Like Tree9Likes
  • 1 Post By SLOWHATCH
  • 2 Post By rfinkle2
  • 2 Post By atvfreek
  • 2 Post By ms3blackmica
 Old 05-30-2013, 11:56 AM   #1
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Default JBR 3.0" WP Owners
How much air are you guy flowing under WOT? In the middle of my Strat tune and we've quickly hit a wall with my CS unit sucking down 245g/s which seems to be limiting the true potential of the tune (along with this shitty 91 octane fuel, although im switching to 94)
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
 Old 05-30-2013, 12:17 PM   #2
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
In cold weather I was hitting 310. Still hitting 295 in 55 degree weather.
Note: I do have a full DP and I was getting probably 265-270 on my CS intake that I had previously.
2012 Velocity Red Mica
 Old 05-30-2013, 12:24 PM   #3
speed14's Avatar
Posts: 527   (View Stats)
speed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the world
Same here, CS intake and these numbers look familiar. I keep putting it off, but going to throw in HTP 3" and see what I can gain.
g/s depends alot of your MAF cal too, are you sure this is nailed down? How are your AFRs at wot?
2010 Mazdaspeed 3 | Black Mica
COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs
speed14 is offline   Reply With Quote
 Old 05-30-2013, 12:30 PM   #4
Dimenus's Avatar
Groans: 33
Normally quite good. The log I posted above is an anomaly.
 Old 05-30-2013, 12:20 PM   #5
245 seems low.
CWP_MS3 (05-30-2013)
 Old 05-30-2013, 12:29 PM   #6
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
@jbarone; I think he is saying 245g/s from the CS intake, not your 3".
The Following User Says Thank You to Mike@Stratified For This Useful Post:
SLOWHATCH (05-30-2013)
 Old 05-30-2013, 12:38 PM   #7
Yeah I thought that seemed low though.
 Old 05-30-2013, 12:39 PM   #8
JDMJOSH's Avatar
Here's my latest WOT log
 Old 05-30-2013, 12:49 PM   #9
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
I'm flowing more than that with a Cobb SRI and stock TIP.
Anyone else with a CS care to chime in? I would hope it would flow substantially more than that...
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
The Following User Says Thank You to Tyhackman15 For This Useful Post:
mr.speedy3 (05-30-2013)
 Old 05-30-2013, 12:57 PM   #10
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
I'm with this guy, I flow more on my tiny SRI/TIP combo... in Arizona heat (already in daily 100 degrees)
 Old 05-30-2013, 12:51 PM   #11
PPD369Speed3's Avatar
Posts: 785   (View Stats)
PPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the world
Groaned at 97 Times in 19 Posts
As soon as I get done work I can post a log. Just finished up a 93 freektune. Filling her up with e85 within the next couple days.
probably tappin dat ass
2011 Speed3
BNR S3 / HTP 3" Intake / Grimspeed EBCS / AT Internals / Cobb AP / UR Catless TBE / ETS TMIC / Forge V1 BPV / JBR 88 Duro RMM / Eibach Pro kit / SPC Camber Arms
Freektune in progress
PPD369Speed3 is offline   Reply With Quote
 Old 05-30-2013, 12:52 PM   #12
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I saw my CS intake and tip combo max out around 240-250g/s on a hot day. Highest recorded was on a very cold day somewhere around 275-280g/s. Nothing abnormal if the maf is dialed in correctly IMO.
The Following 2 Users Say Thank You to SLOWHATCH For This Useful Post:
atvfreek (05-31-2013), rfinkle2 (05-31-2013)
 Old 05-30-2013, 01:02 PM   #13
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
I just finished up a RichTune and with my cs Sri/tip I flowed (flew?) 280g/s max.
