 Old 05-18-2019, 05:32 PM   #1
ealmei's Avatar
Posts: 6   (View Stats)
ealmei will become famous soon enough
Default Leak down oddity
Has anyone experienced this:
While doing a leak down test if you move the crank slightly the reading gets better, maybe by 5%?
Is one of the valves still slightly open at TDC?
Could I have a dirty valve not closed all the way?
Could the timing be off just slightly?
I am I doing it wrong?
It is a stock engine that has never been molested.
I did the leak down test with two people. I had a rubber hose down the spark plug hole with my fingers right on the valve cover to stabilize the hose and feel the slightest movement up or down of the hose slipping through my fingers. Another person turned the crank to get it at TDC. I was sure that it was on the compression stroke because I blew air until I heard it leaking in the intake.
While putting the tester to the spark plug hole the other person held the crank still so that it didn't move under pressure. Once I got a reading I asked the person to move it slightly one way or another. Sometimes it got worse and other times it got better. But I was always made sure that we started at TDC holding the crank steady.
Any insight is appreciated.
thx
ealmei is offline   Reply With Quote
 Old 05-19-2019, 07:41 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If you check leakdown at TDC of compression stroke, you can be assured that no valves should be open.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-19-2019, 11:30 AM   #3
ealmei's Avatar
Thanks. I'll check it tomorrow.
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 12:29 PM
Frankfurt: Citroën Tubik is another space Gallic oddity Haltech Automotive News 0 09-13-2011 01:00 PM
SEMA 2010: 2011 Honda CR-Z Mugen is a rare oddity Haltech Automotive News 0 11-03-2010 12:27 AM
Review: 2010 Acura ZDX is a space (challenged) oddity Haltech Automotive News 0 04-29-2010 10:20 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Page generated in 0.24287 seconds with 21 queries
