Like Tree3Likes
  • 1 Post By senor blanco ms3
  • 1 Post By JBR
  • 1 Post By JBR
 Old 09-30-2014, 11:57 PM   #1
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Default 5mm Spacer
I bent a spacer, don't ask. lol
Can I order just one?
Raider likes this.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 10-01-2014, 05:14 AM   #2
MBalik's Avatar
Posts: 500   (View Stats)
MBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the world
Can I ask?
And generally no but try contacting the selle directly and asking. Shouldn't be a problem I think
2013 White Pearl Pu
Back to stock.... for now
MBalik is offline   Reply With Quote
 Old 10-01-2014, 05:43 AM   #3
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
I'm gonna ask, how did you bend a spacer?
 Old 10-01-2014, 03:25 PM   #4
I don't even wanna know.
Send us an email please.
Raider likes this.
Cevaes_64 (10-02-2014), littleloogy (10-01-2014), MBalik (10-01-2014), Raider (10-01-2014), senor blanco ms3 (10-02-2014)
 Old 10-01-2014, 05:49 PM   #5
It involves a sheep, KY jelly, and a prybar. That's all the OP shared.
 Old 10-01-2014, 05:50 PM   #6
Hargarbl's Avatar
Groans: 51
No tranny?
The Following 2 Users Say Thank You to Hargarbl For This Useful Post:
 Old 10-02-2014, 08:28 AM   #7
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Not to be a debbie downer but beware of running these with stock length wheel studs, broke one the other day after running these 7k miles.
timmcc02 is offline   Reply With Quote
 Old 10-02-2014, 08:33 AM   #8
I have ARP extended studs. When installing the front studs, the washers I was using stuck together so I thought since the spacer is steel, it would work better. I didn't pay attention to the fact that the only mating surface was on the hub and not out by the hole for the stud. So it bent and I lol'd.
I actually may not need a spacer for the rear though. I'll know later today when I put my new wheels on.
A lot of mods
 Old 10-02-2014, 08:50 AM   #9
Spacers don't break studs. Frequent removal, lack of lubricant and over torquing breaks studs. There is more than enough stud length to run 5mm spacers safely or we would include longer studs.
Yousuf likes this.
 Old 10-02-2014, 08:57 AM   #10
When I did the test fit on the front with my 17x9 +45mm wheels, we got about 5 turns on the lugs before snugging them down. The shop doing my corner balance suggested to go longer in order to get 7 turns. But I also need 10mm spacers to clear the coilovers.
A lot of mods
 Old 10-02-2014, 01:18 PM   #11
timmcc02's Avatar
Maybe it was a fluke but I use a snap-on digital torque wrench on my lugs to 80 ft lbs everytime, it was getting about 5 turns. I checked the other lugs before replacing and they were all torqued still.
10mm spacer + 5mm spacer Atomic41 Wheels & Tires - BLACK 3 12-05-2012 11:47 AM
ptp manifold spacer help? bombdotcom MazdaSpeed 3 - Engine, Transmission & Driveline 37 04-17-2010 06:22 PM
PTP IM spacer bombdotcom MazdaSpeed 3/6 - Turbo Induction 13 02-04-2010 11:03 PM
Page generated in 0.31592 seconds with 25 queries