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
The Following User Says Thank You to MizzyMS3 For This Useful Post:
JDMJOSH (05-30-2013)
 Old 05-30-2013, 05:22 PM   #14
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
hmmm that is low I would assume you should hit 300 grams per second with a 3.0 intake with the proper tune. I am almost hitting 300 g/s on my rich tune revision with a injen cold air intake, but when I am ready to make more power such as a BT I am for sure going with a jbr WP
 Old 05-30-2013, 05:33 PM   #15
Ireland's Avatar
Posts: 1,419   (View Stats)
Ireland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the world
Groaned at 119 Times in 22 Posts
My CS sri/tip is in the 290's and im in the begining of a tune
2013 Tech Package // NVS tuned // 35% e85
DYNOCOM eddy current chassis dyno @ 332hp 400lbft
Ireland is offline   Reply With Quote
The Following 3 Users Say Thank You to Ireland For This Useful Post:
himurax13 (05-30-2013), i8urgti (05-31-2013), JDMJOSH (05-30-2013)
 Old 05-30-2013, 10:27 PM   #16
JDMJOSH's Avatar
hmmm, wonder whats causing my flow issue then. Well, im going to take off the air filter tommorow and inspect the MAF housing. Maybe the filter needs cleaning (doubt it)
 Old 05-30-2013, 10:35 PM   #17
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Another thing to consider, is the shitty cotton whatever filter they use. Not sure if they changed it in the last year, but mine is junk and don't flow shit.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
JDMJOSH (05-30-2013), SLOWHATCH (05-31-2013)
 Old 05-30-2013, 10:43 PM   #18
Ireland's Avatar
They still rockin the cotton
The Following User Says Thank You to Ireland For This Useful Post:
amggilly305 (05-30-2013)
 Old 05-30-2013, 10:44 PM   #19
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Hmm. I bought mine early last year. I am hitting in the mid 280's on 91 octane on my K04. With the beaner I was hitting above 360 if I remember right.
Sent via blown passenger side speakers.
Pickles Tune in progress
 Old 05-30-2013, 10:28 PM   #20
amggilly305's Avatar
Posts: 899   (View Stats)
amggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the world
Groans: 92
because pu thats why
KILLAH BUILT
PTE 5862 @29psi
JMF MANI
METH
TUNED BY NISHAN
11.54@123
What does your new map trap
amggilly305 is offline   Reply With Quote
The Following 4 Users Say Thank You to amggilly305 For This Useful Post:
ABSpeed3 (05-31-2013), i8urgti (05-31-2013), Kyle Undefined (05-31-2013), ms3blackmica (05-31-2013)
The Following 3 Users Say NO Thank You to amggilly305 For This Un-useful Post:
Dmurray06 (05-31-2013), El_Diablo (05-31-2013), himurax13 (05-30-2013)
 Old 05-30-2013, 10:47 PM   #21
Dmurray06's Avatar
Yeah, living in the foothills of the Rocky Mountains doesn't help either.lol
 Old 05-30-2013, 10:52 PM   #22
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
I can attest to that. on my final K04 tune with E, i was only flowing 245 g/s, and now on my latest revision of my GTX, with a full 3" intake, i'm only flowing a hair over 300 g/s.
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
 Old 05-30-2013, 10:54 PM   #23
Dmurray06's Avatar
That's depressing
The Following 4 Users Say Thank You to Dmurray06 For This Useful Post:
CWP_MS3 (05-31-2013), himurax13 (05-31-2013), Mortose (05-30-2013), Roddiy (05-31-2013)
 Old 05-31-2013, 07:13 AM   #24
agentgordon27's Avatar
Posts: 560   (View Stats)
I was in the CS section and someone was asking about how to fit the stock maf size CS intake on a GTX2867r, this is on the K04 and your topping out right?
Dayum, that dood is gonna have fun getting 290hp on BT. @NCspecV81; check this out before trying to suck BT air through a stir straw.
Stock as fook.
 Old 05-31-2013, 09:31 AM   #25
With my jbr 3.0 on a 4th gear pull I got up to 275 g's. I'm about finish a 93 tune and going to start on e85 shortly. Also it's probably not flowing as well as it should be of the humidity. It gets very humid in Philadelphia.
2011 Speed3
The Following User Says Thank You to PPD369Speed3 For This Useful Post:
 Old 05-31-2013, 09:47 AM   #26
The maf g/s is highly dependent on how tight the maf curve is.
I don't think it has been quantified, but the gen2 can correct open loop fueling up to 10% or more, so @ 250 g/s, that could be the ~25 g/s discrepancy. Your altitude is also contributing.
My k04 never hit any more than 265 g/s and I made 338 whp / 362 wtq with a .98 CF.
