 Old 04-16-2011, 08:06 AM   #1
LandonElf's Avatar
Posts: 51   (View Stats)
LandonElf is a splendid one to beholdLandonElf is a splendid one to beholdLandonElf is a splendid one to beholdLandonElf is a splendid one to beholdLandonElf is a splendid one to beholdLandonElf is a splendid one to beholdLandonElf is a splendid one to behold
Default Wont shift into reverse
Hey guys, after parking a perfectly fine car and walking into a store, when i came out, the car would not go into reverse. When I press down on the shifter and put it into reverse, it won't engage and just pops right back up. Even when i try to hold it down, the car will not reverse.
The other 6 gears work perfectly fine, but neutral feels kind of hung up as well. I checked all the shift linkages and they are not being blocked or hung up on anything.
Its been at the dealership for 2 days and they cant figure anything out so far. All they have been able to come up with is "maybe its your shifter bushings". Do you guys have any recomendations that will help point the dealership guys in the right direction? I'm really tired of driving a courtesy mazda 2.
Thanks,
2010 Velocity Red Mazdaspeed 3
Forge BPV
Cobb SRI
Denso Iridiums
Sure Shifter bushings
LandonElf is offline   Reply With Quote
 Old 04-16-2011, 08:20 AM   #2
bamorgan7's Avatar
Posts: 76   (View Stats)
bamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond reputebamorgan7 has a reputation beyond repute
Maybe you're in sixth?
bamorgan7 is offline   Reply With Quote
 Old 04-16-2011, 08:48 AM   #3
bewsted's Avatar
Posts: 2,456   (View Stats)
Well if the dealer cant figure it out then you done something GOOD to it!
EWG K04...GETSUM!
 Old 04-16-2011, 08:53 AM   #4
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Monotonous ONE (04-16-2011), NJSPEED3 (04-16-2011)
Refusing To Shift Reverse.. Silver Ecstasy 2010 MS3 - Engine, Transmission & Driveline 9 02-25-2011 11:47 PM
What happens if you shift into Reverse while driving? Haltech Automotive News 0 09-09-2009 06:20 AM
Page generated in 0.24865 seconds with 23 queries
