping from 19 psi up to 22 until fuel cut. I read that having a catless exhaust will do this but I'm looking for opinions because this is getting ridiculous. Mods are CS hpfp internals, atp 3" intake, atp catless downpipe, speed daddy cbe, ngk 1 step colders, matt damond egr block off, jbr occ, jbr motor mounts, Treadstone FMIC with TR8, coolant bypass and tb gasket etc. Thanks
vesestilldrumming is offline   Reply With Quote
 Old 10-03-2015, 07:48 PM   #2
gdawg25's Avatar
Posts: 248   (View Stats)
Fuel pump internals? 3 bar map sensor?
 Old 10-03-2015, 08:02 PM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
He mentions CS internals.
But I agree on the 3 bar MAP, do you have it? If not, You're only guessing at seeing 22psi, and could be pushing much more. Might be the reason why you are hitting fuel cut when you think you shouldn't be.
And if your tuner doesn't realize this, and you've given him your mod list, you might want to get a new tuner.
Awal (10-03-2015)
 Old 10-04-2015, 10:09 AM   #4
spl
spl's Avatar
Posts: 185   (View Stats)
spl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the world
Neutral  +1 score
I think that your ebcs is faulty or isn't installed correctly. Also you're definitely hitting fuel cut because your boost is actually going higher than 22 like others have said. How high? Sky's the limit buddy!
EBCS 3 port, 1 line from manifold, 1 line from intake and 1 line from wastegate. Which brand of EBCS you have denotes where these go. Good luck dude.
2010 BM - FREEKTUNED - BNRS3
spl is offline   Reply With Quote
The Following 3 Users Say Thank You to spl For This Useful Post:
Awal (10-04-2015), ericrapp0507@gmail.com (10-04-2015), phate (10-08-2015)
 Old 10-04-2015, 04:50 PM   #5
I ran a JBR true boost 3 port ebcs and a grimmspeed 3 port ebcs. Both are doing the same thing.
 Old 10-08-2015, 06:25 AM   #6
OK, I moved all the related posts from the Corksport general thread over here, and cleaned it up a bit. I think this will really help.
vesestilldrumming likes this.
Easter Bunny (10-19-2015), WetzMS3 (10-08-2015)
 Old 10-08-2015, 09:03 AM   #7
You will probably need a revised map with the changes.
vesestilldrumming and ms3gt08 like this.
 Old 10-08-2015, 09:04 AM   #8
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
IMO you are doing a lot of work for nothing.
You pulled 17psi on the wastegate alone, so it can only be one of a few things...plumbing to ebcs incorrect, faulty ebcs thats not opening, faulty wiring keeping ebcs closed. What are you doing with both ports on the wg? Is one blocked with a cap while in 3 port?
On my corksport turbo with corksport catless dp and rp with a grimmspeed ebcs I have port 2 on wg with other wg port capped, port 3 straight to turbo, and port 1 goes to my jbr 3.5" intake toob. This is on 3 port interrupt not for 2 port bleed
For reference Ryan is also tuning my car with great success so far
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
The Following 2 Users Say Thank You to davychronic For This Useful Post:
Easter Bunny (10-08-2015), Raider (10-08-2015)
 Old 10-08-2015, 09:58 AM   #9
littleloogy's Avatar
Posts: 4,005   (View Stats)
+1 for advising you to leave the DP on.
Sent from my iPhone 6
 Old 10-08-2015, 10:48 AM   #10
Ok so I guess what I'm gonna need is someone with more extensive knowledge,such as you guys, to look at my car in person and help diagnose this problem
Sent from my SM-G920F using Tapatalk
The Following User Says Thank You to vesestilldrumming For This Useful Post:
davychronic (10-08-2015)
 Old 10-08-2015, 10:52 AM   #11
iammike's Avatar
Posts: 1,415   (View Stats)
@L0k1; could maybe help. He's in that area but not sure where he stands on tech knowledge.
Mike
 Old 10-08-2015, 11:17 AM   #12
I don't know of any capping of a 3 port solenoid that should be done.
Hook port 3 to the high pressure source and port 2 to the wga.
 Old 10-08-2015, 11:44 AM   #13
If you vent port 1 and dont cap the intake, you will have issues. You can leave a cap off port 2 on the wg but a cap keeps out dirt and debris.
