 Old 09-18-2019, 02:33 PM   #1
callumr100's Avatar
Posts: 3   (View Stats)
callumr100 has a spectacular aura aboutcallumr100 has a spectacular aura about
Default Fuel Pressure drop at WOT
Hi All! abit of a noob to the mazdaspeed forum.
long story short, my other halfs gen2 has a weird fuel pressure drop in the 3k RPM range (as per the attached)
MODS: bnrs3, JBR intake 3" i believe, CP-E Tmic, Auto tech HPFP internals, Cobb 3port bcs,ATP decat downpipe (long) tuned by Justin.
car had been tuned a while ago so thought i'd get a log to check things over. nothing has been changed on the from when it was tuned etc.
Checked/changed
-HPFP Pump
-HPFP internals
-HPFP spill valve (twice)
-Rail Relief Valve (twice)
-Re-Flashed ECU (current tune)
-Re-Flashed ECU (previous tune)
-Fuel Rail Pressure sensor (twice)
-Low pressure in tank pump & sender
-Fuel Pump resister
-Fuel pump relay
-Primary 02 sensor
-Purge Valve solenoid
-fuel filters
-inspected fuel injector seals
-inspected fuel injector o rings
-replaced complete fuel rail with new pressure sensor and relief valve
-checked injector resistance (1.1ohm)
-checked purge valve with oscilloscope
-checked HO2S with oscilloscope
-checked injectors with oscilloscope
-checked fuel tank pressure
-visually inspected charcoal canister (can’t perform test with out mazda computer)
-checked fuel cap is sealing
-replaced fuel feed to hpfp
-replaced fuel return pipe from relief valve to hpfp.
-replaced HPFP hardline
-replaced wiring loom
-remover turbo and re-tapped snapped stud.
-replaced DP due to 02 sensor seating poorly.
-Repaired a few damaged wires from the intake clamp rubbing through.
Really at a loss with this one, feel somewhat defeated and the Mrs is considering selling up!
My apolologies if this is in the worng section!!
callumr100 is offline   Reply With Quote
 Old 09-18-2019, 08:58 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Did you check or change the pump internals? How did you test the in tank pump?
 Old 09-19-2019, 04:14 AM   #3
callumr100's Avatar
Yes, i swapped out the internals twice using a different pump housing and spill valve each time.
i tested the intank pump as per the workshop manual for electrical issues, i then swapped it out for a known good one (off my own car)
 Old 09-19-2019, 06:35 AM   #4
callumr100's Avatar
FIXED. The charcoal canister was full of fuel. Replaced and it’s all good.
The Following 3 Users Say Thank You to callumr100 For This Useful Post:
MSMS3 (09-19-2019), SSinstaller (09-19-2019), Vansquish (09-19-2019)
what's causing the fuel pressure drop? Sonofnothing 2010 MS3 - ECU Computer Tuning 12 02-09-2018 05:34 PM
Need help with fuel pressure drop ... again BMC Gen2 MS3 General Discussion 3 09-13-2017 10:28 AM
Fuel pressure drop derek13p 2010 MS3 - ECU Computer Tuning 32 05-27-2013 10:24 PM
Fuel Pressure Drop/Cut Burton MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-31-2012 07:43 PM
Fuel Pressure Drop after load of 2 dpolseno41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-17-2012 07:37 PM
Page generated in 0.24317 seconds with 22 queries
