 Old 05-26-2012, 12:28 AM   #1
Mythyk's Avatar
Posts: 37   (View Stats)
Mythyk is a name known to allMythyk is a name known to allMythyk is a name known to allMythyk is a name known to allMythyk is a name known to allMythyk is a name known to all
Default Another happy customer! Shift plate, bushings, and heavy knob
Sorry if this goes a bit long, I'm a tad tired but wanted to post this!
Big thanks to JBR, very happy with my first purchase! Was great about e-mailing me back because I had a ton of questions, especially about ordering stuff up here to Canada. Said it would take about 10-14 days, think I ordered on the 11th and showed up on 23rd. Opened the box, everything looked amazing!
Finally got to install, went well (although me being new to car mods I took my time). I had my car rifled through a couple months back, they took the stock shift knob among other things. I had a $25 replacement until I could save up enough to get the JBR SSP/bushings/knob combo, well worth the wait! The only thing I got a bit confused about were the rubber grommets on the shifter cage. Instructions didn't mention the metal pieces inserted into them that had to be removed before peeling off the grommets, not a big deal though.
Got the black spherical knob with the O-rings, looks great (if a little big), but the feel in hand is phenomenal. Heavy just holding it, but once installed you don't notice as much except for how well gears slide in. Shift plate makes things ridiculously short, I put it to the shortest possible, and love it! Gonna take a bit of getting used to, but felt natural still. Did a little fine tuning, and shifts quite easily now. The bushings also help immensely, the entire experience while shifting feels like it should have when stock!
The one area I ran into trouble was with the air box upon reinstall. I still have the stock air box (will remedy that when I can....) and used the stock rubber grommets from the shifter cage on the bottom pegs of the air box like the instructions said. Put things together and started the car, check engine light was on. The top and bottom fit together, but it looks like there's a big space where the rectangular foam piece is on the front of the air box. It's hard to describe, I don't know cars that well, will try to post a picture when I can.
Has anyone else ran into this problem? Not sure if I just need to readjust the air box, or push the grommets down into the holes a bit more? Will it be a problem to drive the car with the space/CEL on? I'm a bit ignorant in these things, so help/advice/input would be appreciated.
All in all, very satisfied with JBR in terms of the products, instructions, and service. Can't wait until I can get a Rear Motor Mount as well!
P.S. in case I get told to donate: I have donated before, was a few years back, just got onto forums again. I'm only working as a casual, money is a bit tight, but will donate when I can. Love the information and community on this site!
Mythyk is offline   Reply With Quote
 Old 05-27-2012, 09:34 PM   #2
Mythyk's Avatar
Just quick update: CEL came off, was probably just from unplugging the MAF or something.
 Old 05-30-2012, 06:04 AM   #3
Nice write up thanks!!
The CEL was most likely caused by something silly especially since it when away so quick. Nothing with the airbox would cause a CEL.
Thanks,
Jamie
JBR Adjustable Short Throw Shift Plate & Heavy Shift Knob Combo Package In stock!! JBR JAMES BARONE RACING 18 07-09-2012 07:52 AM
JBR SSP + BUSHINGS + HEAVY KNOB = D08SPEED3 MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-22-2011 06:51 AM
Another review jbarone short shift plate, bushings, and knob. bohica17 2010 MS3 - Engine, Transmission & Driveline 18 02-16-2011 07:45 AM
Page generated in 0.23426 seconds with 21 queries
