Like Tree4Likes
  • 2 Post By Enki
  • 1 Post By King Scumbag
  • 1 Post By ABSpeed3
 Old 03-16-2013, 12:25 AM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default HOWTO: Align your JBR shift knob the easy way
Today my knob showed up. I spent probably 5 minutes trying to get it lined up right, when I had a thought that turned out awesome on the first try.
1. Get a 3/8" allen wrench. This makes it easier, because of the shape of the allen wrench, but other tools/devices can be substituted.
2. Install the knob. Use the allen wrench or something else to note the angle that the knob sits at when installed.
3. Uninstall the knob.
4. Re-orient the knob to the (incorrect) angle it sits at when installed.
5. Maintaining the off-angle of the knob, insert the allen wrench into the knob via the bottom.
6. Holding the allen wrench steady, turn the knob to orient it properly. It may be worthwhile to have the knob a couple degrees off center (in the counter-clockwise direction), as this can help get it lined up absolutely perfectly.
7. *SLOWLY* reinstall the knob again, as spinning it fast can cause the jam nut to reorient slightly
Hope this helps!
JBR and johnnyboy05gt like this.
breakfstincluded (06-04-2013), cshunter (06-01-2013), JBR (03-18-2013), sidekick (03-18-2013)
 Old 03-18-2013, 10:01 AM   #2
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
I just rotated the sticker with the shift pattern on it.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
The Following 10 Users Say Thank You to Caligula For This Useful Post:
adrager622 (03-18-2013), blam1 (06-01-2013), breakfstincluded (06-04-2013), Dralphy (03-18-2013), msantana101 (03-18-2013), NavySailorMS3 (03-18-2013), Raider (03-18-2013), sidekick (03-18-2013), silvapain (03-18-2013), Voltwings (03-18-2013)
 Old 03-18-2013, 10:21 AM   #3
^^ Don't do that, and I encourage no else to either.
Easter Bunny (03-18-2013), J'sSpeed3 (03-18-2013), sidekick (03-18-2013), superskaterxes (03-18-2013)
 Old 03-18-2013, 11:38 AM   #4
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Pardon my ignorance but is there a scientific reason for that, like counter weight or is it just cause you die a little inside when someone defaces your products? Lol
2012 Mazdaspeed3 Black Mica
The Following 4 Users Say Thank You to GODspeed7 For This Useful Post:
ABolewski (06-01-2013), breakfstincluded (10-09-2014), Enki (03-18-2013), silvapain (03-18-2013)
 Old 03-18-2013, 11:54 AM   #5
Enki's Avatar
It's like peeling the stickers off the rubix cube. Yeah it works, but it won't ever be the same afterwards.
The Following 6 Users Say Thank You to Enki For This Useful Post:
ABolewski (06-01-2013), aggierandy (03-18-2013), El_Diablo (06-01-2013), JBR (03-18-2013), silvapain (03-18-2013), superskaterxes (03-18-2013)
 Old 03-18-2013, 12:20 PM   #6
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
So it seems that someone was clever enough to use threads that were the same, or at least very close to, the same pitch as the shifter is threaded with. Another win for jbr.
Edit: or is the jam nut just a small Allen bolt without a head? Not quite sure of the mechanism.
RapaTapTap
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 03-18-2013, 12:31 PM   #7
Sum1UDidntC's Avatar
Posts: 157   (View Stats)
Sum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond repute
Why not just keep the emblem separate from the knob so that after the knob is on correctly the consumer can put the shift pattern on themselves?
2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW
Mustang Dyno Results:
301WHP 334WTQ on 35% E85
282WHP 325WTQ on 92oct
Sum1UDidntC is offline   Reply With Quote
 Old 03-18-2013, 12:32 PM   #8
Caligula's Avatar
Groans: 185
It was actually due to the adhesive you use. Last summer it melted to the point where I could basically freely spin the shift pattern decal. Seems to stay on okay but if I park in the sun for a while the sticker will rotate.
 Old 03-18-2013, 01:11 PM   #9
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
Mine will do the same, in the sun the decal basically just floats on liquid adhesive, then when it cools it sticks just fine.
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
The Following User Says Thank You to razorscs For This Useful Post:
Caligula (03-18-2013)
 Old 03-18-2013, 01:16 PM   #10
Caligula's Avatar
Groans: 185
I'm thinking Gorilla Glue or something similar will solve that.
 Old 03-18-2013, 12:55 PM   #11
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
I have used a little Teflon tape in the past to make sure the shift knob is nice and snug.
 Old 03-18-2013, 04:55 PM   #12
GODspeed7's Avatar
I used blue loctite... We will see if I can get it off.... Lol
 Old 06-01-2013, 01:53 AM   #13
Paul's Avatar
Posts: 822   (View Stats)
Paul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the world
Groaned at 20 Times in 5 Posts
Mine is 22,000+ Miles old. The sticker came off by itself once. I Super Glued it back on... El Paso, TX... 110F Summers.....
