 Old 03-17-2015, 09:50 PM   #1
bhigdon101's Avatar
Posts: 37   (View Stats)
bhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nice
Default 3.0 intake
im looking to buy an intake soon.. and was wondering what would be the differ beteen the all aluminum and silicon... im on factory k04 for now will be going bnr s3 next year....
any and all input is welcomed..
2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\
bhigdon101 is offline   Reply With Quote
 Old 03-17-2015, 11:30 PM   #2
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Pros and cons for both, detailed in many other threads.
In your case, I would go aluminum so you could change the coupler out if needed to fit the BNR or whatever turbo you go with in the future.. I'm pretty sure that is detailed as well.
Based on the mods listed in your sig, I would suggest you put the money toward something else first like an Accessport and/or hpfp internals. Especially considering you need a tuning device for that intake.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Easter Bunny (03-18-2015)
 Old 03-18-2015, 12:23 AM   #3
bhigdon101's Avatar
yes a ap3 and internals are on very top of my list..
im trying to get all my mods on paper..and make sure I'm getting good parts that I don't have to swap out later down the road. .I have been reading and researching to find out..but came up empty on these two..
I know aluminum will make more noise..
but any other benefit?
silicon will have less clamps..less likely to leak..
any thing else I'm missing?
 Old 03-18-2015, 01:06 AM   #4
danmillerok's Avatar
Posts: 1,566   (View Stats)
He told you this above. An aluminum intake utilizes a coupler to connect to the turbo. This means that you can change the coupler to fit other inlet sizes if you upgrade the turbo.
2013 Mazdaspeed 3 VRM
The Following User Says Thank You to danmillerok For This Useful Post:
Thepedigree13 (03-18-2015)
 Old 03-18-2015, 06:54 AM   #5
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
It's an intake and you're on a k04...any pros or cons for either will be minimal in comparison to each other. The only benefit with the aluminum is the ability to swap couplers in case you turbo swap down the road, like mentioned above. The quality of the part is what you should be concerned with and in my personal experience, JBR has never let me down.
I am currently running their 3.0 sillicone intake before the TRU revision and have zero complaints. I was able to run it with the stock battery box and stock ecu location. However, the bracing clamp was rubbing the ECU cover so I opted to relocate my ecu. Just food for thought.
You should really go AP and internals before all else. Like, you don't even need to put it down on paper, it's a staple in the speed3 mod path. Also keep in mind you will need a tune on deck once you opt for a larger than stock intake. I believe Stratified has MAF cal tables to get you up and running but you should consider an E-Tune after that.
 Old 03-18-2015, 07:10 AM   #6
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
The idea of silicone vs aluminum is that silicone keeps IATs lower before entering the turbo. But at the end of the day, your still adiabatically compressing air in a turbo that most people run out of its efficiency range, thereby producing a shit ton of heat. Even if you see a degree or two pre-turbo, it's coming out post-turbo hot as fuck, so who cares. You're not going to be able to tell a difference. Get the aluminum for flexibility to switch setups down the line.
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following 4 Users Say Thank You to mize13 For This Useful Post:
dev (03-18-2015), Easter Bunny (03-18-2015), ekklesia_ms3 (03-18-2015), Thepedigree13 (03-18-2015)
 Old 03-18-2015, 07:23 AM   #7
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Normally I would be the guy to argue one over the other... but all I have to say to this one is that the aluminum makes more pssssh noises and if you upgrade turbos you can swap the coupler for a different one. The silicone is quieter and a bit more insulated to engine bay heat. Pick whichever looks better to you.
 Old 03-18-2015, 08:10 AM   #8
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i thought bnr uses stock sized inlet?
it's fun to do bad things
 Old 03-18-2015, 08:26 AM   #9
CockWarner's Avatar
Posts: 265   (View Stats)
CockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the world
The beaner has a slightly larger inlet than the K04 [~1/4"]. I think some have been able to muscle a stock-sized coupler onto the BNR -- I'd suggest saving yourself the headache, and getting an appropriately-sized coupler if you go BNR.
