 Old 04-08-2015, 08:04 PM   #1
thedayman147's Avatar
Posts: 1   (View Stats)
thedayman147 is an unknown quantity at this point
Default P0192 code
I'm having problems with car it wants to idle ruff. if you give it any gas the rpms drop or it wants to die. mods include Corksport stage 2 intake,Tip dp with high flow,cat back exhaust,
autotech internals, and ap v3. If you have any advice to help steer me in the right direction that would be awesome.:
thedayman147 is offline   Reply With Quote
 Old 04-09-2015, 09:25 AM   #2
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
as mention in shout,
step 1: KEY ON ENGINE OFF, check fuel pressure on the AP. this will tell us if the in tank pump is doing its job, for the most part.
step 2: start car and check pressure. this will tell us if the HPFP is doing its job.
step 3: turn engine off, then turn ignition back on. the high pressure relief valve should maintain the higher pressure. if it doesnt, you are losing your relief valve.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
The Following User Says Thank You to udntknw For This Useful Post:
xI Leveler Ix (11-01-2015)
 Old 10-01-2019, 05:55 PM   #3
LivinlavidaSpeed3's Avatar
Posts: 5   (View Stats)
LivinlavidaSpeed3 is an unknown quantity at this point
Im having this same issue however when i start the car it dies and the access port says 0 even when running also have codes Pcm,P0579,p2006,eps,u0140
LivinlavidaSpeed3 is offline   Reply With Quote
P0401 code just got my mazdaspeed 3 and this code popped up Steezyms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-23-2014 02:20 PM
PCM code david001wj 2010 MS3 - ECU Computer Tuning 3 03-08-2014 05:03 PM
From one code to another -__- goHAMM 2010 MS3 - ECU Computer Tuning 50 02-07-2014 04:25 PM
EGR code turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 06-10-2011 08:19 PM
CEL - Code 79BlueSC Mazdaspeed3/6 General Discussion 2 12-20-2010 12:06 AM
Page generated in 0.23707 seconds with 22 queries