Easter Bunny (10-08-2015), rfinkle2 (10-08-2015)
 Old 10-08-2015, 11:47 AM   #14
The high pressure source is on the wrong port. (point being)
You can vent the 3 port vta understood, but need to cap the intake.
Port 1 vta or back into intake tract
Port 2 to top of wga
Port 3 use a step down , i.e. the line that previously went to the bottom of the wga is 6mm.
You have capped the bottom of the wga, so that line is the high pressure boost source.
That line is 6mm, so use the 4mm step down and run it to port 3.
davychronic likes this.
 Old 10-08-2015, 01:18 PM   #15
Yatta's Avatar
Posts: 1,862   (View Stats)
Assuming he is still using a grimmspeed, i pulled this from an earlier (not related to this problem) thread....
if that matches I believe that is how a 2 port should be done?
Grimmspeed EBCS in 2-port mode
 Old 10-08-2015, 01:23 PM   #16
I'm suggesting an alternative that might help.
I wouldn't know why you would run a 3 port solenoid in 2 port mode.
Hey, try it if you want, don't if you don't.
If I was tuning the car, I'd make the suggestion.
Everything else has been attempted with no solution.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Easter Bunny (10-08-2015), ge3kspd (10-09-2015), Raider (10-08-2015), WetzMS3 (10-08-2015), Yatta (10-08-2015)
 Old 10-08-2015, 01:33 PM   #17
Yatta's Avatar
Sorry, I agree with you, thought you were saying it was currently hooked up wrong (it looks right; but OP should confirm where 1 and 2 are connected to currently) the only reason I could think to run a 3 in 2 is replacing/keeping ‘stock’ behavior, if a tuner is involved, set it up for 3 port and tune for it.
 Old 10-08-2015, 02:22 PM   #18
Does anyone know what the voltage or ohms coming from the ebcs wiring harness should be? Could someone go test theirs real quick please?
 Old 10-08-2015, 04:32 PM   #19
I can do it tonight when I get off work. You sure your boost tubes don't have any holes? Have you done a boost test?
 Old 10-08-2015, 06:53 PM   #20
Ryan mt tuner wants me to put my catted downpipe back on and so does the tech from Corksport. So that's what I'm doing in the morning.
 Old 10-08-2015, 07:02 PM   #21
Godspeed
Easter Bunny (10-08-2015), WetzMS3 (10-09-2015)
 Old 10-08-2015, 07:10 PM   #22
Make sure you get a revised map.
 Old 10-08-2015, 07:17 PM   #23
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
If it holds at 17psi with the boost source directly to the WG then swapping DPs isn't going to solve your issue. I haven't read through all the posts, but have you checked all the hoses on the EBCS to make sure none are split, cracked or otherwise not optimal?
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
chaser27 (10-21-2015), Easter Bunny (10-08-2015)
 Old 10-08-2015, 07:20 PM   #24
Yes. Time and time and time again. Ryan Martin had a car in Australia he tuned that was doing the same thing my car is doing. The only thing that fixed it was by putting a cat back in the exhaust
 Old 10-08-2015, 07:33 PM   #25
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
so what would cause the same combo on another car to not creep? witchcraft?
94 M
MS6
IS350
 Old 10-08-2015, 07:47 PM   #26
The good idea fairy and comment Kings have run their course. Thank you for the help everyone who actually gave me positive input. It's comments like this ^^^^ that piss me off
 Old 10-08-2015, 07:56 PM   #27
iammike's Avatar
There is nothing wrong with his comment...but it's not creep.
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
 Old 10-08-2015, 08:02 PM   #28
I've had two very reputable tuners tell me it IS creep and they both tell me putting a cat back in my exhaust will help with the problem. I've literally run every single other option and everyone keeps telling me the same things to do. I can only take off my battery, intake, battery box and other stuff, then change boost lines, zip ties, and ebcs's so many times with the same result before I lose my mind. The only time anything made a difference is when I directly hooked up boost from turbo to wastegate and it worked at 17psi. I'm taking full trust in my tuner, like anyone should with as trustworthy of a tuner as Ryan Martin, and I'm putting my stock dp back on. End of story. If you are gonna tell me that it isn't something that many people have already told me it is, then I don't want your opinion. Thanks, rant over.
The Following 3 Users Say NO Thank You to vesestilldrumming For This Un-useful Post:
Easter Bunny (10-08-2015), MS3Shadow (10-09-2015), Vansquish (10-09-2015)
 Old 10-08-2015, 08:05 PM   #29
iammike's Avatar
Then why did you come here asking? Don't ask if you're going to have that kind of attitude. Figure the shit out yourself.
