 Old 04-06-2019, 08:14 AM   #1
Speed3kid93's Avatar
Posts: 59   (View Stats)
Speed3kid93 has a spectacular aura aboutSpeed3kid93 has a spectacular aura about
Groaned at 18 Times in 7 Posts
Default Trouble codes everywhere not sure what’s happening
2011 speed 3
Full bolt ons with purple drank e50 tune stock turbo
Out of no where I got p0171, p0172 and p0300 all at once.
Car drives okay at part throttle but is super lean at idle and WOT. It’s also bogging down really bad at idle like it wants to stall
Cars hitting 19-20 afr at idle. Normally is 14.7,
Tried cleaning the mad, tightened all cupplers, cleaned egr, ran sea foam thru the car ANd did a smoke test
I don’t know what’s causing this. I’m thinking it’s either a huge vacuum leak that I somehow didn’t se or the purge valve.
Please help
HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR
Speed3kid93 is offline   Reply With Quote
 Old 04-06-2019, 10:50 AM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Its probably a pre turbo leak. Do a boost leak test and then a log. if it was a post turbo leak like the purge valve or a opening in the system you would be running rich at wot and lean at idle.
Do a boost leak test from the filter. spray soapy water everywhere while testing. you will be amazed how many leaks you find this way vs "smoke testing". if it was a huge leak the car would run like dog shit
How-To NATOR A Boost Leak Tester for $15
Dont use seafoam it will fuck up the o2 IMO.
MECP
2012 BM
Rfinkle tune in progress
Mazda OBD-II Trouble Codes Haltech MazdaSpeed 3/6 - ECU Computer Tuning 9 06-18-2019 05:12 PM
Trouble codes new engine ThatJuanMS3 MazdaSpeed 3/6 - ECU Computer Tuning 13 12-15-2017 03:04 PM
Stocked out my car and now I'm getting trouble codes Brendanb 2010 MS3 - Troubleshoot/Diagnostics 7 09-01-2014 02:15 PM
Trouble codes boostjunky MazdaSpeed 6 - How-To's 5 01-10-2013 07:29 AM
Link to trouble codes...... winniep MazdaSpeed 3/6 - ECU Computer Tuning 2 03-20-2008 07:22 PM
Page generated in 0.23458 seconds with 21 queries
