 Old 09-26-2013, 01:57 AM   #1
chris.s.85's Avatar
Posts: 11   (View Stats)
chris.s.85 is infamous around these parts
Groaned at 19 Times in 2 Posts
Default HPFP internal question???
am needing to get the autotech internals by the sound of everyone on the forum but i had a question. do i need to tune anything after the install? or are the internals just providing a more steady higher flow of gas
chris.s.85 is offline   Reply With Quote
The Following User Says NO Thank You to chris.s.85 For This Un-useful Post:
Mauro_Penguin (09-26-2013)
 Old 09-26-2013, 02:20 AM   #2
cshunter's Avatar
Posts: 1,312   (View Stats)
Nice first post, and whalecum I guess.
OP I would recommend that you go do your intro thread, read the welcome pm, read the sticky threads, and continue from there.
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 09-26-2013, 03:06 AM   #3
JJMS3's Avatar
Posts: 343   (View Stats)
JJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond reputeJJMS3 has a reputation beyond repute
Welcome,
What he said ^; there are plenty of threads in the forums to search for answers you seek.
Do not forget to donate.
Have fun.
-James
2013 black mica MS3 - CS 3" intake, Cobb AP, Autotech Internals, CS TMIC, CS RMM, CS short shifter, CS RP, CS hood scoop for decoration, CS RSB, OBX CBE
JRL Tuned
JJMS3 is offline   Reply With Quote
 Old 09-26-2013, 03:36 AM   #4
GTFD_Tony's Avatar
Posts: 58   (View Stats)
GTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud ofGTFD_Tony has much to be proud of
Do you NEED a tune afterwards? Probably not. BUT a tune is going to allow you to take advantage of that extra fuel pressure. I would say its well worth it (even without preformance gains) just because you will have a much more stable and safer running car. If you like your car and want the best advice, then as suggested I would donate (first thing I did) as you will find this forum will offer ALOT more (people will help you out alot easier, this first one is free). We ask people to donate to better our forum (I say our forum becuase it is that, we take care of eachother. Raffles for good parts, information you would otherwise pay ALOT more for, and vendors listening to what we want/need because well were the best mazdaspeed forum and they know that) Most importantly if youre just going to be a freeloading brownie, read your ass off. There is SOOOO much information on here to be gained. So make a post of who you are saying hi, donate, and read till your eyes are dry. Best of luck to you
06 speed 6
Current:
CPE dp, CS tip, CS rmm, CS rdm, JBR side mounts (70a)
Cobb sri, Toyota seals, Autotech internals, CS tmic.
In progress:
Rich Tuned
Future:
JBR OCC, lowering, BT and 5th port (maybe)
GTFD_Tony is offline   Reply With Quote
 Old 09-26-2013, 03:47 AM   #5
Benis's Avatar
Posts: 413   (View Stats)
Benis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the world
Like others have said - you don't need a tune. But it's a good idea to get an AP so you can monitor the fuel pressure to ensure you did the install correctly.
Benis is offline   Reply With Quote
 Old 09-26-2013, 08:05 AM   #6
littleloogy's Avatar
Posts: 4,005   (View Stats)
Fuel pump internals and an AP is all you need to get started Mind what others have told you. Save your car, it can.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
 Old 09-26-2013, 08:30 AM   #7
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Internals are a mechanicle thing. Putting them in doesnt make your pressure higher/lower it just makes it able to keep up with whatever demand you put on the fueling system.
TEAM LUXURY
Fuel pump internal/HPFP,really necessary? RMCAT MazdaSpeed 6 - Engine, Transmission & Driveline 13 08-09-2013 09:22 AM
Hpfp internal/Cobb ap question maddocx240 Mazdaspeed3/6 General Discussion 24 04-29-2012 09:30 PM
Should you upgrade the cam follower when putting in internal for the HPFP? daztdMS6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 07-27-2011 07:12 PM
Rust on HPFP internal parts??? Keemo577 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 07-21-2011 02:02 PM
Page generated in 0.29071 seconds with 26 queries
