  • 1 Post By Vansquish
 Old 09-26-2016, 04:47 PM   #1
IzzysAuto's Avatar
Posts: 1   (View Stats)
IzzysAuto is an unknown quantity at this point
Default P2009 Code
Hello everyone new member here to the forums I am finishing up on a 2010 Mazda Speed 3 with 70K miles its all stock except a secondary cat or resonator delete. The car keeps throwing a P2009 code and the local AutoZone cleared the code and told me i needed a new VVT Solenoid which was made by DURALAST Part # TS 1004 which i already purchased for 52.63. What i guess I am asking is this going to fix the code that keeps coming up? Also how hard is it to change out this Solenoid? It looks like i am going to have to remover the valve cover to do this if so could anyone please direct me to a link or video showing me how to do this and once this is finished i will make someone on here the deal of a century on a Mazda Speed 3. The reason I say that is that i have a 2015 Beetle i need to get fixed and sold to pay for my Nursing School.
IzzysAuto is offline   Reply With Quote
 Old 09-26-2016, 05:01 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Click this link. It will open a search box for this forum that works quite well. I wouldn't use anything but OEM for the VVT. YMMV.
https://cse.google.com/cse/publicurl...1oxu#gsc.tab=0
 Old 09-26-2016, 06:07 PM   #3
Police - Grammarhead
Vansquish's Avatar
STOP!
Autozone doesn't know anything about our cars.
P2009 is " variable tumble control system solenoid valve circuit low input"
This is an indication that your Variable Tumble Control System (VTCS) is not functioning properly. It has absolutely nothing to do with the VVT actuator. The VTCS system is a set of flapper valves mounted to a rod that passes through each of the intake manifold runners. There is a small sensor switch that often fails because it contacts a small piece of plastic that, over time, weakens and breaks off.
Here's an image of the parts that I'm talking about: Now what..P2006
(Incidentally, P2004, P2006, and P2009 are all failure modes for the VTCS system.)
DO NOT, under ANY circumstances, do anything with your VVT unless you are 100% sure that the VVT is bad. It's an expensive ($1100+) service, and you do not need to perform it if the code is really P2009.
shawnthom90 likes this.
The Following 6 Users Say Thank You to Vansquish For This Useful Post:
Gerbilo (09-27-2016), sheston (09-26-2016), SofaKingAwesome (09-27-2016), tegxsi (09-26-2016), tek_88 (09-27-2016), Thor Hammer (09-27-2016)
 Old 09-26-2016, 06:11 PM   #4
sheston's Avatar
^^^ This is what I love about this forum
Vansquish (09-26-2016)
 Old 11-12-2016, 02:54 PM   #5
shawnthom90's Avatar
Posts: 4   (View Stats)
shawnthom90 is an unknown quantity at this point
My car just did this the other day. I talked to the Mazda service guy about it and he said there is a sensor that could be the problem or this flapper problem. I bought the sendor part and If that does not work, I am going to do the flapper service.
shawnthom90 is offline   Reply With Quote
 Old 11-13-2016, 05:05 PM   #6
Vansquish's Avatar
I'm so glad you read this thread...
CEL P2009 no idea what it is Highestrich4 MazdaSpeed 6 - Engine, Transmission & Driveline 7 06-12-2016 09:46 PM
P2004 P2009 codes angiehbrown MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-31-2016 08:27 PM
DTC P2004, P2009 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 24 07-14-2015 07:27 PM
P2004 P2009 codes Sphinx1983 Mazdaspeed3/6 General Discussion 1 05-20-2015 08:44 AM
MS6 Throwing Codes P0123 P0222 and P2009 Speedn253 MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-19-2012 11:17 AM
Page generated in 0.29201 seconds with 24 queries