Mike
The Following 5 Users Say Thank You to iammike For This Useful Post:
chaser27 (10-21-2015), Easter Bunny (10-08-2015), MS3Shadow (10-09-2015), Raider (10-09-2015), Vansquish (10-09-2015)
 Old 10-08-2015, 08:09 PM   #30
I you don't except my last post...then you aren't human. Everyone gave great input except you and the other "witchcraft" dude. I explained that the same recommendations all produced the same output and all you did was give me some short bullshit statement with no recommendation. So thanks for nothing dude
 Old 10-08-2015, 08:21 PM   #31
iammike's Avatar
Self-entitled much? Have fun. You just don't like what I have to say and you're acting like a child.
Mike
The Following 4 Users Say Thank You to iammike For This Useful Post:
 Old 10-08-2015, 08:21 PM   #32
Pu Manchu's Avatar
Groans: 546
sorry that was my version of the socratic method.
if other people run this turbo with a catless exhaust without creep, but you need a cat to achieve the same result, then your cat is a bandaid for the real problem.
good luck.
94 M
MS6
IS350
The Following 7 Users Say Thank You to Pu Manchu For This Useful Post:
865ms3 (10-09-2015), chaser27 (10-21-2015), DaUberSchwebel (10-09-2015), Easter Bunny (10-08-2015), MS3Shadow (10-09-2015), Vansquish (10-09-2015), WetzMS3 (10-09-2015)
 Old 10-08-2015, 08:23 PM   #33
0187
esr010's Avatar
Posts: 486   (View Stats)
esr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the world
Groaned at 9 Times in 5 Posts
OP. Let it go. At least no one is saying in before ZZB because you can't figure your shit out. If it's the cat then prove everyone wrong and show a solution to those that have the issue with similar setup in the future.
esr010 is offline   Reply With Quote
The Following User Says Thank You to esr010 For This Useful Post:
vesestilldrumming (10-08-2015)
 Old 10-09-2015, 05:18 AM   #34
EnixStorm's Avatar
Posts: 108   (View Stats)
EnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond repute
Groaned at 3 Times in 1 Post
In before ZZB 😁
Cobb SRI :|: Cobb TIP :|: CPE Stg 2 RMM :|: JBR 70 PMM :|: AutoTech Internals :|: AP V3
EnixStorm is offline   Reply With Quote
The Following 5 Users Say Thank You to EnixStorm For This Useful Post:
chaser27 (10-21-2015), Deldran (10-09-2015), Easter Bunny (10-09-2015), Raider (10-09-2015), WetzMS3 (10-09-2015)
 Old 10-08-2015, 08:54 PM   #35
Word 👍
good luck.
Yeah I guess but there is a legitimate other MS3 with the same issue and the cat helped. So that's what I'm going with next. Thank you for real input bro
Last edited by vesestilldrumming; 10-08-2015 at 08:54 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-08-2015, 09:55 PM   #36
If it's creepy then why does my grimspeed, CS turbo, and catless combo stay right on boost target?
MS3Shadow and davychronic like this.
The Following 5 Users Say Thank You to littleloogy For This Useful Post:
iammike (10-09-2015), MS3Shadow (10-09-2015), Raider (10-09-2015), Vansquish (10-09-2015), WetzMS3 (10-09-2015)
 Old 10-08-2015, 10:44 PM   #37
if you have no creep when the boost source is connected to the wastegate then you do not have creep you have a boost control problem.
So you are faced with a situation where one configuration runs without creep and then by simply reconnecting one part you suddenly have creep. This is the classic cause and effect, you are faced with narrowing it down to which part of the ecbs is faulty, wiring plumbing or the valve itself.
Anyone recommending putting in a carted downpipe is putting a bandaid on a broken leg all this will do is mask your boost control issue. So by all means waste your time swapping downpipes but we will see you tomorrow same time same place with the same boost control problem.
Hopefully your sandy vagina didn't piss too many people off and someone will still be willing to help you.
