Like Tree11Likes
  • 4 Post By King Scumbag
  • 1 Post By mzr0818
  • 2 Post By King Scumbag
  • 2 Post By ms3blackmica
  • 1 Post By Gr8Speed
  • 1 Post By Justin@Freektune
 Old 05-27-2014, 06:25 PM   #1
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Thumbs up Getting FREEKy With JBR!
Getting Freeky With JBR
Well as some of you may or may not know I was selected by @jbarone; to be apart and sponsored by the James Barone Racing Team on 10/11/2013. Thread found here (Calling out SBMS316! JBR Sponsorship Request Granted!). Shortly there after James Barone Racing was kind enough to initiate my first task by sending me a brand new 3.5” WP All Silicone intake in a special order of white ☺ and a new 51R Small Battery Tray to install and test out! Prior to having the 3.5” WP and sponsorship I was running his Power path Stage II intake system and it was great! Both intakes will be covered in this review!
Also covered in this review coupled with @jbarone; and his quality parts will be the ever so amazing and smooth tuning process with @Justin@Freektune;! Also know as @atvfreek; when I first got started with Justin!
Tl;dr My entire history of working with JBR and the Freek!
Lets get started.
Upon my return home from Afghanistan I had a BIG box of James Barone Racing and other various parts awaiting to be installed in my (at the time) unmolested 2007 Mazdaspeed GT. Did my research and I hit up Justin, talked to him for about a month and got started dat FREEK TUNE.
1st Setup
I was running on 18x8” wheels with 235/45/18 Michellen PSS’s. Average Temps outside were between 90-95 degrees. Twas a hot month!
Mod list: JBR PPS2, JBR TRIO 70d MOUNT SET, BOOST TUBES, RECIRC HOSE, OCC, AUTOTECH INTERNALS and COBB AP V2. NC 93 Octane
@Justin@Freektune; and I started tuning on this setup on MAY 29 2013. Within the same day as getting him the beans he had a base MAP “MAP A” in my inbox. Uploaded the MAP to my AP and on I went. Just in the base MAP itself the car felt and ran sooo much smoother then stock or any OTS tune!
(REFER TO THE ATTACHED DOCUMENTS AT THE BOTTOM OF THE POST FOR DATALOG FILES!)
-May 30th: I had a MAF CAL, Idle Log and 3rd Gear WOT log complete and sent his way. The same night he had “MAP B” sent with increased wgdc and timing.J
-June 1st: had a MAF Cal Log and couple 3rd gear WOT logs sent. That same afternoon I already received “MAP C”, moved wgdc up a little up top, 18.5 psi through the mid range and added a couple degrees of timing. Lets start some 4th gear pulls!
-June 2nd: got some 4th gear pulls on “MAP C”. It was a late night and didn’t get logs to Justin until later that night. Here is a VD Progress.
-June 3rd: That morning I had “MAP D” sitting in my mailbox! Added about a degree of timing. Loaded it up and that afternoon had a couple 4th gear logs and had them sent out.
WEEKEND
-June 6th: Had “MAP E” sitting in my inbox awaiting my actions! Uploaded the Map and went out for some logs. Logged a couple 4th gear WOT runs and sent them to Justin. This MAP was AMAZING!
-June 6th to the 11th: MAP F and G Shown below just kept getting better and better!
All compared together.
The tuning process with @Justin@Freektune; was as smooth as butter! Every day the car felt stronger and as you can see the power steadily increased with more power. Not only more power but smooth curves! Justin answered alllll of my newb questions as best has he could allaborating more in detail on some cases!
Towards the beginning of the year @jbarone; sent me a surprise! In the box was a 3.5 WP all silicone WHITE intake and Small battery tray! At first glance you can’t help but notice the craftsmanship! Top Notch just as it was when I first received his mounts and PP intake last year. It took me a couple of months before I could get the intake in and scrape up some dough for the 51r battery. I was also planning on acquiring more power modifications!
51r Small Battery Tray
The small battery tray was a breeze to install! Following along with Jamies instructions as well as having a basic understanding of the part itself helped greatly! Took approx. 45minutes to an hour to complete (fat fingers) but it went in nicely and still sits perfect! The only gripe I had with the small battery tray kit was that it used a zip tie to fasten the ECU wiring harness. I grabbed a rubber coated C-clip with nut and bolt from work and it worked perfect!
