 Old 12-03-2015, 12:40 AM   #1
csmaan12's Avatar
Posts: 325   (View Stats)
csmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond repute
Default Fuel pump took long to prime...
Literally just happened, turned on the ignition and I heard the fuel pump prime for much longer than its usual time. Car started kind of weak (has been for a couple weeks) where it doesn't immediately go to its high RPM 2k cold start. It went from 1.3k initial and went up to the normal 2k RPM.
Starts right back up normally, but if I let it sit for a while it does that weak transitioning to normal start.
Could it be what from my injector/seal replacement? Or something else. I followed all the torque specs for the CS injector seals. I don't smell any fuel anywhere, been checking every day for the last 2 weeks since I installed them. Under the hood all seems completely normal.
Any ideas? There was another poster who mentioned weak battery, but why would that cause the fuel pump to prime so long?
2011 Mazdaspeed3 Mod List:
FREEKTUNED
ETS TMIC
Autotech HPFP Internals
CS Stage II SRI + TIP
Tial QR
UR Catback
UR Catless Test Pipe
Damond RMM
Damond SSP
csmaan12 is offline   Reply With Quote
 Old 12-03-2015, 08:15 AM   #2
tastysi2004's Avatar
Posts: 1,063   (View Stats)
tastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the world
could be the battery. fuel pump needs that juice. if in doubt, take it all apart and redo it. check for scoring on the bucket, internals and double check each of the bolts. also check your pressure relief valve. if its bad, it may let off the extra pressure.
check the thread on how to tell if it's going bad.
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
build block, pnp everything, tr825 core, meth and lots of it.
554whp/546wtq @ 30psi.
another build? maybe soon..
b/c race cars need more attention than women.
adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~
#CATBACKEXHAUST
tastysi2004 is offline   Reply With Quote
 Old 12-03-2015, 08:38 AM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Take a log while the pump is priming + cold startup. Include Voltage.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 12-04-2015, 08:56 AM   #4
csmaan12's Avatar
Alright I'll do that and report back, interestingly enough it hasn't done that since I posted about it. Now just the slow start.
I'll post a log in a few hours when I get back from work, that way I'll have 2 cold start logs.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 09:09 AM   #5
csmaan12's Avatar
Here are three cold start data logs I took. I wasn't able to get the fuel pump to prime for a long time again, however I did get the slow start up you can see the RPMs start super low and build up to normal cold start RPM which is like 1800+.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 09:38 AM   #6
littleloogy's Avatar
Posts: 4,005   (View Stats)
Cold start:
KOEO-you should see pressure build to something close to 60PSI. If it does not get close to that on one key cycle, count how many key cycles it takes to get to around 60psi. You could have a check valve that is letting fuel bleed back into the tank.
If you get 60psi right off the bat and pressure does not want to build when you start, then I would think your mechanical fuel pump needs some servicing...
 Old 12-08-2015, 09:47 AM   #7
csmaan12's Avatar
Cold start:
Well pressure does build when I start, but I do notice that it's pretty much every time I start the car pressure is around 57PSI. When I start it, it builds up to 1700+ for the higher RPMs and settles down slowly to the idle pressure ~430PSI.
Only thing I notice, when it's not super cold out, lets say 40F+ there's this squeak that happens right when the fuel pressure goes from 1700+ and begins to come down with the RPMs as the engine warms up. To me that sounds like the relief valve. I'm not sure the spill valve would make that sort of noise, because it's literally happening only once, on cold start, and when there's a high > low pressure change. Does not happen while I'm driving at all even at WOT.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 09:58 AM   #8
Cold start squeaky squeak
csmaan12 (12-08-2015)
 Old 12-08-2015, 10:15 AM   #9
csmaan12's Avatar
Yeah I read that before so I took it as normal. Just brought it up in relation to the low pressure on cold start. In any case would that answer why my cold start is so slow.
I'm not sure if you noticed RPM climbs from 1k to 1.2k, then shoots up to 1800+. It was never like that before. It would always go straight to 1800.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 10:26 AM   #10
You running any E85?
 Old 12-08-2015, 10:29 AM   #11
csmaan12's Avatar
Yes, running an E30 flash tune from stratified.
I've had it a while now, no problems until just recently.
Also it took one cycle to get pressure above 60psi.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 10:35 AM   #12
Oh, yeah. That would be the problem you must have some buildup of sticky goo. Clean your pump or put a bottle of a Redline Si-1 in your tank.
 Old 12-08-2015, 10:59 AM   #13
csmaan12's Avatar
The whole thing or just the spill valve? Surprised how quickly it built up only on E30, not to mention internals are maybe a couple months old.
I'll give it a shot at cleaning and adding stuff in the gas tank.
Is the battery voltage looking normal in the logs?
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 12-08-2015, 11:05 AM   #14
I have not seen your logs, maybe I'll look tonight when I get home for work. What oil are you running? Certain oil work better with E85 then others.
 Old 12-08-2015, 01:05 PM   #15
csmaan12's Avatar
I use Rotella T6 just like anyone else. Been using it since I got the car at 53k miles. Changing every 3500 miles, I wasn't getting smoking for the turbo during that time, but I used it as a preventative measure. Since it's common to the K04 on our cars.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 09-28-2019, 10:36 PM   #16
Wicked411's Avatar
Posts: 1   (View Stats)
Wicked411 is an unknown quantity at this point
Default Help tonight? Mazdaspeed 6 wont start
I installed my autotech internals today. I go to get in car and it turns over but wont start. I went to get gas treatment. It started for 5 seconds then died. I've checked all my connections everything is good. I did it 2 times because the first time there was a ticking coming from a the plug by the turbo . Now I tried to wait for it to prime. But nothing seems to be working. Help?
Wicked411 is offline   Reply With Quote
 Old 09-29-2019, 03:43 AM   #17
MSMS3's Avatar
Posts: 2,826   (View Stats)
Worked before the install. Not now. That equals an install error. Could be just about anything. Do you have logging or diagnostic equipment?
First check the electrical connection to the pump. Check actual voltage.
If good, check key in key off test for 60 psi pressure to the low side of the pump.
If good, remove the pump, disassemble, clean thoroughly with fresh gasoline, work in a very clean location, reassemble.
Follow the instructions carefully.
Water Pump, Tstat, Fuel Pump Oh My! CBear3 Mazdaspeed3/6 General Discussion 13 10-01-2015 06:03 PM
Meth pump losing prime? deekspeed 2010 MS3 - Fuel, Nitrous & Water Injection 8 11-20-2014 03:13 PM
Fuel pump losing prime Speed3man MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 03-26-2012 07:33 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
Page generated in 0.36753 seconds with 26 queries
