 Old 05-18-2019, 07:32 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Intermitent starting problem!
Has any body of the members here have reported a faulty start push button?
My situation is intermittent, sometimes it does it, sometimes it doesn't do it.
The problem is that when i hit the push button to start the car, normally car starts fast with no delay problem.
Lately once and then, when i hit the push button to start my car, there is like a 3 to 5 second delay and then it starts cranking to start the car but it takes longer than usual. It wasn't doing this before. The normal behavior has been instant engine start once you hit the start push button.
I took the car to pepboys and they told me that according to their diagnostic equipment battery had to replaced. After this i took it to 2 more places(autozone and another local shop) to have second opinions and to be sure it was battery but on both places they told me battery was good. Mechanic tells me that is not the starter because car is cranking with power on a push of a button the majority of the time, its just a problem that is intermittent. I'm lost here because if its not battery and starter, what the hell is it?
A few days ago a check engine light came on with a P0300 random misfire. Code was cleared but it hasn't showed up on the cluster again. At that moment i had a very empty gas tank and was using another gas, then that day i decided to go back to the previous pump gas brand but still yesterday and today it did it. This is a weird problem and i'm not gonna out and waste money on a battery, coil pack, crank sensor etc. if i don't know for sure what the heck it is. Can somebody share some light here because i'm lost
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
Another Intermitent P0300 Problem ZoomRubyZoom 2010 MS3 - Troubleshoot/Diagnostics 17 03-25-2017 06:26 PM
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 02:13 PM
just starting thegoofjuice 2010 MS3 - Build Diaries 6 04-06-2012 01:30 PM
Starting Problem GH07MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 12-31-2011 12:06 AM
Page generated in 0.22316 seconds with 20 queries