Style of C-clip I used for the ECU harness
3.5” WP all Silicone Intake
The 3.5” WP silicone intake is an awesome piece of equipment! It’s big and meaty! Install time took me about 1-2 hours. While installing it I kept noticing that I couldn’t get it to sit down far enough to line up with the turbo. After numerous efforts of trying to get it to work I removed it to see what was going on. I noticed that the coolant line that runs under the intake sat to high preventing the intake from sitting any lower. I simply adjusted the line pushing it down the nipple a little further, which in turn pushed the hose down and out of the way. Started again on getting the intake installed and everything went smoothly from there. From there I got everything else hooked up and then got to the VC breather hose. I don’t know if it the updated VC that has the downward facing nipple or the strait nipple but I have the downward facing VC breather nipple. With JBR’s WP 3.5” silicone intakes his breather portion is towards the rear and exits out of the top. Getting a hose to and from the VC to the intake is still a hassle. I’ve tried many different setups to keep the hose from kinking but I have just ended up buying a VC with a strait nipple and that should solve my problems. All in all this intake has treated me well! At first I did my own MAF Cal to get buy with a MAP I had from @Justin@Freektune; and get the car running. I was waiting for the rest of my mods to go ahead and re-tune!
(I had pictures of the problem areas as well as updated pictures after 10k miles but they were on an old phone ☹. My HPFP hardline broke last month while removing my HPFP and I chucked the phone off a wall. Lol)
Night the WP surprised me in the mail!
PARTS! ☺
Parts getting installed at @mzr0818;s house NATOR NC/SC HQ!
WP Installed
Finally got everything installed! Was in the process of another tune on E85 that was not working out to well at all. Shit was rough and my car was running even rougher! I know @mzr0818; and a lot of the NATOR NC/SC guys there helping me through everything saw the struggles I was having. My plan was to be fully tuned and ready to go by ENM but it wasn’t looking that way at all! That’s when I contacted Justin. I cannot thank this man enough. It was days before ENM and needed help. Told him what was up and we started working on it that same day!
Current FREEKTUNE and Current Mods.
I was running on 18x8” wheels with 225/45/18 Dunflops. Average Temps outside were between 80-95 degrees. YESS its hot here in SC during April!
Mod List: COBB FMIC, J2 Catless DP, HKS CBE, AT Internals, JBR 3.5” WP silicone, GFB valve, JBR Trio 70d Mount set, NGK IX step colder plugs, JBR OCC and running on 3 gallons E85.
-April 7th-10th: Sent Justin a copy of the last MAP “F” that we used in our last tuning process. He sent back to me the initial MAPS A and B to get the MAF Cal down completed.
-April 10th 2014: MAP C comes in and it’s ON THE MONEY! Everything was perfect and the car had been running better then ever! I had a few months of nothing but hassles and they no longer existed! Just in time for ENM! Here is a VD and actual dyno done at Moore during ENM. I hope to have 93 numbers in the future for comparison!
VD
Dyno at Moore.
This tune is still my current tune and is still running awesome! Unfortunaetly the E85 station near by recently shut down ☹. Justin helped me out with a new 93 Map though!
All and all you can not go wrong with the outstanding parts that @jbarone; provides for this platform and amazing tunes that @Justin@Freektune; does to bring these parts to life!
Any questions, concerns gripes, or complaints let me know and I will do my best to answer and or fix it !
JBR, 6Y MAZDA, trancehead and 1 others like this.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 24 Users Say Thank You to King Scumbag For This Useful Post:
6Y MAZDA (05-28-2014), Agent_Orange (05-27-2014), alaskazero (06-16-2014), Benis (05-27-2014), Chief_Wiggum (05-28-2014), Code Monkey (06-09-2014), covelife1016 (05-27-2014), CrawlingMS3 (05-28-2014), cshunter (06-04-2014), Gr8Speed (06-09-2014), Hush (05-27-2014), JgamB (05-27-2014), Justin@Freektune (05-27-2014), Kellerspeed3 (06-09-2014), Mattcinnc1 (05-27-2014), Mauro_Penguin (05-28-2014), ms3blackmica (06-09-2014), ms6mil (05-27-2014), mzr0818 (05-27-2014), Quigs (05-27-2014), southernspeed1669 (05-27-2014), trancehead (05-28-2014), XxSmarTz (05-28-2014), [R]usty (05-28-2014)
 Old 05-27-2014, 09:14 PM   #2
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Nice review man, makes me want to get on that E. Did you end up switching out the Go Fast Bits BOV?
Was that picture taken at Broomfield landing?
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following User Says Thank You to covelife1016 For This Useful Post:
King Scumbag (05-27-2014)
 Old 05-27-2014, 09:21 PM   #3
Yes I am still running the GFB.
I'd say hit up the place in Yemesse for E but it's not there anymore. I'll be checking on another source in Yemassee tommorow. Lmk if your interested and I can get you a couple 5 gallon jugs so you don't have to make a 30min trip every time you fill up just keep the cans on standby.
I have no idea where that is lol. I just know it's a little strip of road that ends in the water right by the bridge that goes from Downtown Beaufort to Lady's Island
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-27-2014, 09:34 PM   #4
Ahh, Whitebluff Plantation is the name of that road.
I know the Parker's in Bluffton off of Buckwalter has E85. I am too busy with work right now to start tuning again. I had to pick up another job, thanks for the offer tho. Good luck on finding E station.