G/s is not a particularly good indicator of HP.
atvfreek and SLOWHATCH like this.
The Following 8 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (05-31-2013), i8urgti (05-31-2013), Instrument_Guy (05-31-2013), JBR (05-31-2013), ms3blackmica (05-31-2013), SLOWHATCH (05-31-2013), smoogs12 (05-31-2013), YABBAMZR (05-31-2013)
 Old 05-31-2013, 09:53 AM   #27
Instrument_Guy's Avatar
Posts: 167   (View Stats)
Instrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the world
FWIW Josh, I've seen my MAF gs' drop off when it gets warmer. Its our shitty altitude. Get Lex to show you one of my logs when I was tuning with him last year for a comparison.
Instrument_Guy is offline   Reply With Quote
The Following 2 Users Say Thank You to Instrument_Guy For This Useful Post:
JDMJOSH (06-03-2013), rfinkle2 (05-31-2013)
 Old 05-31-2013, 09:59 AM   #28
atvfreek's Avatar
Posts: 7,787   (View Stats)
Like Rfinkle2 said, people use that g/s number way to much to quantify power level. My BNR "flows" 315ish on a hot day, yet I make 400+hp
FYI, the CS intake uses an AEM dryflow filter, which has been proven to be one of the best performing filters on the market.
Edit: As does all of the JBR intakes
Another FYI, one of the first times I got on a dyno to tune my car was when the AP first came out for gen2, and I was testing maf cal, and g/s vs actual hp. So I ran my CS map, then loaded a COBB SF map. Both of these were tested on the street before hand, and wot maf cal was spot on 11.5afr. CS map flowed 255-265 g/s, the COBB SF map was "flowing" 300g/s, boost and timing were the same...... HP/TQ numbers were all within 5hp of each other over the 4 runs I made on those 2 maps. So maf g/s has to be used with a grain of salt.
rfinkle2 and Ireland like this.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
amggilly305 (05-31-2013), i8urgti (05-31-2013), Ireland (05-31-2013), rfinkle2 (05-31-2013), Tyhackman15 (05-31-2013), YABBAMZR (05-31-2013)
 Old 05-31-2013, 02:09 PM   #29
LOL @ Gilly getting groaned.
The gen2's are out in force.
atvfreek and amggilly305 like this.
The Following 7 Users Say Thank You to rfinkle2 For This Useful Post:
amggilly305 (05-31-2013), atvfreek (05-31-2013), himurax13 (06-01-2013), Kyle Undefined (05-31-2013), ms3blackmica (05-31-2013), PUGENE (06-22-2013), zxhoya (06-01-2013)
 Old 05-31-2013, 02:38 PM   #30
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
In all seriouseness though, amggilly305 is right.
Because Pu Lol
I see sometimes people claiming k04's flowing 330 g/s with 3 or 3.5" intakes but its really just the result of an overly scaled MAF curve with the ECU correcting so AFR's look spot on. OP may actually be flowing up to ~275 g/s but would not know due to OL correction. MAF g/s can most certainly be used as an indicator of HP but it is to be taken with a grain of salt as atvfreek said especially if we run E85 which contains more oxygen in the fuel itself than 93 Pump Gasoline w/ ~10-15% ethanol.
Groan me
rfinkle2 and amggilly305 like this.
www.tunedbynishan.com
The Following 7 Users Say Thank You to ms3blackmica For This Useful Post:
amggilly305 (05-31-2013), atvfreek (05-31-2013), Kyle Undefined (05-31-2013), Little John (05-31-2013), rfinkle2 (05-31-2013), YABBAMZR (05-31-2013), zxhoya (06-01-2013)
Official: GM will loan free cars to Chevy Volt owners who have "fire anxiety" Haltech Automotive News 1 11-28-2011 03:23 PM
Report: Nissan offering 2010 "model version up" kit to older JDM GT-R owners Haltech Automotive News 0 04-05-2010 09:50 AM
STUDY: Hummer owners believe they've made "a highly moral consumption choice" Haltech Automotive News 0 09-25-2009 02:00 PM
Ford offering extra incentives to "orphaned" Chrysler owners? Haltech Automotive News 0 06-03-2009 07:00 AM
Page generated in 0.52778 seconds with 41 queries
