![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score https://youtu.be/-vKEZ8gZCxc https://youtu.be/zJ-lsNYOfdw Last edited by Edwards3893; 04-17-2019 at 01:16 PM. |
| Not Ranked : 0 score Threw: past tense of throw. Example: My engine THREW a rod yesterday because my car has problems and I drove it anyway. The rod went THROUGH the side of the block. Because I didn't read this magnificent website THOROUGHLY THROUGH and THROUGH, now I'm THROUGH with Mazdaspeed and THROWING in the towel. Any THOUGHTS THOUGH?
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Bertospeed3 (04-17-2019), Jeff23spl (04-18-2019) |
(Thread Starter) | Not Ranked : 0 score Sorry for my grammar.... I am dyslexic and struggle with common grammar sometimes. Other then that I’m not an idiot by any means. I just need help with my car . I don’t know what it could be —♂️ The noise is the loudest on the back side of the motor but I’m having issues trying to hunt it down. It sounds to be coming from the turbo maybe exhaust side of it when I put my scope on it you can hear it in the turbo very loud and clear but you also can hear it very well on the back side of the valve cover/head |
![]() Join Date: Oct 2015 Location: Central Jerz
| Not Ranked : 0 score Damn, now i feel bad for laughing
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
Groans: 60
| Not Ranked : 0 score Your knocking sound reminds me of the intro to every bent rod story Ive ever read. Also, you should pull the valvecover and inspect the VVT actuator, that could be your crazy rattle at startup.
| The Following User Says Thank You to SSinstaller For This Useful Post: | 86AmishMs3 (04-18-2019) |
(Thread Starter) | Not Ranked : 0 score So is the only way to see if it’s a bent rod is to take it out (aka motor rebuild why I’m there) would a compression test tell anything on a bent rod? Also I don’t hear the knocking after a certain rpm because the motor will drain the noise out. Last edited by Edwards3893; 04-17-2019 at 04:21 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Ahh. Drown it out with the radio if you don't want to rev it too much.
Groans: 60
| Not Ranked : 0 score You could try a compression test- a bent rod would drop the compression in that cylinder, but it might not be that noticable on a high mileage motor. You could always just pull the oil pan and look.
| Not Ranked : 0 score There's always the screwdriver test for a bent rod. Stick long screwdriver through sparkplug hole. Crank manually to TDC and mark the height if the screwdriver. Repeat on other 3 cylinders. But, like the compression test, it may be too small of a difference to notice.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | 86AmishMs3 (04-18-2019) |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score @Fstrnyou; do you need a hug buddy?
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
| Not Ranked : 0 score unless you are skilled at checking rod height or have a followed historic of your engine compression. You would better remove the oil pan to inspect each top part of the rod bearing and if you see marks or color difference, you need a rebuild + crank work. You can inspect timing chain and VVT, if chain is stretched or VVT is some kind of free, you call a timing job.... And don't return to the shop that said it could be a lifter or a rocker arm because it isn't a carburated old 350 V8... our engines don't have rocker and, lifter are solid...unless it ran without oil, the chance for too much valve play is very limited and if it do ran without oil pressure, the bottom end will fail a lot sooner than the top.... If you look for a pleasant and economic solution rise the volume until it ZZB.
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Do a compression test. It will tell you what you need to know. Easy to rent.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
(Thread Starter) | Not Ranked : 0 score Thank you everyone that replied back I will try a compression test and see if that gives me anything! I’ll post my test in here once I get it done |
![]() Join Date: Jun 2019
| Not Ranked : 0 score I am having a similar issue with my speed3. My stock turbo failed at 84k after a lot of hard driving. Anyways I replaced the turbo and my air oil separator because it was cracked and leaking. I also did the timing chain, guides, gear and replaced my VVT solenoid because it was acting up (screen was clogged). Now when I drive the car under very little load it runs and drives perfectly. But under heavy load there is a loud clicking noise that follows RPM as well as backfiring out of the intake. I thought the valves were leaking so I cleaned them but it didn't solve it unfortunately. My compression is about 165psi on the end cylinders and 160psi in the middle. Anyone got any ideas as what it could be? |
![]() Join Date: Jun 2009
| Not Ranked : 0 score I thought the same thing but I checked it and so did 4 other techs I work with. It is definitely set right. |
| Constant KR daily | alden | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 08-29-2018 10:58 AM |
| Knock Knock Knock..Whose There? (<===total noob) | thomas_cory2000 | MazdaSpeed 3/6 - ECU Computer Tuning | 158 | 06-12-2014 11:57 PM |
| Parted out, stock tune -- constant knock? | curlyface | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 18 | 08-05-2013 06:50 PM |
| Constant rumble after CO's & RSB | dpolseno41 | MazdaSpeed 3/6 - Suspension & Brakes | 0 | 03-18-2012 03:59 PM |