2010 MS3 non tech
TUNED BY STRATIFIED
 Old 05-27-2014, 09:34 PM   #5
JgamB's Avatar
Posts: 2,566   (View Stats)
Sorry to hear about your loss of the Eth It's magic and used appropriately (3/9 mix) it's just about bullet proof in reliability and power.
I'm anxious to see what kind of power returning to 93 oct yields, and if @Justin@Freektune; is game for the experiment, I'd like to see your old 93 revision F rescaled for just the larger ID intake.
You need a meth kit! Getting your car neutered by half a Civic worth of HP isn't fun. Tell Jamie to get crackin on a perfect meth solution in addition to all the other stuff he's working on!
 Old 05-27-2014, 09:43 PM   #6
Well I have plenty of containers so jus lemme know and there all yours. We needa meet up some time man.
I hear ya man.
As for the 93 tune, I don't know for sure but I think that's what he did for this 93 map I have. Just running down what I have leftover for E. @Justin@Freektune; would be able to answer weather or not it is the original map that the 93 map is based off of.
I am definitely looking into a meth kit. Especially as temps here get well above 115* in the dead of summer .
Yes I know @jbarone; we want a meth kit to go along with that FMIC kit lol
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
JgamB (05-27-2014)
 Old 05-28-2014, 05:33 AM   #7
mzr0818's Avatar
Groans: 221
Great write up and it was a struggle getting there but I am glad to have been a part of it with you...
King Scumbag likes this.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
The Following 2 Users Say Thank You to mzr0818 For This Useful Post:
King Scumbag (05-28-2014), Mattcinnc1 (05-28-2014)
 Old 05-28-2014, 05:56 AM   #8
Default Getting FREEKy With JBR!
Thanks brother!
Can't thank y'all enough for helping me out installs, troubleshooting and especially when we had the spark plug scare!
@MAZ; @omgvance; @guitarzan134; @Mattcinnc1; @dagrimey1; @CrawlingMS3;
And anyone else I May be missing from NATOR NC/SC!
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-28-2014, 12:30 PM   #9
Mattcinnc1's Avatar
Posts: 573   (View Stats)
Mattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the world
We all are glad your running strong now man. I like your review you even put thought into it
2006 Mazdaspeed 6 WWP
Mods: Cobb ap, Freektune ots+, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, JBR RMM, Cpe diff mount, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), JBR shift bushings, corksport rear sway bar, VTCS delete, Dba 4000 slotted rotors, ebc red stuff
Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs
Looks: 15% tint all around, 40% entire windshield, Corksport LED fogs, Corksport stub
Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90
waiting to install (in garage):
Cpe catted dp
Mattcinnc1 is offline   Reply With Quote
The Following User Says Thank You to Mattcinnc1 For This Useful Post:
 Old 05-28-2014, 12:49 PM   #10
Thanks man. I did the best I could with what I had, everything got lost when my computer crashed after ENM so I went back this weekend and tried to pull everything together again. Tough past couple of months have been tough!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 06-04-2014, 07:14 PM   #11
Stay tuned for 93 results ladies and gents!!! @Justin@Freektune; is getting it done!
Edit: @JgamB; the near future shall answer your questions
cshunter and JgamB like this.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
covelife1016 (06-04-2014), JgamB (06-04-2014)
 Old 06-09-2014, 12:36 PM   #12
knocturnal's Avatar
Posts: 266   (View Stats)
OOOOO WHALE PENIS comes in white?!?!?!?!
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 06-09-2014, 02:48 PM   #13
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
I think @Justin@Freektune; had 90 mentions for just one thread.
LOL.
Good stuff man.
www.tunedbynishan.com
Justin@Freektune (06-09-2014), King Scumbag (06-09-2014)
 Old 06-09-2014, 04:33 PM   #14
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
LOL.
Good stuff man.
Just in case he didn't get the message @Justin@Freektune; you've been mentioned.
ms3blackmica likes this.
 Old 06-09-2014, 08:14 PM   #15
LOL.
Good stuff man.
5 to be exact!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
Gr8Speed (06-09-2014), ms3blackmica (06-09-2014)
 Old 06-09-2014, 08:34 PM   #16
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Everyone's got jokes lol @ms3blackmica; @SBMS316; @Gr8Speed;
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Gr8Speed (06-09-2014), King Scumbag (06-09-2014), ms3blackmica (06-09-2014)
 Old 06-16-2014, 04:43 PM   #17
A little update since I never added the pictures. For peeps with the small battery tray. This is what the rubber coated c-clip looks like for the ECU harness.
I grabbed this one from work but I'm sure can be had for cheap at lowes or Home Depot.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
A Freeky little build atvfreek 2010 MS3 - Big Turbo Builds 432 01-15-2016 08:22 PM
Freeky new tuner Justin@Freektune FREEKTUNE 104 06-25-2014 08:16 AM
Page generated in 0.66012 seconds with 29 queries
