 Old 05-08-2019, 07:07 PM   #1
Yelpats03's Avatar
Posts: 3   (View Stats)
Yelpats03 is an unknown quantity at this point
Default Stock tune 3-KR during WOT
This all started when I noticed some knock going on. Since I don't have a RMM, I figure some knock is fine, but I started seeing a few times when the knock would go way high. I figure, without a RMM, ghost knocking being a thing, higher boost temps (AZ here) as well as other factors, this shouldn't be an issue.
And then one day I did my typical on-ramp pull and noticed the KR go up to 8. I thought that was super odd, so I did another pull (dumb I know), this time logging it to see if it was just noise. While the car actually didn't see 8 on the monitor, it did see 3 on the next pull I did in the logs.
Before I go on, here's a mod list:
CS HPFP
Full CBE (stock DP)
CS SRI Stage 2
CS TIP (Need a tune?? Website says not)
Forge V2 BPV
COBB AP V3
Autolite Iridium XP gapped to .03
I ran without the Cobb OTS maps because well, they're shitty. But I decided to test and see if that would improve my AFRs, KR, and a few other things. And it did in almost every part of the graph. With the only KR I'm seeing at low RPM of a maximum of 0.89.
Here are the logs for the two pulls:
https://datazap.me/u/yelpats03/stage...log=0&data=1-2
Log 78 being Stage 0, and Log 79 being the COBB S1+SF
Also, both the stage 0 and stage 1 tune have the WGDC set to -15% if there is overboost, if that's relevant at all.
EDIT: One thing I did notice as well - The stock tune has the throttle position all over the place while the stage 1 does not.
Yelpats03 is offline   Reply With Quote
 Old 05-09-2019, 06:37 AM   #2
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
You should really invest in a tune and probably close the gap up with your plugs.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 05-09-2019, 10:34 AM   #3
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Yeah I wouldnt be sure where to start but a proper tune and plugs gapped .026-.028 definitely sounds like a good start
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 05-09-2019, 04:11 PM   #4
Yelpats03's Avatar
Protune was the next step when I get a DP.
I still don't know where to start either lol. Considering I have mods that don't require a tune I couldn't figure this out. And I gapped them to .03 because that was within factory spec, but I didn't realize the OTS tune required lower. Guess I can go do that. Wasn't planning on running the OTS tune either, but if it's safer I will.
 Old 05-09-2019, 06:32 PM   #5
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
FYI
The factory plugs on my 2013 were running just over 0.025" gap.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 05-10-2019, 06:49 AM   #6
Police - Grammarhead
Vansquish's Avatar
Actually, according to the revised Mazda workshop manual for the L3-VDT engine, the spark plug gap is supposed to be 0.024" - 0.027".
stock tune wot KR mig02 Mazdaspeed3/6 General Discussion 7 11-11-2013 08:09 AM
Stock tune ms3 vs stock s2000 ap1 Tokay444 Street Racing Stories ( Bench Racing ) 28 08-26-2011 03:49 PM
FFS on an otherwise stock tune SpdFreak
Cobb ATR Support
5 04-29-2010 05:37 PM
Page generated in 0.26145 seconds with 24 queries
