![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 150
(Thread Starter) | Not Ranked : 0 score whats up guys. so monday i decided to put in a 3 gallon mix of e85 on monday, the car is running fine if not better. so i decided to fill back up the same way yesterday. this morning the car is smoking at idle for a few mins then stops. everything on my ap seems to be ok from what i can tell (i aint no expert). i did a datalog yesterday if someone can see if they see anything or what the smoke could be from. mods are cobb downpipe, autotech fuel internals, speed daddy catback, k&n sri |
(Thread Starter) | Not Ranked : 0 score running the stratified stage 2 ots map |
| Not Ranked : 0 score Umm the incredibly lean AFR's could have something to do with it... you cant run E85 on an OTS map, you must be tuned for it. id consider 12.4 the leanest i would go on an E85 blend (tuned my own car on that for several years), but even still most people i tune on a 12.2... you're damn near 13 the entire pull.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | Ireland (04-11-2014) |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score So you're running a OTS map and just decided to throw in some corn? Did you do this to test for knock or...?
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
(Thread Starter) | Not Ranked : 0 score yea i was seeing a little knock here and there nothing major, so someone said drop a couple gallons of e85 to see if it goes away or not. they said if it doesnt go away to its probably just engine noise. im stilling getting about the same knock. so what should i do? just run my car easy or maybe dump some low octane in it. whats causing the smoke? |
| The Following User Says NO Thank You to bshotts422 For This Un-useful Post: | emag remrofni (04-20-2014) |
![]() Join Date: Jan 2013 Location: Tempe AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 898
Groaned at 8 Times in 7 Posts
__________________ TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned ![]() [SIGPIC][/SIGPIC] Sold 08 FJ Cruiser Expo build in progress... | |
![]() Join Date: Apr 2014 Location: clifton park, new York 12065
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 57
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score White smoke comes out of mine too. From the weed |
![]() Join Date: Jan 2013 Location: Spring,Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 788
Groaned at 119 Times in 22 Posts
| Not Ranked : 0 score .
__________________ [SIGPIC][/SIGPIC] 2013 Tech Package // NVS tuned // 35% e85 DYNOCOM eddy current chassis dyno @ 332hp 400lbft ![]() |
| The Following 2 Users Say Thank You to Ireland For This Useful Post: | ms6mil (04-11-2014), SofaKingAwesome (04-11-2014) |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | Ireland (04-11-2014) |
(Thread Starter) | Not Ranked : 0 score here is a couple logs from last week before i put in the e85. why is the afr so high at the end? |
![]() Join Date: Nov 2010 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score You better baby the shit out of it tell the tank is empty and fill up with just gas and hope the smoking goes away |
| The Following User Says Thank You to timmcc02 For This Useful Post: | bshotts422 (04-11-2014) |
(Thread Starter) | Not Ranked : 0 score would it help if i add a lower octane fuel or just keep topping it off with 93 to try and dilute the mix? |
| Not Ranked : 0 score I would go top off with 91 or whatever the map calls for, its not about the octain and baby it. Then get e-tuned asap. You could always just contact an etuner and grab a base map for 3 gallons of E. This is what I would do, I know I love me e map!
| The Following User Says Thank You to DoMiNic For This Useful Post: | bshotts422 (04-11-2014) |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score Why would you add a lower octane fuel?
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
(Thread Starter) | Not Ranked : 0 score do you have a turner to recommend so i can get a base map asap while im at work? and i figured lower octane might would help. guess i didnt read enough on e before putting some in, i thought 3 gallons wasnt that much |
You need to scale your fuel injectors to add more fuel so the car can accurately compensate for E85. Also, looking at your knock. While it is consistent, anything under 1* is likely just noise. The computer's logic is to pull 2x the "knock event detected," in timing. Basically a "knock event" of 1* will pull 2* of timing. Anything under 1* i'd brush off as chatter, between 1*-2* is something to keep an eye on to see if it repeats, over 2* needs to be addressed. Your first step however should be a compression test to determine the health of your motor.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
| The Following 3 Users Say Thank You to Voltwings For This Useful Post: |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
This. Essentially; E85 has less specific gravity meaning you need more of it to equal the same energy output as 91/93. | |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Voltwings (04-11-2014) |
| Not Ranked : 0 score LTFTs are at 15, I'd also be doing a MAF
| The Following 2 Users Say Thank You to Ireland For This Useful Post: | trancehead (04-11-2014), Voltwings (04-11-2014) |
![]() | | #19 | ![]() |
Groans: 33
| Not Ranked : 0 score That has nothing to do with his MAF cal. It's because of the E content.