The Following 13 Users Say Thank You to Easter Bunny For This Useful Post:
865ms3 (10-09-2015), anavrinIV (10-09-2015), chaser27 (10-21-2015), DaUberSchwebel (10-09-2015), Deldran (10-09-2015), iammike (10-09-2015), MS3Shadow (10-09-2015), Raider (10-09-2015), sh4d0w (10-09-2015), tegxsi (10-09-2015), Vansquish (10-09-2015), WetzMS3 (10-09-2015), Yatta (10-09-2015)
 Old 10-09-2015, 03:31 AM   #38
Obviously you are frustrated that the problem will not go away.
But step back after you do what you do, and ask yourself if you fixed the problem, or masked the symptom. Because if it's not fixed, and you do creep or get a spike down the road that leads to ZZB, it's going to be a lot more expensive.
My advice is to look into the stratified guardian angel. In your case, it's something to install for sure.
Mike@Stratified (10-09-2015), sh4d0w (10-09-2015)
 Old 10-09-2015, 05:01 AM   #39
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
I believe @lpugfan2004 had the same problem, i think he had to add a cat into his downpipe to fix the problem...he can answer better tho...
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
The Following User Says Thank You to djern For This Useful Post:
lpugfan2004 (10-09-2015)
 Old 10-09-2015, 08:14 AM   #40
lpugfan2004's Avatar
Posts: 771   (View Stats)
lpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the world
I did have the exact same problem (except mine creeped even going straight to source) and tried everything. Even eliminating the boost control and going over to manual control (WG straight into boost source and cap off everything else) to see if it would hold spring pressure, and it still creeped to 23+. I checked the EBCS lines everytime someone asked, and believe me it was every time I asked for help. New WG actuator, check the WG flapper no blackage, adjusted the arm so many times I ruined my heat shield, ran out of hose re doing my EBCS every couple days, went back to bleed set up on stock EBCS with restrictor pill, and so on.
After 2 months of tinkering and trying shit (nothing worked), corksport helped me out and sold me a cat, got it welded in and it holds spring pressure without an issue, with an ebcs and without an ebcs. I don't know if I just bandaided another problem, but my tuner and local Nator members were completely out of ideas and a cat was my last resort.
OP it could very well work for you, but it seems that since you can put the WG directly onto boost source and it holds that something else may be going on here and ignoring the base problem by putting a cat back on may cause more harm than good.
It sounds like boost creep is NOT your issue though. It is a boost control issue.
Have you called Corksport? I was in constant contact with Barret / Eric / Vincent through the entire ordeal and they were more than helpful. They even sent me a WG actuator to eliminate that as a fault.
In the defense of OP, hearing "my car with the same setup doesnt creep" gets old really fast. I heard it for 2 months with little to no suggestions from anybody and just stopped asking for suggestions.
tldr; I had similar issue, was definitely boost creep, put cat in. OPs problem is not creep, its a boost control issue.
2012 Velocity Red Mazdaspeed3
- CP-E Stage 1 RMM - Autotech HPFP Internals - COBB AP v3 - Corksport 3inch Intake - Corksport Turbo - Corksport BPV -
- JBR Shift Plate & Shift Weight - JBR Solid Bushings - cp-e Catted TBE - NGK 1 step colder plugs - COBB 3 Port EBCS -
- ETS TMIC - Michelin Pilot Super Sport 235/40-18 - JBR OCC Stage 2 - JBR EGR Delete - CorkSport Boost Tubes -
- JBR IM and TB gaskets w/ coolant bypass - Damond Motosports PMM - Corksport PMM Bushing Insert -
Tune in progress
lpugfan2004 is offline   Reply With Quote
The Following 10 Users Say Thank You to lpugfan2004 For This Useful Post:
anavrinIV (10-09-2015), chaser27 (10-21-2015), Code Monkey (10-09-2015), djern (10-10-2015), Easter Bunny (10-09-2015), Mike@Stratified (10-09-2015), Pu Manchu (10-09-2015), rfinkle2 (10-09-2015), vesestilldrumming (10-09-2015), WetzMS3 (10-09-2015)
Fuel Cut, Over Boost, Turbo Creep Ms6_Guy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-08-2014 03:29 PM
GTX3071R boost creep/boost spike! Need help! MS3 Ventura MazdaSpeed 3/6 - Big Turbo Builds 20 05-11-2013 11:44 AM
Boost creep 86AmishMs3 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-21-2011 05:30 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Boost Creep RocketScientist MazdaSpeed 3/6 - Turbo Induction 3 08-02-2010 11:13 AM
Page generated in 0.72019 seconds with 37 queries
