 Old 08-06-2011, 07:15 AM   #1
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Default CEL P0134 & P0139
So I installed my CNT DP (w/ high-flow cat) yesterday, and I did some WOT pulls right after the install with no issue. AP's Live Datalog showed me hitting 1.9-2.1 calc load throughout most of the RPM range, MAF g/s peaked at ~260, and KR didn't exceed 1.0 during the pulls. No CELs.
Fast forward one hour, and the CEL comes on during a light 5 minute drive to Jack in the Box. I use the AP to pull the code, and I come up with P0134 and P0139.
Now as I understand it, P0134 indicates that there is no reading coming from the primary O2 sensor. To further confirm that there is a problem, the AP's Actual AFR parameter reads a constant 14.7, no more, no less, regardless of whether I'm at low throttle, part-throttle, or WOT.
P0139 seems to indicate that the secondary O2 isn't receiving enough exhaust flow. I have CNT's CEL "fix" installed, which is basically an L-shaped defouler installed to the secondary O2 sensor location. I may try removing it to see what happens, but I was under the impression that having the secondary O2 closer to the exhaust stream would cause the ECU to throw the "inefficient cat" code.
I want to rule out a bad sensor, because I really don't want to buy a new set, since they cost lots of $$$. I didn't strip either sensors removing them from the stock DP. Are the sensors easily damaged? Is there a way to clean them? Other than that, the only thing I can think of doing is checking to make sure the wire harness connections are plugged in, and uninstalling the "fix" (defouler) from the second O2 sensor and just plugging the secondary O2 straight into the bung.
Thanks in advance guys.
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
P0137, P0139 and P0140 felt MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 07-18-2017 05:39 AM
P0139 CEL? D08SPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 21 06-17-2012 07:56 PM
P0139 MS3-a(sore)ASS-rex MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 03-01-2011 07:12 AM
I threw a p0139 speed_3 MazdaSpeed 3/6 - ECU Computer Tuning 6 10-01-2008 03:22 PM
P0139.....again Death-From-A-Mile
Cobb Access Port/Maps
10 05-31-2008 01:31 AM
Page generated in 0.27732 seconds with 24 queries
