  • 1 Post By 2012FailWheelDrive
 Old 07-18-2013, 07:07 PM   #1
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
Default P2096 Finally FIXED
code 2096 pop's up so I weld the bung on the Dp, then fix some leaks, and code still there.
hours and hours reading about with no luck, ordered a ATP DP, thinking my CP-E DP would be the proble,...
Then (Thanks to) @2012FailWheelDrive; said, when he grease the BPV, problem fixed.
So I installed yesterday a GFB BOV (50/50) and code gone, now I drove the speed for about 90 miles and no code,
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline   Reply With Quote
The Following User Says Thank You to speeed For This Useful Post:
2012FailWheelDrive (07-19-2013)
 Old 07-19-2013, 06:25 PM   #2
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Glad it worked out!
speeed likes this.
"under construction"
The Following 2 Users Say Thank You to 2012FailWheelDrive For This Useful Post:
Boost_creep (11-25-2013), speeed (07-19-2013)
 Old 07-24-2013, 01:07 PM   #3
speeed's Avatar
Fuck...code came back.....
Will change the dp next week. Just ordered a catless ATP DP....let's see how it works....
2012 LSM MS3
 Old 07-24-2013, 01:20 PM   #4
RLam's Avatar
Posts: 396   (View Stats)
RLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the worldRLam is the leader of the world
Groaned at 7 Times in 3 Posts
Is your secondary o2 sensor in an extended (non-fouler) bung?
RLam is offline   Reply With Quote
 Old 07-24-2013, 01:55 PM   #5
speeed's Avatar
No. Just weld short bung like a month ago.....
2012 LSM MS3
 Old 07-26-2013, 06:06 AM   #6
PushingRedline's Avatar
Posts: 146   (View Stats)
PushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond repute
I just installed the ebay catless dp this past weekend and got this same code (along with P0139). I can't remember if the second sensor is extended or not so I am gonna take a look tonight and also check for leaks.
PushingRedline
2012 Mazdaspeed 3 - Red w/ Tech
-Cobb AP/S-OTS Stage 2
-AT Internals
-JBR 80 Duro RMM
-JBR Stage 3 CAI System
-CorkSport SSP
-JBR Solid Shifter Bushings
-Ebay Catless Downpipe
-NGK Iridium IX 1-step Colder Spark Plugs
-Forge V2 BPv
PushingRedline is offline   Reply With Quote
 Old 08-05-2013, 01:26 AM   #7
msantana101's Avatar
Posts: 1,517   (View Stats)
I get this code about once a month, and just reflash my map to get rid of it. I've noticed my AFRs begin to slowly dwindle down from 14.7-8 or stoic while I idle or drive at cruising speeds, so I'm sure there is some sort of correlation.
FreekTuned
 Old 11-24-2013, 08:35 PM   #8
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
does this still occur for you? you running e85?
code just popped up for the first time this morning. cleared it with the ap but it came back.
plan on unplugging battery to reset ecu then reflash map. hopefully that fixes the issue. gaahhh this sucks.
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 11-24-2013, 08:56 PM   #9
speeed's Avatar
Are you on cpe dp?
Im on tapafuck and cant read your sig. ..
2012 LSM MS3
 Old 11-24-2013, 10:04 PM   #10
turbo test's Avatar
Are you on cpe dp?
No I have an aqmotorsports catted dp, its been on for a good 20k miles with no problems. So I don't think that is the cause. I plan on getting under the car tomorrow and checking for any leaks
Sent from my EVO using Tapatalk
 Old 11-24-2013, 10:27 PM   #11
Haven't had any issues since I got retuned with e85
FreekTuned
 Old 08-07-2015, 08:59 AM   #12
inchuljang's Avatar
Posts: 11   (View Stats)
inchuljang will become famous soon enough
help anyone... having P2096 issues on a stock MS3 2010.
Help: CEL P2096 on stock MS3 2010
inchuljang is offline   Reply With Quote
 Old 05-28-2019, 04:57 AM   #13
Mnassie's Avatar
Posts: 10   (View Stats)
Mnassie has a little shameless behaviour in the past
Originally Posted by Austopist View Post
Cialis Generico Tampico Ebillme Later Viagra How Long Does Zithromax Last cialis 20 mg lilly Buy Clomid Online
Powerpoint Presentation On Amoxicillin Kamagra And Viagra Lasix Diuretic 100mg viagra Propecia Finasteride Msd Donde Comprar Levitra Propecia Ab Wann Wirkt
Buy Levitra Online Canada »cialis Buy Kamagra From India Online Buy Plavix 75 Mg Uk Cialis Ou Pas
Tadalis Sx Soft Internet Prescription Online Cialis Pharmacie Ligne Priligy Sito Ufficiale eva pills levitra Doxycycline 100mg India Amoxicillin Causes Tinnitus
Cephalexin Tanning dapoxetina shopping Generic Dapoxetine
Cephalexin To Treat Hidradenitis Suppurativa viagra online prescription How To Write Out Trazodone Prescription Bentyl Dicyclomine In Internet Ou Est Priligy Vendu
What In the actual fuck? Lol.
Mnassie is offline   Reply With Quote
 Old 05-28-2019, 04:58 AM   #14
Mnassie's Avatar
Amoxicillin Side Effects Rash viagra Buy Viagra In Cyprus 282 Achat De Viagra En Suisse Achat Nolvadex Proviron
I don’t want your stupid rash viagra
 Old 05-28-2019, 04:59 AM   #15
Mnassie's Avatar
Alli Pills Amazon Cialis Tadalafil 20mg Vente Generique Cialis Professional tadapox tadalafil dapoxetine Para Que Sirve Cialis Canda Pharmasey Male Enhancement
I give up. Bots are weird nowadays.
CEL p2096 ? help? RobLoMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 06-29-2012 09:22 PM
Finally fixed my knock problem! ricknm Gen2 MS3 General Discussion 32 06-13-2012 05:00 PM
P2096 Andrew_MPS 2010 MS3 - Turbo Induction 14 01-30-2011 08:35 AM
finally fixed the boost cut with cs sri+tip TheFranchizeSLB 2010 MS3 - Turbo Induction 26 12-11-2010 08:07 PM
My car is finally fixed! volodya84 MazdaSpeed 6 - Engine, Transmission & Driveline 8 05-26-2010 02:36 AM
Page generated in 0.34328 seconds with 27 queries
