 Old 08-01-2012, 01:21 PM   #1
Gavin's Avatar
Posts: 16   (View Stats)
Gavin is a splendid one to beholdGavin is a splendid one to beholdGavin is a splendid one to beholdGavin is a splendid one to beholdGavin is a splendid one to beholdGavin is a splendid one to beholdGavin is a splendid one to behold
Default 70 duro rem gone soft?
i have a jb rear egine mounts. its the 70duro. i got a 3" exhaust made up but it was catching under acceleration on the tunnel cross brace (if that makes sense). what i did was space the brace it off with washers which cured it just fine for about a 2 months then it starts to catch again under hard driving to which i spaced off even more. This cured it once again for around a month and once again the exhaust started to catch again under acceleration. I have space the tunel brace down again, it now has 11 washers in. the only thing i can put it down to is the rear engine mount is getting play in it allowing the engine movement to push the exhaust down.
is this possable. is my mount becoming to soft?
forge built and remap
Gavin is offline   Reply With Quote
 Old 08-01-2012, 02:19 PM   #2
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
that shit doesn't make any sense. but you definitely shouldn't need 11 washers to space out something.
it sounds like the 3" exhaust is the problem.
it's fun to do bad things
 Old 08-01-2012, 02:36 PM   #3
Gavin's Avatar
that was my thoughts at first but surly once I had spaced it once it should stay spaced but the more i drive about it starts to catch again. Im going to try and use those poly exhaust bushes to see if i can stop abit a movement. but it only catches when the engine tilts under abit of heavy right foot.
i am going to take the car back to where i got the exhaust built as it has a liftime garuntee on it but it just seem strange how the catching keeps returning.
Soft brakes after install mazdaspeeding MazdaSpeed 3/6 - Suspension & Brakes 19 08-28-2011 08:16 AM
Genpu section has gotten soft MS33SM Gen2 MS3 General Discussion 86 07-08-2011 04:24 PM
Opinion: Is BMW becoming too soft? Haltech Automotive News 0 03-09-2011 03:50 PM
Soft hum from under hood after car is shut off indianaryan 2010 MS3 - Troubleshoot/Diagnostics 17 06-22-2010 12:08 PM
I went from stiff to soft . ccann26 MazdaSpeed 3/6 - Suspension & Brakes 9 03-23-2009 07:46 PM
Page generated in 0.24144 seconds with 21 queries
