 Old 11-03-2010, 05:40 AM   #1
Arrow 04' - 09' (GEN 1) MAZDA 3 and MAZDASPEED 3 Mud Flaps In Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
James Barone Racing Mud Flaps for the 04' - 09' Mazda 3 & MAZDASPEED 3 are the highest quality flaps available at a price that's easy to afford. Made from thick Polyvinyl Chloride with a attractive automotive finish these flaps will provide superior protection against rain, snow, mud, dirt and road debris for the life of your vehicle.
$95 Shipped!!
Mounting hardware included.
Here's a link to the product page
gtarman77787 (11-03-2010), jack_hammer (11-03-2010), Sacrilicious (11-03-2010)
 Old 11-03-2010, 05:43 AM   #2
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
nice! can you clarify if the install requires you to drill out the rivets like the rally armor flaps require?
Sacrilicious is offline   Reply With Quote
The Following 2 Users Say Thank You to Sacrilicious For This Useful Post:
JBR (11-03-2010), manelscout4life (11-03-2010)
 Old 11-03-2010, 05:56 AM   #3
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
would these fit speed6's?
I envy your ass raping.
The Following User Says Thank You to SIXual Panda For This Useful Post:
JBR (11-03-2010)
 Old 11-03-2010, 06:19 AM   #4
They do require the removal of the rivets. I chose to use the existing locations for mounting instead of having two additional holes drilled for the outer mounting points. The rivets are aluminum and come out with very little effort.
Thanks,
Jamie
Unfortunately no. I may make up some for the MS6 but that would be after the 2010-11 MS3 flaps are done. I also have rear motor mounts and sway bars for the MS3 in testing now and shift knobs in production so I have a bit on my plate.
Thanks,
Jamie
Last edited by JBR; 11-03-2010 at 06:19 AM. Reason: MSF Database - Automerged Doublepost
Sacrilicious (11-03-2010), SIXual Panda (11-03-2010)
 Old 11-03-2010, 06:31 AM   #5
pewpew
Thanks,
Jamie
oh sweet! what kind of bushings are you using for the RMM? epdm or urethane?
 Old 11-03-2010, 07:35 AM   #6
I chose to use urethane. Urethane has been around since the 40's and is the most durable and common polymer used for suspension bushings in the automotive industry. It's resistant to oil and fuel among other things where EDPM is not. In the automotive industry EDPM is widely used for weather stripping but no where have I found that it's commonly used for bushing applications. I've chosen to use a durometer of 70a only in my mounts at this time. This should provide a happy medium between the popular 65a and 75a bushings currently available. The company manufacturing the bushings for me has produced bushings for Boeing, Toyota and NASA as well as host of other well known companies.
Needles to say this is one part I'm very excited about.
Thanks,
Jamie
 Old 11-03-2010, 07:45 AM   #7
TRex's Avatar
Posts: 3,139   (View Stats)
ETA on RMM and sway bars?
The Following User Says Thank You to TRex For This Useful Post:
JBR (11-03-2010)
 Old 11-03-2010, 07:46 AM   #8
pewpew
Thanks,
Jamie
well, the OEM bushings are all epdm (or some other flavor of rubber). i like it more than urethane simply because it ends up being more comfortable than urethane. ya, i know it's not necessarily the bleeding edge of performance, but then again, my car's DD value is very important to me, so that's why i've always liked the cpe RMM.
regardless, as long as you use a large bushing, it should be a lot more comfortable than mounts like the TRZ...
The Following User Says Thank You to Sacrilicious For This Useful Post:
JBR (11-03-2010)
 Old 11-03-2010, 07:56 AM   #9
Both will be available by the end of the year.
Thanks,
Jamie
 Old 11-03-2010, 08:01 AM   #10
Agreed...EDPM may be a bit more comfortable but 70a is 70a when it comes right down to hardness. Also my business is small and I wanted to go with a proven material. The bushing is very large too.
Thanks,
Jamie
 Old 11-03-2010, 08:17 AM   #11
pewpew
Thanks,
Jamie
from trying out a number of commonly-available RMMs, i have found that hardness only makes up a part of the equation. elasticity also comes into play, and because epdm has higher elasticity, it helps to make a given hardness of bushing feel more comfortable than a equal hardness urethane bushing.
all that aside, though, i definitely agree that since your business is small, the risk of going with epdm is probably too much. cpe has had to deal with a number of epdm-related bushing consistency problems, and i don't imagine that's something you could easily handle (financially) as a small business owner. once you establish your mounts, though, i'd love to see an epdm offering if you ever feel up to the task...