![]() | | #20 | ![]() |
| Not Ranked : 0 score For sure, but I wouldn't think that much.
![]() | | #21 | ![]() |
![]() Join Date: Oct 2012 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 252
| The Following User Says Thank You to Sergeant_M For This Useful Post: | Ireland (04-11-2014) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score The car is running lean because the injector scalar is not set correctly for the E85 blend. However this is not causing the white smoke and while not ideal it is not dangerous to run until the tank is empty. So run the tank out, put in 93 pump fuel and then decide if you want a map done for E85. You don't need to rush into getting a base map for the fuel you are running ASAP. Doing things in a rush usually has poor results. Also if you are running JUST an OTS map from us they are made for the JBR intake, not the K&N intake and that will skew your AFRs as well to the lean side since the K&N is a bigger intake. If you want to run an S-OTS PLUS map, this is going to be setup correctly for your intake. Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune [Stratified Mazda S-OTS+ Tune] - $25.00CAD : Stratified Automotive Controls
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 04-11-2014 at 09:41 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score if i just take it easy over the weekend should i be ok? im working doubles everyday. having to do this at work now. car has about 14,000 miles. this is really freaking me out! didn't think 3 gallons would hurt. what gauges should i set my ap on to keep an eye on? current is hfhp, boost, rpm, knock, and mass air |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,454
Groans: 142
| Not Ranked : 0 score Listen to Lex...he is a god!
__________________ ~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~ |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score ill get the ots map when i get home tonight. and try to do the custom tune in a few weeks after a finishing installing my last upgrades. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Is the smoke coming from the exhaust or the engine bay? What kind of oil are you running? Catted or Catless DP? |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score coming from exhaust, engine bay nothing, downpipe in catted, oil is catrol 5w20 i think. The exhaust has only been on about 6 weeks. |
![]() | | #28 | ![]() |
Groans: 33
Wrong oil sir.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() | |
| The Following User Says Thank You to Dimenus For This Useful Post: | Gr8Speed (04-11-2014) |
![]() | | #29 | ![]() |
Pennzoil Platinum 5W30 is a good oil that is fairly affordable for these cars.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok i cant remember the number but its what mazda dealership put in |
![]() | | #31 | ![]() |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score If your not doing oil changes yourself, ALWAYS check what they put in. When I bought my car, they changed the oil and put 5w20 in. I argued with them that it wasnt correct and actually had to pull the owners manual out and show them. They thought it would be fine with 5w20 just like the mazda 3. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score How does your coolant look? If your coolant looks fine, then there is a decent chance that the thinner oil is leaking through turbo seals. |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok i just went to check is is 5w30 |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok i just went on lunch break and still smoking pretty bad at idle afr is idling a 14.5. i still have a full tank. is it serious enough to go have a tank emptied? |
![]() | | #35 | ![]() |
If you have very thin oil in the car it could be the turbo seals.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | mxlplx71 (04-11-2014), Sergeant_M (04-11-2014) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Like Lex said, e85 isn't going to cause what you are describing. Can you take a video of the smoke? The color and smell of the smoke will give you a good idea of what is getting burned up. |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score man i feel so stupid for doing this. last thing i need is to fuck up my car. ill take a video when i get off, it might be late tonight before i can post it. the smoke doesn't really have an usually smell. it was drifting about to my passenger door then gone. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score You didn't get out and smell it? |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea smells like exhaust no burnt oil or anthing Sent from my iPhone using Tapatalk
__________________ BNR S3 V2, Cork Sport TMIC, Cobb Down pipe, Speed Daddy Cat Back, Auto Tech fuel internals, Cobb AP V3, Cobb TIH, K&N SRI, Cobb RMM, Cobb 3 port, Bosch 3 bar, Cork Sport BPV, Cork Sport hood struts, MD SSP, NGX one step colder plugs, Nitto Invo 235/40zr18, and Guarded by an Angel. Stratified tune with 3/9 E85 mix. Waiting to install MD OCC Up next: Cork Sport 3" intake and WMI |
![]() | | #40 | ![]() |
| The Following User Says Thank You to Sergeant_M For This Useful Post: | Voltwings (04-11-2014) |
| white smoke | Dslatch4 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 11-12-2013 10:06 AM |
| White smoke | aldekei | 2010 MS3 - Troubleshoot/Diagnostics | 7 | 07-22-2013 12:26 PM |
| White Smoke | Soriku1489 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 07-08-2010 05:25 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
| finally got the white smoke | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 3 | 01-29-2009 04:53 PM |
