![]() Join Date: Jan 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I had a fuel smell for quite some time, had a leak on my gas tank, which appeared to be coming from the top and checked the fuel pump underneath the rear seats, sure enough, its leaking from the in line, now is there a way to reseal the end, replace oring/snapring? or do I have to replace the whole fuel line? it appears to be seeping from here, and when I went to wiggle the line, it was squirting fuel out, is there a fuel cutoff? or will it just leak fuel until the line is dry from moving it? If I take the end off? how much fuel will spill? Attached are the images of the tank and fuel pump |
![]() Join Date: Dec 2017
Hate to restart an older thread but i'm having the same issue on my 2013speed. My fuel is spraying from the connector hose (the green clip) which i replaced and the leak is even worse now. I'm thinking its the ITFP housing that is leaking? Did you ever get this issue resolved? Not sure i want to spend a weekend dropping the tank or cutting open the backseat access hole. Last edited by GRRRRANDALL; 12-31-2019 at 12:48 PM. Reason: Typo | |
![]() Join Date: Jun 2009
Maybe start a new thread and hang around long enough to give people a chance to see it and reply?
(Thread Starter) | Not Ranked : 0 score lol, apparently im still connected to these forums, I just got email notification... there was a hairline crack on the top of the fuel pump assembly, specifically the fuel line spigot/L-connector on top of the housing had a crack. Fuel line was fine, I didn't have to buy a new fuel pump assembly, was able to purchase just the top housing separately from local mazda dealership, but unfortunately, you have to drop the tank to get to it Last edited by MikeCZoomZoom; 01-02-2020 at 10:47 AM. |
| The Following User Says Thank You to MikeCZoomZoom For This Useful Post: | MSMS3 (01-02-2020) |
| Display Modes | |
| BMW calls in 50,000 motorbikes over fuel pump leak | Haltech | Automotive News | 0 | 01-07-2014 06:40 AM |
| Select 2010-2012 Jaguar XF models recalled over fuel leak fears | Haltech | Automotive News | 0 | 11-08-2012 02:40 PM |
| 2010-2011 Saab 9-3 faces recall over possible fuel pump defect | Haltech | Automotive News | 0 | 01-21-2011 02:30 PM |
| 2009-2010 Mazda5 minivans recalled over fuel pump concerns | Haltech | Automotive News | 0 | 12-08-2010 04:10 PM |
| Audi recalls over 10,000 2006-2010 A3 and TT models over potential fuel leak | Haltech | Automotive News | 0 | 10-05-2009 05:30 PM |
