 Old 01-29-2014, 09:51 AM   #1
jakk's Avatar
Posts: 3,266   (View Stats)
jakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the world
Default P0096 - Boost air temperature sensor circuit range/performance problem
Has anyone ever seen this code before? I first saw it two nights ago when I started my car after work and it was -6 out. I thought maybe it was just due to the cold temp, so I went home and cleared the code. It was fine the next day until I went to start my car after work last night when it was 0 out and the code came back. I see in the service manual it says the code is only thrown when the ignition has been off for 6+ hours and the other conditions are met. I did try leaving the car sit in my garage last night and the code was still there this morning. I cleared it again but I am guessing it will come back when I start it up after work again.
Mods are in my sig, I have not done any work recently to the car. I'm just wondering if anyone has had this and where to start. I did notice the MAF seems to be one of the sensors the manual mentions, so I'm wondering if MAF cleaner might fix it? Thanks for the help.
Edit: if anyone else ever has this code, it ended up being a bad MAP (NOT MAF) sensor
2012 Black Mica MS3|Autotech internals|SURE ID300 Full3 Aeros|ETS TMIC|UR TP|AP(Stratified 93 and E85 tunes)|NGK one step colder|Forge V2 BPV|JBR RSB|CP-E Stage 2 RMM|JBR shifter bushings
jakk is offline   Reply With Quote
P0335 Crank Position Sensor A Circuit Malfunction dougefresh_ MazdaSpeed 3/6 - Troubleshoot/Diagnostics 140 07-02-2019 04:07 PM
Egr/ o2 sensor problem. meurinj MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-25-2013 05:32 PM
Cel P1288 CHT sensor out of range JefeSpeed MazdaSpeed 3/6 - ECU Computer Tuning 14 01-10-2011 08:07 PM
Recurring CEL: PCM 2006 APV Motor Control Circuit IC Problem bast525
Cobb Access Port/Maps
1 03-06-2009 07:43 AM
Boost Air Temperature on Dashhawk... timv MazdaSpeed 3/6 - ECU Computer Tuning 20 11-23-2008 09:52 PM
Page generated in 0.23013 seconds with 20 queries