JBR (11-03-2010)
 Old 11-03-2010, 08:35 AM   #12
I will see if the molds I'm currently using will work with EDPM, if so then I'll get some poured. If not, I'll need to wait and get a new test mold tooled. I'm sure that the two cure differently so I think It's unlikely my molds will work but I will check in to it. The investment in tooling alone is huge but they are paid for.
 Old 11-03-2010, 08:47 AM   #13
TRex's Avatar
man....i dont know if i could ever start a business...i mean shit how do you get this stuff made? do you just go around to shops and say hey i want to make this and here is the interest? seems you can make a huge amount of money if you are good but the risk is giant!
haha anyway cant wait for the RMM was looking for a slightly cheaper alternative to the cp-e one and 70 is awsome because i have been stuck between 65 and 75 myself....i can haz RMM and SSP bundle pack =D
JBR (11-03-2010)
 Old 11-03-2010, 09:20 AM   #14
You have no idea how many sleepless nights I've had. Shops don't really care what they make as long as they get paid so research in to the demand is key. So yes when you shell out 3-5K to get a part made the risk is huge. But that's all part of the fun and as long as this is fun for me I'll keep making some new stuff.
Jamie
Sacrilicious (11-03-2010), wankular (11-03-2010)
 Old 11-03-2010, 10:14 AM   #15
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
if you need a sway bar tester, let me know.
it's fun to do bad things
JBR (11-03-2010)
 Old 11-03-2010, 11:01 AM   #16
TRex's Avatar
ditto...im local even =D (st. louis)...but i know you got a bunch of dudes down near you
JBR (11-03-2010)
 Old 11-17-2010, 10:40 AM   #17
spec2k5's Avatar
Posts: 267   (View Stats)
spec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the worldspec2k5 is the leader of the world
Groaned at 55 Times in 9 Posts
I ordered mud flaps from Jamie as soon as he released them on his website. I have had them on for a few weeks now, and I gotta say, they are great. They are thick and very durable. I have bottomed out a few times, and they are holding up without as much as a mark on them. I recently got a garage and the first time I pulled in (its on quite a hill and I had to build up the drive to get it in) I did not have the drive high enough. The front flaps caught on the floor of the garage and almost bent in half. I was thinking I broke them, but pulled back out of the garage and they are still perfect. Great job Jamie on another fantastic product. Sorry for the crappy pics.
spec2k5 is offline   Reply With Quote
The Following 3 Users Say Thank You to spec2k5 For This Useful Post:
Chief_Wiggum (11-17-2010), JBR (11-17-2010), neotide87 (01-24-2011)
 Old 12-13-2010, 06:14 AM   #18
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
After this weekend's snow; these tie with my weathertech floor mats as my favorite 'winter-specific' modification. They've managed to keep the side of my car 1000% cleaner than last winter.
 Old 02-24-2011, 06:20 PM   #19
mroclimbr's Avatar
Posts: 245   (View Stats)
mroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond repute
Groaned at 30 Times in 14 Posts
Why is your floor plywood?
mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles.
mroclimbr is offline   Reply With Quote
 Old 02-24-2011, 07:40 PM   #20
spec2k5's Avatar
It's a shed. Not really a garage...hence the wood floor.
 Old 02-24-2011, 07:54 PM   #21
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
Jamie, I dig those red JB decals. Do those come with the guards? I wouldn't mind having those on my car.
The Following User Says Thank You to dizzydtrain For This Useful Post:
JBR (02-25-2011)
 Old 02-25-2011, 05:58 AM   #22
No, but I could include a pair for you.
dizzydtrain (02-25-2011)
 Old 02-25-2011, 06:09 AM   #23
wood floor burnouts FTW!
 Old 02-25-2011, 09:04 AM   #24
spec2k5's Avatar
mmmmm......burnt rubber and burnt wood smell good together. Almost sounds like I need to use more lube
Difference between Cobb stock map and Mazda stock map? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 10 07-20-2010 05:08 PM
Do mazda 3 wheels fit a mazdaspeed 3? qualm MazdaSpeed 3/6 - Wheels & Tires 8 12-13-2008 11:04 AM
Page generated in 0.43082 seconds with 29 queries
