 Old 04-27-2019, 01:15 PM   #1
Nickd917's Avatar
Posts: 1   (View Stats)
Nickd917 is an unknown quantity at this point
Default P0303
First time posting on here. Just bought a 2013 speed3 with 40k a few months ago. Recently had gotten a p0303 (cylinder 3 misfire). I put oem plugs in, gapped to .028. Moved around coil packs, still stayed on cylinder 3. Had a compression and leak down test done that came back good. Heres the weird thing.. ive replaced plugs a couple times, and they ALL have carbon build up on the bottom of the plug within 10-15 miles of driving. Next im going to swap injectors and see if it follows that. But a bad injector at 40k seems off. Ive read a little bit about fuel relief valves giving people p0303 codes too.. Pretty narrowed down to it being a fuel or possible electrical problem. Any advice would be lovely at this point.
Car will run almost fine. Idle is a little rough and can hear random popping out of exhaust. At wot i hold boost (so no vacuum leaks) but you can tell the power osnt 100% there
Nickd917 is offline   Reply With Quote
P0303 - Cyl 3 Misfire. tmaiorca MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 05-09-2016 08:49 AM
CEL P0303 stokes620 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 37 11-14-2015 11:53 PM
P0303 561BlackMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 09-10-2013 01:17 PM
P0303 BGofMD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 49 01-17-2012 04:51 PM
CEL P0303 75meters MazdaSpeed 3 - Engine, Transmission & Driveline 5 04-05-2011 04:05 PM
Page generated in 0.21718 seconds with 20 queries
