![]() Join Date: Aug 2017
Groaned at 18 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score My radiator support was broken and my radiator needed to be removed and put back in. Before the radiator was removed the A/C worked perfectly. Now after the radiator was put back in the A/C only works at night. Along with no A/C, the cooling fan also does not kick on when I turn the A/C on during the day. At night it blows perfectly cold and the fans work. I thought that they just forgot to put in a connector or something when putting the radiator back in but now that the A/C works at night I am thinking there is a different issue. What cold this be?
__________________ HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR |
| Not Ranked : 0 score if you paid to get it done, why do you try to fix it by yourself, go back there and ask to complete the job. the ac rad need to be moved to get out the rad support so probably you ran out of freon because it was disconnected or an ac pipe-joint or something got broken in the process... but if you aren t a mechanic with stuff to trouble shoot AC system, there isn't much you can do by yourself unless you learn on youtube how to use cheap ac fluid with propane based but.... By the way, the small plastic part of the under tray is needed for proper cooling
| Suzuki, please come back and bring the Alto Works with you | Haltech | Automotive News | 0 | 12-25-2015 12:11 PM |
| Went Back To The Track Last Night | Payne Racing 67 | Drag Racing | 19 | 03-19-2012 02:48 PM |
| Auto industry works to win back engineers | Haltech | Automotive News | 0 | 01-16-2012 02:50 PM |