2011 MS3 || Tech Pkg || Shark fin ||
|| HTP 3.5 Intake || || BNR4 || CS TMIC || CS CBE ||
|| CS Boost & BpV Tubes || DENSO IVT22 || FORGE BPV v2 ||
|| AT Internals || COBB APV3 || CNT DP || Koni Yellows || H&R Springs ||
|| JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings ||
|| JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || JBR EGR Block/Delete - OCC - Small Battery box ||
\\|// AJ 91 & E85/91 Mix Tunes by A.J \\|//
|| Window Tints, Lamine-x Headlights/Fogs, Tinted Tails, JDM Rain Guards ||
Paul is offline   Reply With Quote
 Old 06-01-2013, 09:10 AM   #14
Caligula's Avatar
Groans: 185
Related topic, the black coating on mine is chipping off.
Sent from my Galaxy Nexus using Tapatalk 4 Beta
The Following User Says Thank You to Caligula For This Useful Post:
 Old 06-01-2013, 09:24 AM   #15
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Samesies
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
The Following 2 Users Say Thank You to turbo test For This Useful Post:
breakfstincluded (06-04-2013), Caligula (06-01-2013)
 Old 06-01-2013, 10:31 AM   #16
Yeah, that's related.
 Old 06-01-2013, 09:36 AM   #17
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
@ABSpeed3;
The Following User Says Thank You to Manny For This Useful Post:
 Old 06-01-2013, 11:04 AM   #18
Caligula's Avatar
Groans: 185
Well I suppose I could have made a thread about it but it's not that big of a deal. I just wanted to leave feedback on that aspect.
 Old 06-01-2013, 03:13 PM   #19
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Mine chipped too. Looks ugly.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to ABSpeed3 For This Useful Post:
Caligula (06-01-2013), turbo test (06-03-2013)
 Old 06-01-2013, 05:45 PM   #20
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Kind of related because I read in another jbr knob thread that some people had gaps between their knob and the shift boot... I already posted this but here it is again.
I cut a piece off one of my stock shifter bushings and put that on top of the shift boot before I installed my knob. Makes the bottom of the shifter tighter against the shift boot, just to hold it in place a little better. Note: I have no gap...
Crappatalking on my big-ass phone.
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 06-01-2013, 06:05 PM   #21
No gap if install correctly. Adjust the jamb nut up inside the knob further.
Hush (06-01-2013), jfspeed6 (06-01-2013), SeeMeGovan (06-02-2013)
 Old 06-01-2013, 06:09 PM   #22
jfspeed6's Avatar
Posts: 1,508   (View Stats)
jfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the world
I don't have a gap on mine but the finish started to chip in a small area and the sticker on the top spins around. It still works the same as the day I got it. Can't really complain about a free shift knob though (won it OCC meet last year).
2006 Titanium Gray Mazdaspeed6 GT
2002 Mercedes Benz CLK 430 Cabriolet
jfspeed6 is offline   Reply With Quote
 Old 06-02-2013, 06:57 PM   #23
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I love the feeling of @jbarone;s heavy ribbed sphere knob in the grip of my hand
jfspeed6 likes this.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
jfspeed6 (06-02-2013)
 Old 06-02-2013, 08:16 PM   #24
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
Just installed my new spherical knob. It didn't have a shift pattern button on it, so aligning it wasn't an issue.
And I gotta say, I love it. I probably wouldn't have bought it, but I won it so I figured that I'd try it out. I absolutely adore it. Perfect size, easy to grab, easy to shift, and feels amazing in my hand. If you're on the fence about getting it, just pull the trigger. You won't regret it.
On deck: VG Sharkfin Antenna
The Following User Says Thank You to jk_ms3 For This Useful Post:
 Old 06-02-2013, 08:24 PM   #25
SeeMeGovan's Avatar
+1 ^^
I bought a red spherical one and put the 3 o-rings on it. Took a few minutes to get the alignment right but goddamn what a perfect handful of shifting goodness when you're done.
I'm 6'1" and have medium-large hands and I'll try to put the size of this knob in perspective. It's like if your girlfriend went from a small B-cup that's not quite a handful to a proper C-cup that gives all your fingers something to hold onto.
NATOR-WA 'GOVAN'
The Following 2 Users Say Thank You to SeeMeGovan For This Useful Post:
Franky-5-Fingaz (06-24-2016), jk_ms3 (06-02-2013)
 Old 06-04-2013, 08:28 PM   #26
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
my sticker has also moved off place from heat before
And my knob has also chipped in placed I have no idea how
How about a re-coating program? (:
 Old 06-04-2013, 08:48 PM   #27
Yeah, that would be called a warranty.
 Old 06-04-2013, 08:51 PM   #28
Really?? So when the knob becomes chipped enough that I miss how it was brand new I can send it back? (:
ABSpeed3 (06-05-2013)
 Old 06-05-2013, 07:10 AM   #29
ABSpeed3's Avatar
Groans: 133
I would like to do this as well.
CampingCarl likes this.
08.5 CWP MS3 GT
 Old 06-05-2013, 10:08 AM   #30
Caligula's Avatar
Groans: 185
X3.
Page generated in 0.50793 seconds with 37 queries
