 Old 03-25-2018, 06:45 PM   #1
maritimer95gt's Avatar
Posts: 1   (View Stats)
maritimer95gt is an unknown quantity at this point
Default Starter turns engine extremely slowly and wont start
This problem started up after the car sat for the winter. I put a brand new battery in it, cleaned the cables to ensure a good connection, but still no dice. The starter spins the engine so slowly that that tach barely comes off 0rpm. I figured this might be a cold cranking amps issue due to the fact that it is still in the 40s here, but even after wiring up my explorer with jumper cables, there was no difference in starter speed and the car still failed to start. I'm not sure if the starter needs to be replaced or if there is another issue somewhere else seeing as the starter still turns.
Please help! I need this car moved ASAP!!!!!
2012 Mazdaspeed 3
Brand new as of 12/23/11
HPFP, COBB CAI, 3" Turbo back exhaust wo/cat, Rear engine mount, Cobb AP, TMIC, Drilled/Slotted Hawk Rotors and Hawk Pads
If you're not having fun, you're doing it wrong.
maritimer95gt is offline   Reply With Quote
Car won't start and dealership claims starter and CPE hpfp are the cause GR4YF0X MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 08-27-2015 11:55 AM
Upgraded CDFP in MS6: engine still wont start Imsorryk MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 07-12-2013 01:15 PM
Engine Build First Start....Wont Stay Running Death-From-A-Mile MazdaSpeed 3/6 - Troubleshoot/Diagnostics 30 04-25-2012 05:41 PM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 11:11 PM
Engine Wont Start What So Ever BGofMD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-18-2010 05:31 PM
Page generated in 0.22200 seconds with 20 queries
