 Old 04-15-2015, 02:30 PM   #1
Arrow Bosch 3 Bar TMap Map Sensors in Stock!!
Bosch 3 Bar TMap Map Sensor with IAT
Details:
The stock Manifold Absolute Pressure sensor (MAP) is only a 2.5 BAR. It tops out around 23-24psi and accuracy becomes decreased around 22-23psi. To ensure accuracy in those pressure ranges or over, it's critical to upgrade to a 3 BAR sensor.
This manifold absolute pressure sensor precisely measures the absolute pressure in your intake manifold and compares it with a vacuum reference. Plus, it also allows your engine management system to accurately detect inlet air temperature, as well as manifold pressure. This integrated Bosch T-MAP sensors is extremely robust and it's not sensitive to oils, fuels, or fluids
Application:
2006 - 2013 Mazdaspeed 3/6 and CX-7
Includes:
-1 Bosch 3 Bar TMap Map Sensor with IAT
-Carries manufacturers warranty
-Shipping is free in the US
Awal (05-29-2015), ESA (05-29-2015), Mauro_Penguin (04-15-2015)
 Old 05-29-2015, 02:47 PM   #2
We now have the PnP harnesses for these in stock.
Awal (05-29-2015), ESA (05-29-2015), littleloogy (05-29-2015)
Need Help, what size are the threads of the stock 02 sensors? Lymerock MazdaSpeed 3 - Engine, Transmission & Driveline 3 12-15-2008 08:36 AM
Page generated in 0.23927 seconds with 20 queries
