 Old 01-16-2014, 08:03 AM   #1
POE
POE's Avatar
Posts: 46   (View Stats)
POE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of light
Default Install Question
So, I'm getting ready to install my JBR Stage-1 SRI.
What is this part? And where do I put it?
In the picture below, I circled the part in question. It's mounted directly to the current (OEM dealer installed) CAI. Not sure what the part is, or if there is a better place to remount it when I install the my new JBR SRI.
I'm replacing CAI with SRI because I live in Minnesnowda and my air filter has been getting filled with winter road grime. It will also make filter cleaning much easier.
POE is offline   Reply With Quote
 Old 01-16-2014, 03:32 PM   #2
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Fuel pump resistor. There should be some tabs that it was originally mounted to longitudinally on the frame horn. Reference page 20 of 23 is installation (red "don't touch" sticker just to the right of the intake) JBR provides for their CAI install, it'll give you an idea of where it's supposed to go. If that doesn't help post up again and we'll get you a better pic.
JBR intake install PDF
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following 5 Users Say Thank You to ibcrusn For This Useful Post:
5doorsoffury (01-16-2014), Agent_Orange (01-16-2014), Mauro_Penguin (01-16-2014), POE (01-16-2014), Quigs (01-17-2014)
 Old 01-16-2014, 03:43 PM   #3
POE
POE's Avatar
That should do it. I'll take another look this weekend. As long as I know there's existing holes in that general area I'll sniff 'em out. Thanks a ton for the help.
 Old 01-16-2014, 08:14 PM   #4
ibcrusn's Avatar
Right on.
'10 VRM MS3
Sir Henry Royce
 Old 01-17-2014, 06:12 AM   #5
Thanks for helping the OP @ibcrusn;
 Old 01-17-2014, 06:34 AM   #6
ibcrusn's Avatar
You bet, anytime.
'10 VRM MS3
Sir Henry Royce
DP install question Mazdaspeed666 MazdaSpeed 3/6 - Turbo Induction 2 05-11-2013 08:40 PM
SRI/ TIP question after install eternally_enduring 2010 MS3 - Troubleshoot/Diagnostics 22 10-28-2011 06:23 PM
install question Vinnie MazdaSpeed 3/6 - Turbo Induction 8 02-06-2010 02:33 PM
FSB install question speedster3_08.5 MazdaSpeed 3/6 - Suspension & Brakes 8 11-27-2008 02:19 AM
mbc install question det_ms3 MazdaSpeed 3/6 - Turbo Induction 30 06-04-2008 07:56 AM
Page generated in 0.26171 seconds with 22 queries
