![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
(Thread Starter) | Not Ranked : 0 score This has happened three times since February, and I can't tell where it is coming from. Any ideas? tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches |
| Not Ranked : 0 score exhaust leak |
| The Following User Says Thank You to Raider For This Useful Post: | aldekei (05-08-2013) |
(Thread Starter) | Not Ranked : 0 score That was my first thought. There is some minimal streaking where the downpipe connects to the turbo, but seems odd that it would only leak like that once in a blue moon. tapawhat
![]() Join Date: Oct 2012 Location: Hackensack, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
| Not Ranked : 0 score @aldekei; I just installed a catless UR test pipe and the same thing has been happening to me recently. It smells, and the smoke comes out randomly after I drive, then stop at a light or stop sign. It does not do it at the first start up, or any start up. Did you ever figure out if it was an exhaust leak, or something else?
__________________ FreekBuilt. I like turtles. |
I've since gone BT with a cp-e downpipe (the corksport design will not work with the atp hotside, btw), and my issue is now long gone. Where is the smoke coming from in your case? If it is coming from your tail pipe and makes your car look like a fog machine, then I would pull your TIP and check for shaft play in the turbo (assuming k04). Otherwise, get under your car and look for signs of a leak. They should be pretty obvious. tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches | |
| Not Ranked : 0 score I'm thinking it's a leak because it's not pouring out like the bad turbo seals problem that these cars have. It's just a quick white/blueish puff randomly. I did have a hard time installing the test pipe, so it may be that. I'll have to check it out.
![]() Join Date: Oct 2012 Location: sarasota fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score I have done plenty of research on the white smoke pouring out my exhaust. Reading many threads I am glad it happens to others. I don't believe mine is turbo seal because it spools consistent. If you run catless like me you run rich, so that is what I believe my issue is. People yell at me all the time "your car's smoking". I have to turn it off at the bank or drive thru. Told the wife the turbo is bad and needs a GTX. |
![]() Sent from, uhh..
__________________ FreekBuilt. I like turtles. | |
| White smoke campaign | kneedraggin101 | Mazdaspeed3/6 General Discussion | 4 | 04-06-2013 09:29 PM |
| Need help, white smoke and cooland gone AGAIN!~ | speed31982 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 02-03-2012 10:56 PM |
| White Smoke | Soriku1489 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 07-08-2010 05:25 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
| finally got the white smoke | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 3 | 01-29-2009 04:53 PM |
