  • 1 Post By kTaLgsTo
  • 1 Post By flapjack
 Old 02-04-2018, 03:14 AM   #1
nicknguyenle's Avatar
Posts: 2   (View Stats)
nicknguyenle is an unknown quantity at this point
Default Low boost issue
everything was perfect after last night, my car lose boost. My boost used to be at 15-16.5 psi at wot. Right now, maximum is ~9.5 psi. I took it to the shop and check for boost leak ===> no sign of leaking. Turbo no smoking, replace new EBCS but wont help. I tried different maps, and even restored to stock map but no help. It still got under boost. My car right now got CS SRI and TIP. HPFP and Cobb AP. i attached log csv file, so anyone could help with my problem ?
nicknguyenle is offline   Reply With Quote
 Old 02-04-2018, 08:28 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
I'll be honest, that log isn't helpful, at least not to my eyes.
sharksinspace likes this.
 Old 02-05-2018, 12:54 AM   #3
i just attached a new log. Plz anyone help
 Old 02-05-2018, 06:53 AM   #4
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Both those logs are useless and tell us nothing. Try to get a log in 3rd gear under full throttle or 4th if you can. Start at 3000 RPM, stomp the pedal all the way to the floor, and hold until ~6500 RPM.
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
flapjack is offline   Reply With Quote
 Old 02-05-2018, 08:30 AM   #5
speed23's Avatar
Posts: 1,480   (View Stats)
Holes in the vacuum lines to boost control? Wastegate arm C- clip feel off so wastegate isnt actually connected and able to close at the hot side to create boost? Seen both of these before on here.
Boost issue Rob84 MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-01-2015 03:22 PM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Boost issue Moosheep Gen2 MS3 General Discussion 6 07-26-2013 07:04 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.26302 seconds with 24 queries