2011 MS3
GT3071 EWG | Cobb AP v2 | Autotech Internals | HTP 3.5 | ETS TMIC | CP-E Downpipe | CP-E Triton | DIY PnP Intake Manifold |
Cobb XLE BPV | Grimmspeed EBCS | Bosch 3-Bar MAP | DM OCC | DM PMM | JBR 88 Duro RMM | JBR 88 Duro TMM | Kozmic EGR Delete | JBR TB TIG & Coolant Bypass
CockWarner is offline   Reply With Quote
 Old 03-18-2015, 08:28 AM   #10
Gr8Speed's Avatar
My S2 fit a stock sized intake. The S3 is kinda hit and miss it seems.
 Old 03-18-2015, 08:29 AM   #11
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
Jbr lists the bnr with stock so not sure how to get one sized right? May just use a heat gun and warm it up before forcing it on.
CFI2008 is offline   Reply With Quote
 Old 03-18-2015, 08:29 AM   #12
CockWarner's Avatar
I should've clarified that I meant S3
2011 MS3
 Old 03-18-2015, 08:33 AM   #13
CockWarner's Avatar
Just went back and referenced an old invoice. Looks like I got a 2.5" to 3" coupler [for the BNR S3] when I ordered my HTP intake.
2011 MS3
 Old 03-18-2015, 08:35 AM   #14
Gr8Speed's Avatar
@JgamB; did your intake fit the BNR S3V2?
 Old 03-18-2015, 08:57 AM   #15
If you have no plans to go with any other turbo setup then the stock KO4, the silicone intake is the better performing intake. If you're undecided about your future turbo plans, the aluminum intake would be the better choice. Both fit excellent, we have couplers for any size turbo inlet, they are currently on sale and shipping is included if you live in the US as well.
Gr8Speed (03-18-2015)
 Old 03-18-2015, 09:07 AM   #16
Police - Grammarhead
Vansquish's Avatar
Actually, I have the best answer of anyone here for you. I've run both aluminum and silicone intakes and turbo inlets. I found that silicone allows for more adjustability with respect to location within the engine bay and alignment with other parts, but this isn't really much of an issue with any legit, well-manufactured parts.
So...
Buy the cheapest name-brand one you can find. Peruse the For Sale section here and find something for yourself.
I'm running a CP-E Nano intake and 3" CP-E TIP that I bought for a total of $150.00.
I previously ran the CP-E Nano and a CS TIP for $180.00 combined.
Basically, as long as you're willing to fine-tune your MAF calibration, you can run just about any pieces of pipe you want for your intake, but you damn well better make sure that whatever MAF housing you use has a MAF air straightener in it, or you're gonna have a bad time.
g00s3y (03-18-2015)
 Old 03-18-2015, 09:09 AM   #17
Gr8Speed's Avatar
Convert to SD. Run open turbo. All the honda kids are doing it.
 Old 03-18-2015, 11:17 AM   #18
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Had a Cobb SRI with stock TIP when I bought the car
Then Cobb SRI & TIP
Then JBR original silicone 3" (w 2.875"? MAF)
Now CS full aluminum 3"
I noticed a difference from the SRI & stock TIP to the Cobb TIP. But after that, really not much until I started using e85. Then I went to the 3". Just make sure your MAFCAL is good and you will be fine with whatever you get. It's more personal preference than anything, unless you will be upgrading your turbo down the line also. If you want to hear more sound, go pipe. If you want it quieter, go silicone.
 Old 03-18-2015, 01:58 PM   #19
JgamB's Avatar
Posts: 2,566   (View Stats)
It does fit, but it was friggin tight. After a few heat cycles though, you can remove and reinstall it with minimal effort but still very snug, which I prefer to the 2.5" being slightly too large from the start.
JBR (03-21-2015), WAMBUSHHHH! (03-18-2015)
Cold air intake vs short ram intake knarfies MazdaSpeed 3/6 - Turbo Induction 3 04-27-2010 04:15 PM
Page generated in 0.38098 seconds with 32 queries
