 Old 05-05-2013, 11:16 AM   #1
deni's Avatar
Posts: 87   (View Stats)
deni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond reputedeni has a reputation beyond repute
Default post BT install communication problems
So yesterday we did BT install on my 2012 MS3. it starts up and runs fine but im throwing P0403, U0121 and U2023 and I have absolutely NO power steering. I took it around the block to see if all of these warning lights would turn off but no luck; also when going into any sort of boost it feels like i'm bouncing off a rev limiter I don't really know how to explain it. We have checked all of the grounds and wiring harnesses and also tried running the stock MAP sensor with no luck. I'm completely stumped.
gtx3076r
4 doors 4 more whores
deni is offline   Reply With Quote
 Old 05-05-2013, 11:33 AM   #2
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
My money is on something not being hooked up right, etc.
Have you retried clearing the codes?
When they come back, try unpairing the AP, and then reinstalling it over again.
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
deni (05-05-2013), rfinkle2 (05-05-2013)
 Old 05-05-2013, 01:08 PM   #3
deni's Avatar
well tried all of this again, still nothing.
gtx3076r
 Old 05-05-2013, 02:12 PM   #4
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
Need bigger pic. Very hard to see. lol
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
 Old 05-07-2013, 08:41 AM   #5
sassyspeed3's Avatar
Posts: 1,054   (View Stats)
sassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the world
alright, after dealing with this for a couple days and having a set of fresh eyes on the car, we still have no luck.
here is a run down of the problems:
Car drives, runs, bla bla
Speedo doesn't work, ABS light is on as well as the same U codes, power steering doesn't work.
we've traced the ecu harness, checked fuses, checked the power steering pump, checked all grounds and still no luck. we've also installed and uninstalled the AP. can anyone provide some insight?
@chimmike;
@Captain KR;
@robry; @SPEED6 KILLAH;
@phate;
thanks you guys
2013 Mitsubishi Lancer Evolution GSR
2008 Red MS3
BT & All
Eth Mix - 460hp/429tq
Pump - 411hp/403tq
**SOLD**
[02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for
[09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough
sassyspeed3 is offline   Reply With Quote
 Old 05-07-2013, 10:06 AM   #6
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Is the battery good, and are your battery connections tight?
Edit: @timjs is usually pretty good at this stuff.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 05-07-2013, 10:08 AM   #7
Yes. Also it's like the car is in permanent limp mode. Swas is permanently on and car will bounce the rev around 3400rpm
sent from my cleavage via tapatalk
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 05-07-2013, 10:11 AM   #8
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Make sure all the pins on ecu are clean and pointing straight, both on plug side n ecu side
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
deni (05-08-2013), phate (05-07-2013)
 Old 05-07-2013, 10:45 AM   #9
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Thanks for the mention @phate;
P0403:00 EGR valve (stepper motor) circuit malfunction
U0121:00 Communication error to DSC HU/CM (network codes can read different descriptions, depending which module they are pulled from)
U2023 Signal error from PCM
All of these set at the same time?
All of them indicate a possible open circuit. Probably a connector where all of these circuits pass through. I really think you need to go over every single section of that harness.
Maybe focus on the speedo. It gets vehicle speed information from the DSCHU (the ABS module).
Find THAT open circuit, and you'll probably find them all. Make sure the abs module is fully plugged in. Disconnect it, inspect the pins with a bright flashlight, and reinstall it. The connector should have a little slide latch type of mechanism to it, make sure it's fully seated.
timjs is offline   Reply With Quote
The Following 6 Users Say Thank You to timjs For This Useful Post:
atvfreek (05-12-2013), Bucker (05-07-2013), deni (05-08-2013), phate (05-07-2013), robry (05-08-2013), SPEED6 KILLAH (05-07-2013)
 Old 05-07-2013, 03:51 PM   #10
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
Did anybody do any wiring or possibly knick a wire with a screwdriver or a set of pliers? If I were you I would unwrap the tape on the ecu harness and look for burns and frays
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
atvfreek (05-12-2013), deni (05-08-2013)
 Old 05-07-2013, 04:06 PM   #11
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Hmm I had this problem before I forgot to plug in the map sensor in but I still had power steering.
Also had a couple of NA mazda3 which had this codes and have a bad abs module too.
what you should do is double check over your work and then friendly mod dealer
let them look at it. Your are cover under warranty still.
Diagnose a can network system is a pain of the ass lol..
SPEED6 KILLAH is offline   Reply With Quote
The Following 4 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (05-12-2013), deni (05-08-2013), tbot (05-07-2013), timjs (05-07-2013)
 Old 05-08-2013, 03:49 PM   #12
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
Just make sure that the two connectors at the hpfp are connected good and tight, and also check the connector in front of the intake manifold to and make sure it is nice tight, and double check all your ground that you would of taken off when doing this install, and also make sure your batter ground is nice and secure to, I have seen tons of communication errors caused by a loose or damaged battery ground cable.
The P code is for your egr the other two is for abs and your ehps, check your 80amp fuse for that and there is a 7.5 amp for the abs ig check that to and double tripple check all your grounds
deni (05-08-2013)
 Old 05-11-2013, 01:39 AM   #13
Found the problem...
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
The Following 2 Users Say Thank You to sassyspeed3 For This Useful Post:
phate (05-11-2013), snailD (05-11-2013)
 Old 05-11-2013, 07:48 AM   #14
Bucker's Avatar
Groans: 451
Nice!
 Old 05-11-2013, 11:13 PM   #15
Captain KR's Avatar
Groans: 391
Do I win?
Killah Built
The Following User Says Thank You to Captain KR For This Useful Post:
Little John (05-12-2013)
 Old 05-11-2013, 08:27 AM   #16
You know...cause there is a ghost in my garage.
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
Problems after turbo install keke MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-03-2012 09:49 PM
problems with ots map after dp install Zbrit00x 2010 MS3 - ECU Computer Tuning 17 11-03-2011 01:14 PM
BNR Stage III install problems! zenger MazdaSpeed 3/6 - Big Turbo Builds 45 08-10-2011 03:15 PM
ETS TMIC Problems after install (Help!) Bujwazay MazdaSpeed 3/6 - Turbo Induction 17 02-10-2011 07:40 PM
Standback Install Problems bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 25 12-26-2010 04:03 PM
Page generated in 0.37139 seconds with 30 queries
