 Old 03-30-2012, 09:26 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Custom intake gasket
I know you make the gaskets, but do you have the ability to make a custom gasket if I give you a template? The ports on my head are large enough that I dont think a standard size gasket will seal.
Also is 1/16th or 1/32 inch thick material available? I dont need the thermal component as much as I want an smooth transition from the im to head.
If anyone can do it, its gonna be you. Lemme know.
2006 Mazdaspeed 6
 Old 04-04-2012, 08:49 AM   #2
Our PTFE gaskets are ported and 1/16 thick so I think you'll be good to go.
 Old 04-09-2012, 01:21 AM   #3
Speeeeeed
06Speed6's Avatar
Gasket matched? My ports are larger than the gasket.
2006 Mazdaspeed 6
 Old 04-09-2012, 05:31 AM   #4
You ports are larger then the gasket we provide or larger then the stock gasket? The ports on our intake gasket are larger then the stock ports.
06Speed6 (04-15-2012), Easter Bunny (04-09-2012)
 Old 04-09-2012, 11:59 AM   #5
shadesofgray19's Avatar
Posts: 794   (View Stats)
I think he is trying to say that his ports are larger than the gasket itself, as there is not enough material remaining after he ports the gasket to match his head. I didn't think it was possible to remove that much material from the head/Intake manifold.
The Following 2 Users Say Thank You to shadesofgray19 For This Useful Post:
06Speed6 (04-15-2012), JBR (04-10-2012)
 Old 04-15-2012, 08:35 AM   #6
Speeeeeed
06Speed6's Avatar
^^^ what he said.
My ports are too big and there isnt enough room on the oem gasket so I need something aftermarket.
2006 Mazdaspeed 6
 Old 04-17-2012, 08:36 AM   #7
I'll need a template.
Everyone that ordered an intake gasket, look in here! ptperformance Mazdaspeed3/6 General Discussion 36 07-09-2009 05:40 AM
intake manifold gasket for speed6 johnac08 Mazdaspeed3/6 General Discussion 0 06-23-2009 02:50 AM
Intake manifold gasket install cm-jp1 MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-01-2009 04:31 AM
Page generated in 0.26784 seconds with 22 queries
