 Old 07-01-2014, 07:35 PM   #1
BooSTed_Hatch's Avatar
Posts: 169   (View Stats)
BooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond repute
Default Boost problem
So today on the way to work , I went WOT merging onto HWY and car was limp. Would hit boost and then falls flat. Not sure if it's a boost leak or what.
I sent an email to Justin but figured I would post here as well for any advice. Might have to take things apart and look for a leak if that's what it might be (at least I hope that's all it is).... Any advice please.. @Justin@Freektune; @rfinkle2; @Lex;
Took a log but didnt go WOT all the way through RPM range because of how it falls on its face. You can see in the log attached, I hit about 10/11psi and then it drops to 8ish. AFR's are also very low at 8ish.
Car has been running strong for the past 6-7months or so since it was tuned by Justin with no issues...
All my mods are in sig.
2013 CWP MS3 w/Tech Pkg
Performance Mods
Cobb AP V3 ~ JBR 3" WP Intake + Turbo inlet ~ JBR IC Boost tubes ~ AT hpfp Internals ~ ETS TMIC ~ CS Catless DP ~ CS Race pipe ~ CS Catback ~ CP-E Stg2 RMM ~
NGK Iridium IX's (1 step colder) ~ Turbosmart 50/50 ~ KSport Pro Coilovers
[SIGPIC][/SIGPIC]on 93
307whp 339lbft
Exterior mods: ESM 004s - Hankook Ventus V12 Evo2 225/40/18 - Gloss Black Vinyl Roof - Gloss Black emblems - 15% tint - Rear Wiper delete - OEM window visors
On Order: GT2871r, Freektune 3.5" Intake, Bosch 3.5 Bar Map sensor, Cobb EBCS
BooSTed_Hatch is offline   Reply With Quote
 Old 07-01-2014, 07:52 PM   #2
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Really rich afr's, I would say a big boost leak (after turbo).
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
The Following User Says Thank You to Hush For This Useful Post:
BooSTed_Hatch (07-02-2014)
 Old 07-02-2014, 06:23 AM   #3
Thanks Hush, Any other idea's??
Performance Mods
307whp 339lbft
ms6 boost problem...2 psi Stealthvr4 MazdaSpeed 3/6 - Turbo Induction 17 06-14-2014 01:36 AM
Had a boost problem :/ Evolution99 MazdaSpeed 3/6 - Turbo Induction 2 03-29-2013 05:43 PM
same problem... boost spike LiEast MazdaSpeed 3/6 - ECU Computer Tuning 4 10-11-2009 10:31 AM
sb boost control problem speed_3 MazdaSpeed 3/6 - ECU Computer Tuning 20 07-01-2009 04:53 PM
Page generated in 0.24774 seconds with 22 queries
