 Old 01-19-2017, 11:49 AM   #1
Duey1083's Avatar
Posts: 87   (View Stats)
Duey1083 is a splendid one to beholdDuey1083 is a splendid one to beholdDuey1083 is a splendid one to beholdDuey1083 is a splendid one to beholdDuey1083 is a splendid one to beholdDuey1083 is a splendid one to behold
Default P0096
Hey guys,
My car gave me a CEL and my OBD2 scanner gave me the P0096 IAT code. My dealer and myself have both cleaned the MAF, but based on my reading, the problem might actually be the MAP sensor?
I'm not sure which avenue to go with this issue. My car drives perfectly fine, but obviously I'd like to resolve whatever issue it is.
Thanks for any advice!
Andrew
Duey1083 is offline   Reply With Quote
 Old 01-19-2017, 01:35 PM   #2
MunkieJunkie's Avatar
Posts: 51   (View Stats)
MunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud of
I'd probably try inspecting/cleaning the MAP sensor, as this thread leads me to believe the IAT sensor located there ( P0098 intake air temp sensor high input ). I'd start there and see where that takes you.
Edit: After reading a few threads and some other sources the IAT sensor is definitely in the MAP sensor, not the MAF. If cleaning doesn't fix it try to swap it out with a friend's and see if that works. If you can't I'd probably just replace it.
MunkieJunkie is offline   Reply With Quote
 Old 01-19-2017, 03:12 PM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I believe IAT is on the MAF sensor.
boost air temperature is detected at the MAP sensor
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-19-2017, 03:24 PM   #4
That's what I thought too, as all the cars I've owned always had the IAT in the MAF. Some research pointed towards the MAP sensor, though. I could absolutely be wrong though.
In either case I'd check both the MAP and the MAF out and see where that takes you.
 Old 01-19-2017, 03:48 PM   #5
Duey1083's Avatar
Thanks guys!
I have since spoken with the dealership and they agreed the P0096 code comes from the MAP sensor. So they are going to do a few diagnostics for me tomorrow at no charge. They've been good to me!
I asked if the MAP sensor can be cleaned like the MAF sensor and they said no...but I'm not so sure. It seems others have cleaned theirs? I'm assuming the same MAF cleaner could be used to clean the bulb on the MAP sensor.
From my research, the IAT2 error (P0096) is the MAP and the IAT1 is the MAF (P2199?) I think? I could be blowing smoke out of my ass though, haha
One last thing; obviously I don't want to drive around like this too long, but could I cause any harm to my engine with these DTC codes?
Last edited by Duey1083; 01-19-2017 at 03:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-19-2017, 04:29 PM   #6
Yeah you really shouldn't have any issues running around with it temporarily. It will probably just be annoying more than anything.
The Following User Says Thank You to MunkieJunkie For This Useful Post:
Duey1083 (01-19-2017)
 Old 01-20-2017, 01:44 PM   #7
Duey1083's Avatar
Hey guys!
Thank you both again so much. The dealership did some diagnostics on the T-MAP sensor and it is indeed out of spec. They hooked it up to their voltmeter to confirm. So I have a new one ordered!
So, as confusing as it is, do not rush out to purchase a new MAF if the main code is P0096 and cleaning the MAF wasn't successful. It is most likely a fault in the T-MAP sensor
The Following User Says Thank You to Duey1083 For This Useful Post:
MunkieJunkie (01-20-2017)
 Old 01-20-2017, 01:47 PM   #8
Nice! No problem man, I'm sure this thread will help someone else out in the future.
 Old 01-28-2020, 11:10 AM   #9
MarvinM10's Avatar
Posts: 34   (View Stats)
MarvinM10 is just really niceMarvinM10 is just really niceMarvinM10 is just really niceMarvinM10 is just really niceMarvinM10 is just really nice
It did.
MarvinM10 is offline   Reply With Quote
 Old 01-28-2020, 11:20 AM   #10
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
gotta love when forums work the way they're supposed to
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
« unknown misfire | - »
P0096 - Boost air temperature sensor circuit range/performance problem jakk 2010 MS3 - Troubleshoot/Diagnostics 0 01-29-2014 09:51 AM
Page generated in 0.28951 seconds with 24 queries
