 Old 02-25-2011, 07:02 AM   #1
ganderson's Avatar
Posts: 37   (View Stats)
ganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant futureganderson has a brilliant future
Default Heavy Shift Knob... Installed!
I was a little bit of a pain to orient it where I wanted it (all the way down against the boot), but it looks and performs great!
Everything said about it is true: It smoothes out the shifting feel a lot. There is a sense of "gliding" from gear to gear vs the notchier feel with the stock knob.
If I had to critique something, it would be the plastic capsule on top with the shift pattern graphic. Mine has a bit of give when you push down on it which takes away from the super-solid feel of the knob and it is very reflective and plasticy looking. Minor Critique.
Also, obviously this is a big hunk of metal with no real insulating layer so it is quite the heat/cold sink. It wasn't that cold this morning and every time I touched the knob I was reminded that It was around 40 degrees overnight and this lasted well after the interior had warmed up. I'm in central Texas so I'm a little concerned about the upcoming summer heat.
To Jamie: Have you considered producing a custom "Knob Coozie" of some kind that we could keep in our cup holder and slip on to give a little insulation when not driving?
2011 Mazdaspeed3 - Liquid Silver
JBarone Solid Shifter Bushings, Heavy Shift Knob & SSP Kit, CP-E XcelNano SRI w/ SynOil Filter & 60 Duro RMM, DIY Plate Relocation
Tried & Removed: TRZ Dogbone Poly RMM
ganderson is offline   Reply With Quote
The Following User Says Thank You to ganderson For This Useful Post:
JBR (02-25-2011)
JBarone 6-speed Heavy Shift Knob? F**KING AWESOME!! alien_sporez JAMES BARONE RACING 14 04-11-2011 09:04 PM
Does anybody make a heavy ROUND shift knob? BLK_MS3 Exterior 20 01-18-2011 08:40 PM
Heavy Shift Knob that doesn't cost $100+ E4Performance MazdaSpeed 3 - Engine, Transmission & Driveline 277 03-17-2010 11:53 PM
Page generated in 0.22410 seconds with 20 queries
