 Old 02-09-2013, 09:10 AM   #1
Elusivellama's Avatar
Posts: 351   (View Stats)
Elusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the world
Default Aluminum adapter stuck...inside the knob
Hey all. I have a heavy shift knob (JBR cylindrical). Love the damn thing.
Removed it and the adapter came with it - it's stuck inside the knob. I was thinking of using some loctite, put it on the stock shifter assembly and leave it for 5 mins at room temperature, then remove it and hope that the adapter stays behind.
Is this something that anybody has run into before?
Last edited by Elusivellama; 02-09-2013 at 04:54 PM. Reason: 5 mins is all the cure time you need...
Elusivellama is offline   Reply With Quote
 Old 02-09-2013, 09:59 AM   #2
Try the Loctite, sounds like a good idea.
 Old 02-09-2013, 10:05 AM   #3
Thanks Jamie. Can I also safely loctite the adapter to my shifter stalk after I get it out? No issues? (by this, I mean my TWM shifter stalk. The OEM shifter stalk is sitting in a box ATM. )
 Old 02-09-2013, 10:06 AM   #4
Yes I think that'll be fine.
 Old 02-09-2013, 04:53 PM   #5
Just to update... the loctite solution works. Word of caution: use loctite 262 sparingly. One, maybe two drops is all you need. Screw the knob onto the shifter stalk at room temperature, and wait 5 minutes. Unscrew the knob and the adapter will be left behind. Immediately grab a wrench or socket and remove that adapter or it will be stuck to the shifter stalk. Soak adapter in alcohol or something, and clean the inside thoroughly before reusing it.
 Old 02-09-2013, 05:14 PM   #6
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I had the same issue, used loctite, and completely fucked up the knob. glad it all worked out for you.
Blue Pu.
 Old 02-09-2013, 05:20 PM   #7
LumberJack's Avatar
Definitely sounds like it could be a hit or miss situation. Glad it worked for you though.
10.36@148 Fastest Gen 2
 Old 02-10-2013, 02:51 PM   #8
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
i had this issue also i just used a pair of vice grip pliers lol.
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
 Old 02-10-2013, 03:13 PM   #9
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
I had this issue with my last knob, used a giant Allen key and lightly tapped it inside the adapter and then twisted it out. Surprisingly, it didn't fuck up any of the threads at all.
My Knob Is Stuck PreyStayShun Mazdaspeed3/6 General Discussion 7 01-27-2013 10:31 AM
Help removing jbr aluminum shift knob adapter ThunderMidget MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 12-30-2011 03:41 PM
Page generated in 0.37340 seconds with 25 queries
